Biohead Posted March 23, 2016 Share Posted March 23, 2016 Does Apple list the proper technical specifications of their iPads anywhere? I'm looking for something that categorically states what the power class is of their devices but I can't find it. The closest I've come is the user manual, which says under the Bluetooth section that it has a range of about 33ft (10m). Now that suggests it's Class 2, but I need something which states it in black and white. Link to comment https://www.neowin.net/forum/topic/1292958-bluetooth-power-class-of-ipad/ Share on other sites More sharing options...
#Michael Posted March 24, 2016 Share Posted March 24, 2016 Which iPad? iPad pro: BT 4.2 iPad Air 2: BT 4.2 iPad Air: BT 4 iPad Mini 4: BT 4.2 iPad mini 3: BT 4 iPad Mini 2: BT 4 iPad Mini: BT 4 Now, BT 4 or LE BT, is still generally limited to within 30-50 feet. Link to comment https://www.neowin.net/forum/topic/1292958-bluetooth-power-class-of-ipad/#findComment-597336604 Share on other sites More sharing options...
Biohead Posted March 28, 2016 Author Share Posted March 28, 2016 No, I'm referring to the Power Class, not the version. So Class 1 devices transmit at 100mW: Class 2 at 10mW; Class 3 at 1mW. Typical ranges are 100m/10m/1m. Almost all mobile devices are Class 2, and the ipad user manual states 33ft range (10m), but I need something to prove that. Link to comment https://www.neowin.net/forum/topic/1292958-bluetooth-power-class-of-ipad/#findComment-597341762 Share on other sites More sharing options...
zhangm Supervisor Posted March 28, 2016 Supervisor Share Posted March 28, 2016 You can find it, takes a bit of searching. Here's one example: Look up the device teardown on iFixit. Find the device used for bluetooth. In the case of the iPad 4, the Bluetooth device is a Broadcom BCM4334. https://www.ifixit.com/Teardown/iPad+4+Wi-Fi+Teardown/11462 Hop over to bluetooth.org and run a search for the module. https://www.bluetooth.org/tpg/listings.cfm We pull up a match to BCM4334 here: https://www.bluetooth.org/tpg/QLI_viewQDL.cfm?qid=18552 Show the ICS details and see what's checked off. In the iPad 4, the BT module is class 1. Jim K and Biohead 2 Share Link to comment https://www.neowin.net/forum/topic/1292958-bluetooth-power-class-of-ipad/#findComment-597342534 Share on other sites More sharing options...
Jim K Global Moderator Posted March 28, 2016 Global Moderator Share Posted March 28, 2016 On 28/03/2016 at 23:15, zhangm said: You can find it, takes a bit of searching. Here's one example: Look up the device teardown on iFixit. Find the device used for bluetooth. In the case of the iPad 4, the Bluetooth device is a Broadcom BCM4334. https://www.ifixit.com/Teardown/iPad+4+Wi-Fi+Teardown/11462 Hop over to bluetooth.org and run a search for the module. https://www.bluetooth.org/tpg/listings.cfm We pull up a match to BCM4334 here: https://www.bluetooth.org/tpg/QLI_viewQDL.cfm?qid=18552 Show the ICS details and see what's checked off. In the iPad 4, the BT module is class 1. Expand wow...that is pretty cool. I would have said class 2...but been el incorrecto per that spec sheet. Link to comment https://www.neowin.net/forum/topic/1292958-bluetooth-power-class-of-ipad/#findComment-597342556 Share on other sites More sharing options...
TAZMINATOR Posted March 28, 2016 Share Posted March 28, 2016 On 24/03/2016 at 17:50, #Michael said: Now, BT 4 or LE BT, is still generally limited to within 30-50 feet. Expand FYI, if you have Apple Watch and iPhone, then it could be around 350 ft between those devices. Link to comment https://www.neowin.net/forum/topic/1292958-bluetooth-power-class-of-ipad/#findComment-597342570 Share on other sites More sharing options...
