djrobmac Posted November 16, 2006 Share Posted November 16, 2006 Can anyone please please help me. On my XP machine i had to change the MTU settings to 1400 using Dr TCP before i could access everything. Ive learnt that this is not possible with Vista!!! What am i supposed to do. There are loads of websites i cant access like hotmail for example. Ive changed the MTU on the Belkin Router but vista seems to force the MTU to 1478 Please help. Link to comment https://www.neowin.net/forum/topic/513040-change-mtu-settings-help/ Share on other sites More sharing options...
MistaJista Posted November 16, 2006 Share Posted November 16, 2006 open a command prompt and type >netsh interface ipv4 set subinterface "Local Area Connection" mtu=WHATEVER store=persistent obviously entering a number for mtu. In your case mtu=1400 also if you've renamed your NIC from default then use that name between the inverted commas as opposed to Local Area Connection. oh and you probably need to reboot afterward. Link to comment https://www.neowin.net/forum/topic/513040-change-mtu-settings-help/#findComment-588053291 Share on other sites More sharing options...
djrobmac Posted November 16, 2006 Author Share Posted November 16, 2006 MistaJista said: open a command prompt and type >netsh interface ipv4 set subinterface "Local Area Connection" mtu=WHATEVER store=persistent obviously entering a number for mtu. In your case mtu=1400 also if you've renamed your NIC from default then use that name between the inverted commas as opposed to Local Area Connection. oh and you probably need to reboot afterward. Thankyou so much for your speedy reply! Sadly it doesnt work :( using http://www.speedguide.net/analyzer.php it still says MTU = 1478 Link to comment https://www.neowin.net/forum/topic/513040-change-mtu-settings-help/#findComment-588053366 Share on other sites More sharing options...
MistaJista Posted November 16, 2006 Share Posted November 16, 2006 (edited) djrobmac said: Thankyou so much for your speedy reply! Sadly it doesnt work :( using http://www.speedguide.net/analyzer.php it still says MTU = 1478 I just changed mine again and went to to site you posted and it definately works Can you type exactly what you entered in the command prompt for me to have a look at.... PS typing netsh interface ipv4 show subinterfaces will tell you what your NICs are currently set to. Edited November 16, 2006 by MistaJista Link to comment https://www.neowin.net/forum/topic/513040-change-mtu-settings-help/#findComment-588053407 Share on other sites More sharing options...
djrobmac Posted November 16, 2006 Author Share Posted November 16, 2006 MistaJista said: I just changed mine again and went to to site you posted and it definately works Can you type exactly what you entered in the command prompt for me to have a look at.... PS typing netsh interface ipv4 show subinterfaces will tell you what your NICs are currently set to. To say you're a genius is an understatement!! When you open the command prompt from the accessories menu you must right click and chose "run as administrator" otherwise it wont apply. THANKYOU THANKYOU THANKYOU THANKYOU all sites are now working :) THANKYOU! Link to comment https://www.neowin.net/forum/topic/513040-change-mtu-settings-help/#findComment-588053493 Share on other sites More sharing options...
MistaJista Posted November 16, 2006 Share Posted November 16, 2006 can't take credit.... just something I read somewhere else.... I have text files with all these little tips as I can't remember this stuff for s**t! lol Link to comment https://www.neowin.net/forum/topic/513040-change-mtu-settings-help/#findComment-588053511 Share on other sites More sharing options...
