Robbie Khan Reviews Posted May 16, 2014 Reviews Share Posted May 16, 2014 Now featured on Petapixel! Spec34" 3440x1440 Ultra Wide (21:9 cinematic aspect ratio) AH-IPS panel with soft AG coating. 5ms response time. Invisible bezel design.Hardware LUT for high quality accurate colours over all input sources. Calibration software included, calibration device must be user supplied though. Inputs: 2x HDMI, 1x DisplayPort, 2x Thunderbolt 2, audio jack, USB3 hub. Discreet multifunction joystick OSD control. BoxHuge. Way bigger than I was expecting. Mine didn't come wrapped in padding on the outside like some other folks did in the USA though, just wrapped in white plastic on the outside then the box.AccessoriesI got a HDMI lead and Displayport but since I recently bought one and already had it wired up I never unwrapped the bundled cables.The stand is actually metal, the only plastic bit is the trim panel parts along the top. It's quite heavy too. In videos and pics I've seen online it looks plastic. I threw that back in the box because I wasn't going to use it.^The VESA mounting area comes with a protective sticker that you place over the casing and then mount the desk arm plate on to. Protects the case from scratches, a nice touch I thought.The screenIt's huge. bigger than I thought it would be in fact and it's heavy. It comes with a little energy star sticker on the bottom glossy plastic bezel bit (the only bit of bezel on the front really) and as I peeled it off it left a residue. I started to wipe off the residue and noticed that the glossy black plastic area was becoming marred/cobwebbed like black plastic does once it ages. I hate that and it's a shame.Picture of that area below:Why give you a protective sticker for the VESA mount and then put a sticker on the bezel which leaves residue? Kind of a half-assed oversight in my books. I'll end up brushing the whole strip so it's matte instead of glossy in time though so it won't be an issue again.^I also noticed the LG logo isn't exactly in the middle in line with the power LED and joystick button, minor nitpick and most people wouldn't even care, I don't either but this is the kind of thing I tend to notice on stuff generally :pI really like the rear facing connection ports too. I have always hated the ports facing downwards and this is just nice and it all works especially as I am using a monitor arm.^The amount of AG coating is lower than on the Dell U2713HM I had. It's not glossy but it's not matte enough to cause snow on solid light colours. The U2713HM was an improvement over previous Dell screens (U2412M which I also had) in terms of AG coatingOn my desk it's 2 inches shorter than my mousing surface, the Boogiebug XL - That will give some of you an idea of how much desk width this thing takes up!The button and OSDOnly 1 button and it's a directional pad joystick thing which I found works really well. It's nice to see you can turn off the power LED too.Out of the box coloursTo my eyes they looked quite warm. I then went into the OSD and noticed the colour was set to custom and each slider was set to 50% for R G and B.^I plugged in the i1 Display colorimeter and loaded up the LG True Color Finder software. It remains in the system tray and will periodically check to see the monitor is still there to send data to post calibration. This is useful and I'll go into that later.^I ran a calibration using user specified settings. The software is quite similar to other calibration software but doesn't really go into any deep detail with reporting or trends like Lacie Blue Eye Pro or even Xrite's/Datacolor's own software, no big deal, This monitor has it's own LUT built in and the LG software plugs into that. You specify your desired colour temp, luminance and a few other bits and hit calibrate. The monitor locks out the OSD during this and enables the "Calibration" mode in the OSD (it only becomes selectable once you install the LG software and run a calibration).What this mode does is locks the OSD settings for brightness and colour and the LG software sitting in the system tray will keep an eye on this and restore if needed. I noticed that the software also creates an icc profile in Windows and assigns it to the screen and disabling it in Windows made no visual difference to the calibration which is expected since the monitor has had the correct settings sent to it directly. I guess the icc profile is applied anyway for those gfx cards/systems not supporting monitor control.Calibration took about 7 minutes.UsageI've now changed my workflow in Lightroom and Photoshop a bit as the extra resolution on the wide end means I can mimic dual screens on this one screen and then some. Start menu has gone to the left and my Lightroom/Photoshop layout look one of a few ways depending on what I'm processing:Gaming^Grid 2 max everything, perfect fps with vsync on is locked at 50fps for some reason, seems that game or some games will select a fixed refresh rate, in this case 50 when vsync is in use. Vsync off I get 120fps. TF2 gets 150-200~ fps max everything with 4xmsaa even in heated battles on a full server. Recording in Fraps at half res (1720x720) was perfect, was recording TF2 battles with the game running at 120fps.My system is a 3770K @ 4.6GHz, 16GB 1600MHz RAM and a single GTX 780.So far those are the games I've played, been toying with the screen all other times though and I am very very impressed. I have Wolfenstein on pre-order so looking forward to seeing how that runs on this as well as the new Doom 4 beta which comes with it :cool:^ I then fired up the PS3 (I like to play when I feel like a break from photo editing sometimes :p) and at 16:9 I set the OSD aspect ratio to "Original" - Setting it to 1:1 puts a tiny screen with black boxes around all fours. In Original it's like picture 1 above. Setting the aspect ratio to one of the cinema modes it pans and zooms in to fill the screen and to the most extent for some games this is just fine where you don't need to see the top and bottom margins.In either instance of gaming I found no problem with mouse lag. I set the OSD to "High" response time as in Windows I found the Low setting caused too much mouse trailing while the Medium setting was better but High just felt the best. I found no issues with motion though I have been gaming on IPS screens since the Dell 2000FPW days.Movies & TV^This is where 21:9 shines. I fired up Tears of Steel which is in 2160P (well, 4096x1714) and it was glorious. So sharp and looked so good. I then played some 1080P movies which were equally impressive. Not quite as sharp but still highly detailed.TV shows are pretty much exclusively 16:9 so you get windowboxes either side. Not much you can do about that but the good thing is that even still the screen area it takes up is still the same size as a 27" 1440P monitor.Some movies are 16:9 but letterboxed, those you can zoom in to fill the monitor without losing much (if any) content. You need a media player that allows this though. I know MPC-BE/HC does (numpad buttons).Pros & Cons+ Cinematic immersion, amazing for movies & supported PC gaming.+ Uniform colours with no visible backlight bleed (not to be confused with IPS tinge which there is).+ Gaming performance for me was just fine. I have never gamed on a 120Hz monitor but my gaming style in FPSes has adapted to the nature of IPS and I have no problem at staying in the top area of scoreboards in online FPS games like TF2.+ The joystick button is genius, so easy to use and nice.+ Visibly frameless front apart from the glossy bezel part at the bottom.+ Can have a large browser window open AND a 1080P video beside it and you can enjoy both at the same time.+ Hardware calibration means whatever you connect up via the other inputs you will benefit from the calibrated colours too.+ Does not generate much heat. It's been on several hours and it's cooler than my U2713HM. I would say this is mostly down to the fact that this has a power brick so a lot of heat stays away from inside the monitor. The WLED backlight generates little to no heat.- Glossy strip at the bottom of the screen is pointless and will only look poor over time as you wipe it. I've learnt this out already!- Reader mode will disable Calibration mode but when you turn Reader mode off it won't turn Calibration mode back on.- Enabling DisplayPort 1.2 in the OSD did cause random flickering for me even on the Windows desktop. Disabling it solved it. Visually I can't tell any different so maybe 1.2 mode isn't fully working yet I don't know. many others are reporting the same. Let's see if LG release a firmware update.- Hardware LUT only usable via the LG software. True Color Finder stays running in the system tray. It uses 18MB of RAM only.- No USB3 upstream cable supplied. I had to use my own.- Only 1 USB3 downstream port, the other 2 are USB2 ports.Will I miss dual screen? Yes and no. Yes because I liked having a 24" in vertical orientation and reading sites and magazines as they're supposed to. No because this looks way nicer and offers much more everywhere else.Should someone else buy the LG instead of waiting for the Dell version? Interesting question. LG have marketed this display at image and video professionals/enthusiasts and the included hardware features benefit them clearly. I have a feeling Dell may not include some of those features in their version and we can definitely expect to see a higher price (I paid ?830 for the LG). One thing is for certain, Dell's stands and RMA processes can't be beat.I'll remain happy with the 34UM95 as long as nothing breaks on it and LG update us with a firmware to fix the DisplayPort 1.2 flicker :)Additional pics + Video Video UPDATE: 2014.06.16Since writing this review my monitor had developed backlight bleed which I felt was unacceptable. I contacted LG livechat and showed them pictures. They confirmed this was not what they too would call acceptable so initiated an RMA. The monitor was collected on Thursday last week and today have said: Quote ]LG TV, Monitors, AV and IT Support OK it does say repair pending which means it is still being worked on and parts have been ordered. I cannot estimate a delivery date back to you, unfortunately. Looks like my monitor is getting a new panel. Looking around other forums, people have reported some backlight bleed issues with the 29" models too. Weird how mine was fine for the first couple of weeks then got worse but it does seem early batches may well have been affected and LG held stock back from retailers to investigate the issue which would explain quite a lot about the lack of or delayed global stock. These things happen with new stuff I guess :p At least LG has asked no questions about it being imported and are keeping up the 2year warranty. tsupersonic, goretsky, FiB3R and 11 others 14 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/ Share on other sites More sharing options...
Jason S. Global Moderator Posted May 16, 2014 Global Moderator Share Posted May 16, 2014 Fantastic review! really really cool monitor goretsky 1 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596406595 Share on other sites More sharing options...
neufuse Veteran Posted May 16, 2014 Veteran Share Posted May 16, 2014 You know you are getting old when you see "it only uses 18MB of RAM" and you think gawd I remember when I was struggling to get games to run with 640K and some XMS memory 123456789A, Phouchg, MillionVoltss and 3 others 6 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596406617 Share on other sites More sharing options...
Draconian Guppy Posted May 16, 2014 Share Posted May 16, 2014 Very nice review! I can imagine your workflow is now a breeze! I've dealt with leftover sticker residue with alcohol and microfibre cleaning cloths. Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596406619 Share on other sites More sharing options...
theyarecomingforyou Posted May 16, 2014 Share Posted May 16, 2014 Nice review. PS - I find it amusing that you noticed the LG logo being slightly off-centre but opted for an asymmetric stand. The Evil Overlord 1 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596406643 Share on other sites More sharing options...
Chasethebase Reporter Posted May 17, 2014 Reporter Share Posted May 17, 2014 Good lord that FOV in TF2! This is a beautiful piece of kit, and I imagine a pricey one as well, looking at the way Lightroom is arranged in it makes me very happy mind you. Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596407829 Share on other sites More sharing options...
Robbie Khan Reviews Posted May 17, 2014 Author Reviews Share Posted May 17, 2014 As an update, I've uninstalled the nVidia BETA drivers, re-enabled DisplayPort 1.2 and let the monitor stay on for a bit of time and have yet to see a flicker since. Will keep an eye on it though because it does seem like the flicker is there when the screen is initially not warmed up fully at random times. On 17/05/2014 at 18:41, Steve B. said: Good lord that FOV in TF2! This is a beautiful piece of kit, and I imagine a pricey one as well, looking at the way Lightroom is arranged in it makes me very happy mind you. Relative to the size and specifications it's very nicely priced I feel, in the UK it's ?799 (OcUK). Lightroom has a new lease of life and for that I'm very happy! On 16/05/2014 at 19:17, neufuse said: You know you are getting old when you see "it only uses 18MB of RAM" and you think gawd I remember when I was struggling to get games to run with 640K and some XMS memory128MB RAM is as far back to what I can remember :p On 16/05/2014 at 19:08, Jason S. said: Fantastic review! really really cool monitorThanks! On 16/05/2014 at 19:18, Draconian Guppy said: Very nice review! I can imagine your workflow is now a breeze! I've dealt with leftover sticker residue with alcohol and microfibre cleaning cloths. I think it';s a bit too late to sort it with rubbing alcohol since the finish is already marred :( I will just make the whole strip matte with a scouring pad another day I think :) On 16/05/2014 at 19:37, theyarecomingforyou said: Nice review. PS - I find it amusing that you noticed the LG logo being slightly off-centre but opted for an asymmetric stand. The stand works in a way though feel lol. Really though I don't even notice the logo any more. Check out what 1080P movies designed with the cinematic aspect ratio look like: Draconian Guppy, +Zlip792, FiB3R and 1 other 4 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596407879 Share on other sites More sharing options...
neufuse Veteran Posted May 26, 2014 Veteran Share Posted May 26, 2014 You don't happen to know what the wattage of the screen is do you? Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596420543 Share on other sites More sharing options...
notuptome2004 Posted May 27, 2014 Share Posted May 27, 2014 omg that screen looks so damn nice i wish i was rich cause it be nice to have on my system Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596420935 Share on other sites More sharing options...
Robbie Khan Reviews Posted May 27, 2014 Author Reviews Share Posted May 27, 2014 It's not cheap cheap like those large screen Korean displays out there but it's not expensive for what it is I'd say considering there is no competition for it currently so a ?799 price tag is cheaper than what some 32" workstation geared IPS screens are selling for (Dell etc).I paid ?830 for it with shipping from germany but I managed to sell my old dual screens etup for ?400 so this LG really only ended up costing me ?430 hard cash. On 26/05/2014 at 22:49, neufuse said: You don't happen to know what the wattage of the screen is do you? Sure, LG state: Consumption Normal On (Typ.) 80W Normal On(EPA6.0) 56W Consumption Power Save/Sleep Mode(Max) 1.2W DC Off (Max) 0.5W Obviously if you're not using high brightness levels then power consumption will be even less. Factory brightness on mine was 50% IIRC and after claibration I'm at 14. That's a huge drop in power consumption (on my Dell 27" the meter showed consumption go from near 80% draw to about 15%). Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596421269 Share on other sites More sharing options...
notuptome2004 Posted May 28, 2014 Share Posted May 28, 2014 as much as 4K is something that seems liek the obvious go to this seem better . Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596422627 Share on other sites More sharing options...
mrp04 Posted May 28, 2014 Share Posted May 28, 2014 I didn't know about these monitors. At first I thought it was just another one of those stupid 2560x1080 screens, but 3440x1440 is actually a pretty great resolution! I invested a lot in my U3011 (almost 3 years ago!) so I'm going to use this for quite a while longer but that monitor is definitely tempting! Maybe by the time I get a new screen we can have 5040x2160 :P Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596422633 Share on other sites More sharing options...
Robbie Khan Reviews Posted May 28, 2014 Author Reviews Share Posted May 28, 2014 Heh yeah I too think screens of this size and res is the best option for now and... On 28/05/2014 at 05:50, mrp04 said: I didn't know about these monitors. At first I thought it was just another one of those stupid 2560x1080 screens, but 3440x1440 is actually a pretty great resolution! I invested a lot in my U3011 (almost 3 years ago!) so I'm going to use this for quite a while longer but that monitor is definitely tempting! Maybe by the time I get a new screen we can have 5040x2160 :p ... once gpu hardware is capable of running games without dual/tri sli being needed :p Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596422887 Share on other sites More sharing options...
neufuse Veteran Posted May 28, 2014 Veteran Share Posted May 28, 2014 On 28/05/2014 at 05:33, notuptome2004 said: as much as 4K is something that seems liek the obvious go to this seem better . trust me 4K isn't the obvious go to... I looked at 4K panels for work, there are so many disadvantages right now that isn't worth waiting for a year or two on them. 30Hz refresh rate on some 4K displays, or 30Hz refresh if you use DVI or HDMI in general. Backlighting issues, color quality issues, a few lifespan issues already... When Displayport is the standard we wont have to worry about 30Hz in general, but right now most systems still come with HDMI or DVI... Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596423203 Share on other sites More sharing options...
Phouchg Posted May 30, 2014 Share Posted May 30, 2014 On 28/05/2014 at 05:50, mrp04 said: I didn't know about these monitors. At first I thought it was just another one of those stupid 2560x1080 screens Gee, I just got one of those... umm... stupid... hmm. SteveMackinnon 1 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596427177 Share on other sites More sharing options...
DarthPotatoe Posted May 31, 2014 Share Posted May 31, 2014 On 28/05/2014 at 10:32, mrk said: Heh yeah I too think screens of this size and res is the best option for now and... ... once gpu hardware is capable of running games without dual/tri sli being needed :p +mrk thanks for the awesome pictures. Can't wait for mine to come! I have a few questions for you if you don't mind me asking. =D 1. What monitor arm are you using? 2. With the single 780 what kinda frame rates are you getting on what games? 3. Would you recommend this given the price point / refresh rate =p? Thanks mate! Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596428155 Share on other sites More sharing options...
FiB3R Posted May 31, 2014 Share Posted May 31, 2014 Great review, actually enjoyed reading it rather than skipping over stuff like I usually do. (Y) Awesome bit of kit too. Definitely on my wish list for the next time I rob a bank :shiftyninja: :drool: Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596428177 Share on other sites More sharing options...
The_Observer Posted May 31, 2014 Share Posted May 31, 2014 Thanks for the review, am waiting for this to show up in NZ. Wanting to run my rMBP on this. Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596428501 Share on other sites More sharing options...
Cockroach Slayer Posted June 3, 2014 Share Posted June 3, 2014 Thank you for the review and awesome pics! But could you tell us please what monitor arm are you using? Thanks again Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596432055 Share on other sites More sharing options...
Robbie Khan Reviews Posted June 3, 2014 Author Reviews Share Posted June 3, 2014 Cheers all! It's worth noting that this model appears to be out of stock in many places and the UK hasn't even seen stock yet. A bunch of people who have had theirs have posted issues with backlight bleed but mine has been problem free so looks like a stock and/or batch issue "could" be in effect in various regions. As mentioned mine came from Germany so no idea what difference that makes. I'm still enjoying the screen though. Sitting back the IUPS tinge is largely completely gone, it's only really noticeable up close due to the size. You'll get the same effect from a 27" IPS too though like I found with my old Dell U2713HM. The monitor arm is an Ergotron MX by the way. On 31/05/2014 at 15:42, DarthPotatoe said: +mrk thanks for the awesome pictures. Can't wait for mine to come! I have a few questions for you if you don't mind me asking. =D 1. What monitor arm are you using? 2. With the single 780 what kinda frame rates are you getting on what games? 3. Would you recommend this given the price point / refresh rate =p? Thanks mate! As 1 has been answered above :p ... 2: Wolfenstein at native res on Ultra got 45~ fps, bit lower in some area,s and 60fps in other areas. That's on Ultra settings. Lower a few settings and it's near constant 60fps in that game. TF2 I play many times a week and that gets 200+ fps most of the time and 150+ all other times. native res with 4xMSAA and highest settings though Source is easy to render on any res really. Grid 2 is a constant 50fps, that game seems locked at 50Hz though for some reason at native resolution but it's so smooth it doesn't matter anyway 3: Refresh rate is a non issue really, some people say it affects their gaming online, well to that end I can only speak from my experiences with IPS screens at 60Hz and that is this: So much for input lag/low refresh rate eh :D As for your main question, can I recommend it based on price point? I don't know! It's hard to compare it against something else in this class as there is nothing else in this class yet, Rumours are Dell will release one soon or announce at least but until then there is no competition so nobody can really say it's too expensive or even too cheap. We need more time for the China clone makers to do their thing and Dell to show us what they've been working on before coming to a conclusion on this Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596432615 Share on other sites More sharing options...
Robbie Khan Reviews Posted June 3, 2014 Author Reviews Share Posted June 3, 2014 AOC have announced their new 34" Ultrawide, looks like the same LG panel too but without Thunderbolt and a hardware LUT but gaining a better stand and an additional USB3 port. http://pcmonitors.info/aoc/aoc-u3477pqu-with-3440-x-1440-resolution I expect because of that it will be quite a bit cheaper probably in the ?650 region. FiB3R 1 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596432855 Share on other sites More sharing options...
RichiDH Posted June 4, 2014 Share Posted June 4, 2014 HI nice monitor you have, im thinking to buy one too, i like also the arm for the monitor you use, is this also in the box? or is it from your self? if yes where can i buy that model? Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596433705 Share on other sites More sharing options...
RichiDH Posted June 4, 2014 Share Posted June 4, 2014 sorry i i did not see it first but already saw that you answerd someone about the arm :) if i search for that arm, it says avaidable to 30 inch monitors? do you have that one too or are there bigger ones? Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596433747 Share on other sites More sharing options...
dipsylalapo Supervisor Posted June 4, 2014 Supervisor Share Posted June 4, 2014 Great review, I'm massively in love with your setup!!! :drool: :drool: Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596433813 Share on other sites More sharing options...
Robbie Khan Reviews Posted June 4, 2014 Author Reviews Share Posted June 4, 2014 Cheers! On 04/06/2014 at 14:19, RichiDH said: sorry i i did not see it first but already saw that you answerd someone about the arm :) if i search for that arm, it says avaidable to 30 inch monitors? do you have that one too or are there bigger ones? The spec is from when teh MX first came out years ago. 30" monitors were the top dog back then and now we have bigger screens that don't weigh much more than them or in some cases less than the 30" of old. You'll be fine with the MX on a 34" screen. I've had an old Hazro on it before too and that weighed 11KG.... This LG 34" weighs less than 6KG. RichiDH 1 Share Link to comment https://www.neowin.net/forum/topic/1213797-lg-34um95-p-ultra-wide-monitor-review/#findComment-596434443 Share on other sites More sharing options...
