the big dill Posted September 4, 2011 Share Posted September 4, 2011 Hello Neowin! My sisters Hamster got away a few days ago and chewed through a hard to replace cable... :( I was wondering if anyone could assist me in which direction to go in terms of replacing this cable? Cheers, Phil. Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/ Share on other sites More sharing options...
rajputwarrior Posted September 4, 2011 Share Posted September 4, 2011 call logitech. they'll have them for sure. how much they charge i have no idea. Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594283228 Share on other sites More sharing options...
Arkos Reed Posted September 4, 2011 Share Posted September 4, 2011 hmmmm tasty.... the hamster of course :devil: Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594283232 Share on other sites More sharing options...
hjf288 Posted September 4, 2011 Share Posted September 4, 2011 They don't do spare control pods.. I'd recommend sourcing a replacement or splicing the cable and attaching new wire then heat shrink it Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594283240 Share on other sites More sharing options...
rajputwarrior Posted September 4, 2011 Share Posted September 4, 2011 They don't do spare control pods.. I'd recommend sourcing a replacement or splicing the cable and attaching new wire then heat shrink it yes they do. the analog cables on my set went and they said all they could do is send me a spare control pod... call them. Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594283242 Share on other sites More sharing options...
hjf288 Posted September 4, 2011 Share Posted September 4, 2011 I have 3 times and they said they don't supply them... Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594283244 Share on other sites More sharing options...
Harsesis Posted September 4, 2011 Share Posted September 4, 2011 http://forums.logitech.com/t5/Speakers/Out-of-warranty-Z-5500-replacement-control-pod-Help/td-p/235984 Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594283260 Share on other sites More sharing options...
the big dill Posted September 5, 2011 Author Share Posted September 5, 2011 I have 3 times and they said they don't supply them... Yep, they said they don't repair them... told me to get in contact with a local audio shop for repairs :\ The first response i get charges $45 for an estimate :no: Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594285114 Share on other sites More sharing options...
the big dill Posted September 24, 2011 Author Share Posted September 24, 2011 So i took matter into my own hands and... A good 5 hours and it works :D Cheers, Phil. Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-594334646 Share on other sites More sharing options...
SpeakerMan Posted February 15, 2019 Share Posted February 15, 2019 Similar problem here... Trusty faithful Z500 unit playing up and isolated to control cable. It's like $500 or so to upgrade to a unit that is as good or better. What a waste of money. So I am wondering if I can just repair this control cable. Any ideas please. The images above don't work (cannot be found). So I am hoping I can just splice the cable on to a new connector. Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-598418764 Share on other sites More sharing options...
Jim K Global Moderator Posted February 15, 2019 Global Moderator Share Posted February 15, 2019 Please don't resurrect old threads from the grave. Feel free to start a new topic with respect to your question. //locked Link to comment https://www.neowin.net/forum/topic/1023102-z-5500-control-pod-wire-damaged/#findComment-598418768 Share on other sites More sharing options...
