I?ve purchased a used Dell 2209WA monitor off of eBay, and despite the seller stating it came with all cables, the DVI cable is missing. So which cable do I need to purchase, as there?s a DVI-D connector on the monitor and a DVI-I connector on the graphics card?
Both connectors look similar, with a grid of 24 female pin holes, but the DVI-D has an additional single slot (like a minus sign), where as the DVI-I has a plus sign with 4 pin holes within it.
Am I fussing too much, will any DVI cable connect both?
A DVI-D cable is what you need. DVI-I includes both digital and analog signals (the analog signals are on the additional pins). The single blade (minus) of the DVI-D cable will plug into the + part of the DVI-I socket.
  • Like 1
  On 07/04/2012 at 20:46, HawkMan said:
Just get a standard DVD cable.
Also he was probably right, the monitor most likely didn't come with a dvi cable to start with.
  On 07/04/2012 at 20:49, Tony. said:
Any standard DVI cable will be fine. Some DVI ports can carry audio signals that's why they sometimes vary.
And what exactly is a "standard DVI cable"? If OP buys a DVI-I cable he will be SOL since it won't fit into the monitor socket. Happened to me once, I figured any DVI cable would do, then realized DVI-I didn't fit into the monitor.
  • Like 1
Thanks for all the advice. :)
According to the Dell owners sheet, a DVI cable was included.
One other thing: been using the 2209WA for a few days now with a VGA cable, but the onscreen colours are washed out, photos being particually bad. Tried adjusting brightness/contrast, but still the same. I'm reluctant to play with the colour balance before I've got the new cable. Do you think the that washed out look might be mostly down to the VGA cable? The 2209WA owners sheet suggests you get better picture quality from the DVI cable.
