netsurfer802 Posted August 27, 2011 Share Posted August 27, 2011 I recently downloaded Netstumbler on my Windows 7 system and it's saying it's not compatible with the Netgear WNA1100 (N150 Wireless USB Adapter)...is there a program that does the same thing that is compatible with this device or is there a way to make it compatible ...thanks in advanced for any helpful response. Link to comment https://www.neowin.net/forum/topic/1021432-device-not-compatible-wtih-netstumbler/ Share on other sites More sharing options...
sc302 Veteran Posted August 27, 2011 Veteran Share Posted August 27, 2011 http://www.kismetwireless.net/ Link to comment https://www.neowin.net/forum/topic/1021432-device-not-compatible-wtih-netstumbler/#findComment-594265972 Share on other sites More sharing options...
netsurfer802 Posted August 28, 2011 Author Share Posted August 28, 2011 I couldn't figure out how the first program shows SSIDs...as for Kismetwireless...can it work with Windows 7? Link to comment https://www.neowin.net/forum/topic/1021432-device-not-compatible-wtih-netstumbler/#findComment-594266794 Share on other sites More sharing options...
+John Teacake MVC Posted August 28, 2011 MVC Share Posted August 28, 2011 Theres definitely something much better on here http://www.nirsoft.net/ Netstumbler has not been updated for years! http://www.nirsoft.net/utils/wireless_network_view.html Link to comment https://www.neowin.net/forum/topic/1021432-device-not-compatible-wtih-netstumbler/#findComment-594267016 Share on other sites More sharing options...
+BudMan MVC Posted August 28, 2011 MVC Share Posted August 28, 2011 Yeah check out http://www.metageek.net/products/inssider/ netstumbler has not been updated for quite some time. Link to comment https://www.neowin.net/forum/topic/1021432-device-not-compatible-wtih-netstumbler/#findComment-594267122 Share on other sites More sharing options...
