I just updated DTL and lost file associations to .isos
I opened the program and told it to create the associations again, which it did, but the icon on the isos is wrong and when I double click to mount, it errors out and doesn't mount
I've tried manually choosing DTL to open an iso and same thing happens
Any ideas how I can get it associated correctly again ?
Usually the isos have the round lightening bolt icon, not the file shaped one as shown below
https://www.neowin.net/forum/topic/1142998-daemon-tools-lite-problem/
Please download this little app (no installation required): http://www.nirsoft.n...ypesman-x64.zip
Extract and start the app, highlight the .iso extension, then in the upper area right-click .iso -> Edit selected File Type
At 'Default icon' enter "C:\Program files (x86)\DAEMON Tools Lite\DTLite.exe,0"
While .iso is highlighted in the upper area right-click the 'open'-entry in the lower -> Edit selected Action
At 'Command-Line' enter "C:\Program files (x86)\DAEMON Tools Lite\DTLite.exe" -shellmount "%1" (with double quotes).
Reboot and check if Double click-mounting is working now.
  On 21/03/2013 at 20:46, Dashel said:
Does it work if you associate with the built-in?
Yes and no, it associates but still gives the error
At 'Default icon' enter C:\Program files (x86)\DAEMON Tools Lite\DTLite.exe,0
Yea thanks I found that and tried that already, it managed to get the correct icon again but same error when I double click
Actually following those instructions exactly completely broke it, changing the locations for ones that were really there got me where I am now
Try:
* running regedit
* delete HKCR\.iso DAEMON.Tools.Lite, delete it
* delete HKCR\DAEMON.Tools.Lite
* Run Daemon Tools Lite, untick integration, Apply, retick integration, Apply
... or don't... why do it by hand. Nirsoft has many good utilities, one of them being file type editor.
If you put in the wrong location for the app, then it will screw everything up, and omtting the speach marks will also screw things up as there is spaces in the path, copy and paste what I have put above into the required places.
  On 21/03/2013 at 21:03, Phouchg said:
Try:
* running regedit
I don't think its association that is the problem now, and DTL works fine if I drag an ISO to the gadget, its just the double click to mount that seems to point to something broken
I`ll give that reg trick a shot though thanks
Yea I used quotation marks "" and 1st I used the path given in the instructions, which broke everything, then I used the actual path and was back to square one only the correct ISO icons was displayed
Try:
* running regedit
Beauty, the reg trick did it thanks :)
