[JAVA] Runtime.getRuntime().exec() help
Hey, i'm writing a simple program that uses a JFileChooser to select a .java file, copies it to the C:/java directory, then compiles it into a .jar file. I'm having problems launching command.bat and running the commands. My code currently looks like: (My mainClass.txt is already in the target directory)
import javax.swing.JFileChooser;
import javax.swing.*;
import java.awt.event.*;
import java.awt.*;
import java.util.*;
import java.io.*;
public class JavaCompile {
	private String[] cmd;
	private String name;
	private JFileChooser fc;
	private File fin;
	private String path;
	public static void main(String[] args){
		JavaCompile jc = new JavaCompile();
	public JavaCompile(){
		fc = new JFileChooser();
		fin=null;
		if(fc.showOpenDialog(null) == JFileChooser.APPROVE_OPTION) {
			 fin = fc.getSelectedFile();
			 name = fin.getName();
			 path = fin.getAbsolutePath();
		cmd = new String[7];
		cmd[0] = "command.com";
		cmd[1] = "/C";
		cmd[2] = "set PATH=C:\\Program Files\\Java\\jdk1.6.0_04\bin";
		cmd[3] = "cp "+path+"\\name"+ " C:\\java";
		cmd[4] = "cd C:\\java";
		cmd[5] = "javac *.java";
		cmd[6] = "jar cmf mainClass.txt"+" name"+".jar *.class";
		try{
		Runtime.getRuntime().exec(cmd);
		catch(Exception e){
			System.out.println("Error		}
https://www.neowin.net/forum/topic/620450-java-runtimegetruntimeexec-help/
14 answers to this question
  night_stalker_z said:
What sort of problems are you getting. It might be a limitation of the command prompt.
When i run it, my try catch block goes off and prints "Error".
None of the files get moved to the hoped for directory and i never see command.com open, though it may be too fast.
You might need to change this line
make sure its got quotes around it if the path contains spaces.
And in your catch block, print e.getMessage(); as thats more descriptive.
I'll try this and report back soon. Thanks :D
Wait, gotta ask a stupid question, I'm assuming you're trying to run a copy command to copy the file to a certain location and then compile it? (that's how I read it)
Do you not want:
cmd[3] = "copy "+path+"\\name"+ " C:\\java";
as "cp" isn't a valid Command Prompt command, but a Unix command for copy?
Sorry if I'm missing the obvious!
Do you not want:
Way to make me feel moronic XD Good catch! This is my code now, which runs fine but does nothing :( . doesnt even spit errors. Help?
import java.awt.*;
import java.util.*;
import java.io.*;
	private File fin;
		fin=null;
		cmd[0] = "cmd";
		cmd[1] = "/C";
		cmd[3] = "copy " + "\"" +path + "\\" +name+ "\"" + " C:\\java";
		cmd[4] = "chdir C:\\java";
		try{
		System.out.println("runningands");
		catch(Exception e){
			System.out.println(e.getMessage());
			System.out.println("runningands2");
		System.out.println("runningands3");
Maybe i have to use Canonical file paths? I'm not sure of the difference.
Edited by Mortiferous
  _kane81 said:
you should really use a platform independent soluion
http://www.java2s.com/Code/Java/File-Input...ngJavaIOAPI.htm
or here
http://forum.java.sun.com/thread.jspa?thre...ssageID=3841126
they have an example of using cmd too
Indeed, there's native Java solutions for doing this, so why would you want to execute a shell command? Even easier than what was in that first link is the Commons VFS API: http://commons.apache.org/vfs/
FileSystemManager fsManager = VFS.getManager();
FileObject origFile = fsManager.resolveFile("originalFile");
FileObject newFile = fsManager.resolveFile("newFile");
/*Possibly any checks here on both files, or just stick in a try/catch as the next function will throw an exception if it can't do anything*/
origFile.moveTo(newFile);
/*Or just copy:*/
newFile.copyFrom(origFile,new AllFileSelector());
Note this will work on files or directories.
Edited by kjordan2001
/*Or just copy:*/
A Little over my head, but if i did get that to work, ide still be stuck on how to run javac to compile it to a jar.
Bump. Anyone know of a way to do this by calling the command prompt? I cont care to make this platform independent, because its for personal use mostly. I've decided that instead of trying to copy the file, i'll just use a printWriter to do the same thing, that part of my code works. My Current code looks like:
import java.awt.*;
import java.util.*;
import java.io.*;
	//fields
	private File fin;
	private File fout;
	private String pathtest;
	private Scanner in;
	private PrintWriter print;
	//Main Method
	//Constructor
		//initialize fields
		fin=null;
		fout = null;
		print = null;
		in = null;
		//Select the File to copy
			 try{
			 pathtest = fin.getCanonicalPath();
			 }catch(Exception e){
		//select where to copy the file, then copy it.
			  fout = fc.getSelectedFile();
		  try {
			in = new Scanner(fin);
			print = new PrintWriter(fout);
			while (in.hasNextLine()) {
				String s = in.nextLine();
						print.println(s);
			in.close();
			print.close();
		 } catch (Exception e) {
			 System.out.println("Errorrated by print writer:");
		//Creates list of commands to call
		cmd = new String[6];
		cmd[0] = "cmd.exe";
		cmd[1] = "/c";
		cmd[2] = "chdir";
		cmd[3] = "C:\\Program Files\\Java\\jdk1.6.0_04\\bin";
		cmd[4] = "javac";
		cmd[5] = "C:\\java\\Calculator.java";
		try{
		catch(Exception e){
Ah, you also might look into ant or maven for this kind of thing (automated build systems). I've seen hibernate put up a JWindow while compiling, so it may also be likely to be able to put up a JFileChooser, but more than likely it would be easier to just copy the build.xml into each project you want to build and you can build it generically enough with wildcards that it'll compile any java source.
Another option is an IDE like eclipse where it'll automatically compile once you save it and it has an export to jar option.
Hi Mortiferous,
Any updates on Runexec....
I have a similar issue wherein I am trying to compile a java file by invoking command prompt...But it does not work
I tried out two different options:
Option 1
Runtime rt = Runtime.getRuntime();
Process proc = rt.exec("cmd.exeet classpath=%classpath%;Y:\\applications\\maximo\\businessobjects\\classes;Y:\\applications\\maximo\\maximouiweb\\webmodule\\WEB-INF\\classes");
proc = rt.exec("cmd.exeet path=%path%;C:\\bea\\jdk142_05\\bin;.");
proc = rt.exec("cmd.exec Y:\\applications\\maximo\\businessobjects\\classes\\psdi\\MXIDE\\WOExt.java");
InputStream stderr = proc.getErrorStream();
InputStreamReader isr = new InputStreamReader(stderr);
BufferedReader br = new BufferedReader(isr);
String line = null;
while ((line = br.readLine())!= null)
System.out.println(line);
int exitval = proc.waitFor();
System.out.println ("Process Exit Value:" + exitval);
Option 2:
String[] cmd;
cmd = new String[8];
cmd[0] = "cmd.exe";
cmd[1] = "/c";
cmd[2] = "set";
cmd[3] = "PATH=%PATH%;C:\\bea\\jdk142_05\\bin";
cmd[4] = "set";
cmd[5] = "classpath=%classpath%;Y:\\applications\\maximo\\businessobjects\\classes;Y:\\applications\\maximo\\maximouiweb\\webmodule\\WEB-INF\\classes";
cmd[6] = "javac";
cmd[7]= "Y:\\applications\\maximo\\businessobjects\\classes\\psdi\\MXIDE\\WOExt.java";
Process proc = rt.exec(cmd);
String line = null;
When I run option-1 the classpath is not getting set properly and on running javac, it is throwing unreferenced errors on imported class files. When I run option-2, it does not throw any error...But nothing happens. The program returns an exitvalue of 0, but still the class file does not get created....
Any suggestions will be greatly appreciated!!
