internet explorer problem
when I click on a hyperlink, I do not get the"File Download dialog" at all.
Instead the download is automatically saved in "temporary interent files" folder.
I have provided a screenshot of internet explorer which illustrates
what happens when i try to download a file.
I do not want to reinstall ie6sp1 so i'm searching for a possible solution.
I checked for corrupted system files and I use windowsupdate regularly.
https://www.neowin.net/forum/topic/107093-internet-explorer-problem/
suggestions
1. Tools > Internet Options > Security > Default Level. also do this with Advanced > Restore Degault
2. try right clicking on a link and click "Save target as". what happens?
i'll try get more information.
You have to mess with the file types.. I am guessing it a checkmark was selected to auto download the file, so go to tools >> folder options >> file types and whatever the file ended with .exe or whatever go to it and look through probably in advanced and uncheck auto start downloads.
(hope that's it)
I found a solution to this problem. I opened regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Plugins\Extension
The Extension key had some "string values" that probably should not be there
which is wierd since I don't use download mangers.
Anyway, when I deleted them, "File Download dialog" and downloading worked again .
I just wish I thought of this solution two months ago.
I've been downloading using mozilla firebird for the last two months. :blush:
At least now I can go back to using internet explorer.
