ZTE has been fairly active this year, offering several handsets that are both sleek and affordable. At the end of the month, the firm will add another device to its robust lineup with the Blade Z Max.
The Blade Z Max will arrive for MetroPCS and will feature:
- 6-inch 1080p display
- Qualcomm Snapdragon 425
- 2GB RAM
- 16MP and 2MP rear camera with an 8MP front-facing camera
- 32GB internal storage with microSD support
- 4,080mAh battery
- Qualcomm Quick Charge 2.0
- Fingerprint Sensor
While it might not be the most intense set of specifications, the smartphone should be a great entry-level model. The handset will arrive on August 28 and will be priced at a very affordable $129. If interested, you"ll probably want to pre-register for the smartphone before August 27, as this will allow you to take advantage of the $25 promotional Google Play Store credit that is being offered to purchasers. Those that purchase the Blade Z Max by September 26 will be eligible for the credit through an online claim portal.
Source: BusinessWire via Android Authority
