Deep_Level_Shark Posted May 26, 2012 Share Posted May 26, 2012 How do I check if my wireless repeater is working or not ? I'm using ASUS WL-330N3G in Repeater mode. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/ Share on other sites More sharing options...
remixedcat Posted May 26, 2012 Share Posted May 26, 2012 use wireless with and then without it.... Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889201 Share on other sites More sharing options...
Deep_Level_Shark Posted May 26, 2012 Author Share Posted May 26, 2012 On 26/05/2012 at 04:37, remixedcat said: use wireless with and then without it.... Is there any software which could show the signal strength % ? . Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889205 Share on other sites More sharing options...
redvamp128 Posted May 26, 2012 Share Posted May 26, 2012 Tracert ?? Should show up as a link in-between you and the router... just a thought..(not quite 100% sure it would show up but worth a try) also like suggested go far away from your router.. then switch off the repeater go to the point at which you loose original signal.. then switch the repeater back on-- you should notice the signal come back.. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889209 Share on other sites More sharing options...
dafin0 Posted May 26, 2012 Share Posted May 26, 2012 On 26/05/2012 at 04:42, Deep_Level_Shark said: Is there any software which could show the signal strength % ? . this is a handy tool for testing wireless http://www.metageek.net/products/inssider/. hope this helps Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889211 Share on other sites More sharing options...
Deep_Level_Shark Posted May 26, 2012 Author Share Posted May 26, 2012 On 26/05/2012 at 04:53, redvamp128 said: Tracert ?? Is their website under maintenance ? Or I'm looking at a wrong url. Could you please post download link Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889213 Share on other sites More sharing options...
redvamp128 Posted May 26, 2012 Share Posted May 26, 2012 On 26/05/2012 at 04:59, Deep_Level_Shark said: Is their website under maintenance ? Or I'm looking at a wrong url. Could you please post download link LOL-- Tracert means traceroute from command prompt.. http://www.mediacoll...traceroute.html from the command prompt.... tracert www.google.com [/CODE] You may want to elevate it to administrator ... Sometimes depending on the repeater model you may see two of your routers listed as being in the route.. to the traced website. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889215 Share on other sites More sharing options...
Deep_Level_Shark Posted May 26, 2012 Author Share Posted May 26, 2012 On 26/05/2012 at 04:54, dafin0 said: this is a handy tool for testing wireless http://www.metageek....ducts/inssider/. hope this helps I used this tool and run this ... I get this report I dont understand those data in snapshot. I am using D-Link Router and ASUS reapeter . Could you please tell if my ASUS Reapeter is working OK ? Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889217 Share on other sites More sharing options...
dafin0 Posted May 26, 2012 Share Posted May 26, 2012 On 26/05/2012 at 05:05, Deep_Level_Shark said: I used this tool and run this ... I get this report I dont understand those data in snapshot. I am using D-Link Router and ASUS reapeter . Could you please tell if my ASUS Reapeter is working OK ? so from what i understand you are getting a slightly better connection with the Asus repeater. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889253 Share on other sites More sharing options...
+BudMan MVC Posted May 26, 2012 MVC Share Posted May 26, 2012 -70 still a pretty crappy signal -- how far away from devices are you? Across the street? What do you mean by working? What that you can connect to it? That your connecting to it vs the router? See how its highlighted a bit brighter, that means your connected to it. Does it cut your speed in half -- then your connected to the repeater ;) If you want to have better wireless coverage and speed - then run a wire from your router to where you need coverage and use the wireless router/repeater as AcessPoint! You will then get full wireless speed to it, vs half because its wireless connected to your first router. Repeat as many times as you need to provide full wireless coverage for your area with the strength you want. I am really curious how far away your repeater is if your seeing -70, and where is your actual router? **** my wireless interface is in my metal case of my computer - with NO antenna attached, and is under my very heavy wood oak desk, and I still get better than -84 to routers somewhere down the block from me! See those 2 with better than your 84, they are somewhere in the neighborhood. If inssider is showing you the signal in Red and Orange, etc.. Not a very good signal ;) edit: Ok I connected my ALFA usb card, its got an antenna on it and on top of my desk. Look at the jump in signal from some wireless network in the neighborhood -- its now at -67 which is better than your repeater signal.. Where are you at in relation to this repeater? What kind of wireless interface are you using - is it built into your laptop? Usb? What Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889441 Share on other sites More sharing options...
sc302 Veteran Posted May 26, 2012 Veteran Share Posted May 26, 2012 tracert isn't going to show you what you want, it only shows you who/how many people is/are connected to google at any particular time. nextgenhacker101 says so. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889467 Share on other sites More sharing options...
+BudMan MVC Posted May 26, 2012 MVC Share Posted May 26, 2012 ^ yup that is correct, tracert is used to show how many users are connected to any site, and what their speeds and IPs are... You have to watch this if you have not seen it!! And keep in mind the ones you can not see are because your connection is not as good as theres!! Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889473 Share on other sites More sharing options...
remixedcat Posted May 26, 2012 Share Posted May 26, 2012 also try out the amped wireless android app for a mobile device to see how the strength is for the mobile device as well Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889591 Share on other sites More sharing options...
Intersect Posted May 26, 2012 Share Posted May 26, 2012 On 26/05/2012 at 12:41, BudMan said: ^ yup that is correct, tracert is used to show how many users are connected to any site, and what their speeds and IPs are... You have to watch this if you have not seen it!! And keep in mind the ones you can not see are because your connection is not as good as theres!! i can sleep soundly at night knowing he is l33t with tracert. i just hope he dosnt discover how to use ping. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889623 Share on other sites More sharing options...
sc302 Veteran Posted May 26, 2012 Veteran Share Posted May 26, 2012 Nm. Before I get pinged for lack of help. Carry on with a serious discussion. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889641 Share on other sites More sharing options...
remixedcat Posted May 26, 2012 Share Posted May 26, 2012 what did you say!!!!???? Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889649 Share on other sites More sharing options...
sc302 Veteran Posted May 26, 2012 Veteran Share Posted May 26, 2012 It was a Pftc Bad interweb humor in a serious topic...if you didn't get emailed with it then don't worry about it. It wasn't warwagon bad, but it was bad. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889669 Share on other sites More sharing options...
redvamp128 Posted May 26, 2012 Share Posted May 26, 2012 On 26/05/2012 at 12:30, sc302 said: tracert isn't going to show you what you want, it only shows you who/how many people is/are connected to google at any particular time. nextgenhacker101 says so. Actually-- depending on the Repeater.... The repeater will echo the router and show up twice in a trace.... ....Read what I wrote... The one I have now without the repeater on it shows my router once in the trace... with the repeater on the router shows up twice..... And Yes I know what you are saying, but when a repeater is used it will show up twice in a trace route... (because in essence it goes through the router twice) You know the hand off from the repeater back to the router....... basically what happens-- without a repeater.... Your computer says -- go to google.com- router says router here -- go to google.com With the repeater your computer says - go to google.com - repeater says router here- relay to router - go to google.com to router- go to google.com when it relays that signal it shows up as two router connections That and in the troubleshooting part of my repeater manual it says run Tracert to diagnose connection issue to router..It says should show as two of the same connection if working. If it does not show up twice the routers connection then it is not working and to reset it and reprogram it. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889687 Share on other sites More sharing options...
sc302 Veteran Posted May 26, 2012 Veteran Share Posted May 26, 2012 But that is the wrong way to troubleshoot wireless. How budman is going about it is the proper way. You need to see signal strength, not reply times. While it helps somewhat, it doesn't do squat for you. It doesn't tell you if you are covered enough, it doesn't tell you which ap you are connecting to, the only thing it does is tell you ping/response times. True it may show you you are connected to a repeater, but if you want to know if you are properly saturated a tracert isn't going to give you that information....you need to look deeper. That is the difference between book smarts and experience. A book isn't going to tell you to do something else when it is wrong. remixedcat 1 Share Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889695 Share on other sites More sharing options...
redvamp128 Posted May 26, 2012 Share Posted May 26, 2012 On 26/05/2012 at 15:53, sc302 said: But that is the wrong way to troubleshoot wireless. How budman is going about it is the proper way. You need to see signal strength, not reply times. While it helps somewhat, it doesn't do squat for you. It doesn't tell you if you are covered enough, it doesn't tell you which ap you are connecting to, the only thing it does is tell you ping/response times. True it may show you you are connected to a repeater, but if you want to know if you are properly saturated a tracert isn't going to give you that information....you need to look deeper. You are telling me the manual is wrong?? He only asked was it working>? I understand you are talking about signal strength , but this is step one of the troubleshooting guide in my manual for my repeater. That and it also suggests setting the repeater to a different ip address then re run the tracert . To see if there is a large delay between the handoff times. Quoting the book... And I was just using google.com as an example-- for this example he should use the IP of his router.. to see if it shows up twice.. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889705 Share on other sites More sharing options...
sc302 Veteran Posted May 26, 2012 Veteran Share Posted May 26, 2012 Yes, yes it is. It isn't working properly. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594889709 Share on other sites More sharing options...
remixedcat Posted May 26, 2012 Share Posted May 26, 2012 Also you must have the repeater at least in an area where you get more then 60% sig str. from the wireless router or AP. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594890197 Share on other sites More sharing options...
+BudMan MVC Posted May 27, 2012 MVC Share Posted May 27, 2012 "The repeater will echo the router and show up twice in a trace" Where does it say that?? If you are double natting or actually routing you would see different IP in the hop, but you should not see duplicate of your gateway?? That is what would happen if you had a double nat setup with same IP address on both sides of the nat. But wireless is a bridge and the repeater is not your gateway - its just repeating the wireless connection. You should never actually land on the repeater for it to show up in a hop. The IP address of the repeater would be a different IP than your gateway as well, so why should it show the gateway IP twice? Please provide source to this manual, what is the make and model number of your device and what mode do you have it in? If you are seeing your router IP twice in a tracert to google, your not really in wireless repeater or bridge mode or WDS type setup. What is the IP address of your "repeater" ? So when your network traffic be it wireless or wired transverses a bridge, do you see this as a hop? No -- so why should you be seeing your gateway IP twice? Really curious to how your setup if this is the case! Think of it this way -- do you see the IP address your AccessPoint when it is connected to your wired network. Then why should you see your gateway address repeated twice when you go through another bridge that just repeats the wireless signal to another AP? If you want to know what wireless AP your connected to then you would look in your supplicant and it will show you the MAC address of the wireless radio your associated too. The wireless router/ap/repeater/etc. Now the gui one that comes with w7 is pretty limited, but you can get that info from cmd line with netsh netsh>wlan netsh wlan>show all Wireless System Information Summary (Time: 5/27/2012 6:05:55 AM Central Daylight Time) <snipped> ======================================================================= ============================= SHOW INTERFACES ========================= ======================================================================= There is 1 interface on the system: Name : Wireless Network Connection Description : DW1501 Wireless-N WLAN Half-Mini Card GUID : 737d5c79-2b15-4e24-87cf-6d4afff1c9db Physical address : 38:59:f9:5f:63:c1 State : connected SSID : snipped BSSID : 00:13:10:<snipped> Network type : Infrastructure Radio type : 802.11g Authentication : WPA2-Personal Cipher : CCMP Connection mode : Auto Connect Channel : 1 Receive rate (Mbps) : 54 Transmit rate (Mbps) : 54 Signal : 96% Profile : snipped Hosted network status : Not available See the BSSID, that is the MAC of the radio your connected too. Now I have snipped the SSID and part of the mac, because there are databases created from wardriving info that you can look up that stuff, and could point you pretty much right to my house. So its a privacy thing. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594890919 Share on other sites More sharing options...
redvamp128 Posted May 29, 2012 Share Posted May 29, 2012 On 27/05/2012 at 10:37, BudMan said: "The repeater will echo the router and show up twice in a trace" Where does it say that?? If you are double natting or actually routing you would see different IP in the hop, but you should not see duplicate of your gateway?? That is what would happen if you had a double nat setup with same IP address on both sides of the nat. But wireless is a bridge and the repeater is not your gateway - its just repeating the wireless connection. You should never actually land on the repeater for it to show up in a hop. The IP address of the repeater would be a different IP than your gateway as well, so why should it show the gateway IP twice? Please provide source to this manual, what is the make and model number of your device and what mode do you have it in? If you are seeing your router IP twice in a tracert to google, your not really in wireless repeater or bridge mode or WDS type setup. What is the IP address of your "repeater" ? So when your network traffic be it wireless or wired transverses a bridge, do you see this as a hop? No -- so why should you be seeing your gateway IP twice? Really curious to how your setup if this is the case! Think of it this way -- do you see the IP address your AccessPoint when it is connected to your wired network. Then why should you see your gateway address repeated twice when you go through another bridge that just repeats the wireless signal to another AP? If you want to know what wireless AP your connected to then you would look in your supplicant and it will show you the MAC address of the wireless radio your associated too. The wireless router/ap/repeater/etc. Now the gui one that comes with w7 is pretty limited, but you can get that info from cmd line with netsh netsh>wlannetsh wlan>show allWireless System Information Summary(Time: 5/27/2012 6:05:55 AM Central Daylight Time)<snipped>==================================================================================================== SHOW INTERFACES ================================================================================================There is 1 interface on the system: Name : Wireless Network Connection Description : DW1501 Wireless-N WLAN Half-Mini Card GUID : 737d5c79-2b15-4e24-87cf-6d4afff1c9db Physical address : 38:59:f9:5f:63:c1 State : connected SSID : snipped BSSID : 00:13:10:<snipped> Network type : Infrastructure Radio type : 802.11g Authentication : WPA2-Personal Cipher : CCMP Connection mode : Auto Connect Channel : 1 Receive rate (Mbps) : 54 Transmit rate (Mbps) : 54 Signal : 96% Profile : snipped Hosted network status : Not available See the BSSID, that is the MAC of the radio your connected too. Now I have snipped the SSID and part of the mac, because there are databases created from wardriving info that you can look up that stuff, and could point you pretty much right to my house. So its a privacy thing. Sorry that was a mistype-- It says the router will "echo in repeater mode" in a tracert and shows up as a connection (hop) between the router to see if it is working.. and a I use Lynksis router in repeater mode. (two of the same model) There is a setting to enable specify IP address as well. To make for easier diagnosis. I am guessing that by ECHO they mean respond back in a tracert. And that it is counting it and the router. Which in my case is two routers but I figured with a simple repeater it would show up as "hop" as well. What I meant is that there should be two hops between you and the router. Sorry for the confusion it says that it does show up in a tracert and says to use the ttl's to see if connection issues exist. It also has troubleshooter that suggests things to try with the repeater , such as changing its radio from 54,000 to 72000 or 150,000 (Wireless Bands Is the settings in the router to just use N or A-B) and or the changing channel to other channels to reduce interference. When I run Tracert there is two three hops between me and my internet... Me to "Router in Repeater mode" The router that is being repeated The Cable Modem (next hop is the internet) The manual is not exactly the best at explaining but for me -- With my other router setup in repeater mode it shows up as hop . (the repeater itself with a different Mac address) Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594895165 Share on other sites More sharing options...
+BudMan MVC Posted May 29, 2012 MVC Share Posted May 29, 2012 A cable "modem" does not show up in a traceroute - its not a modem if it does, its a GATEWAY (modem/router combo) What is the model of the devices you are using? From what you have stated, I would assume your doing at min a double nat, if not a triple? Why would anyone want 3 hops before they even hit the ISP router? Here is trace to google, there is router in there the 192.168.1.253 address and even if wireless which is at 192.168.1.252 (you would never see this as a hop) Unless you were routing the traffic -- why would you want to run through 3 different segments before you even hit your isp? Even if no nat involved until the last router before you isp. Can you please provide the make and model numbers of all of your devices so I can read the manual and see how you have it configured - I would guess from 3 hops you don't have it configured in a optimal fashion. If your cable "modem" is a hop - why do you even have a router? Why don't you just use the "modem" that is the border between your private network and the public internet to control access? When you say lynksis -- do you mean linksys? Here is a trace from a wireless device through my AP, My router and my cable modem! traceroute www.google.com traceroute to www.google.com (74.125.225.209), 30 hops max, 60 byte packets 1 pfsense.local.lan (192.168.1.253) 2.159 ms 2.495 ms 2.453 ms 2 c-24-13-xx-xx.hsd1.il.comcast.net (24.13.xx.xx) 11.791 ms 18.604 ms 32.163 ms 3 te-1-2-ur08.mtprospect.il.chicago.comcast.net (68.85.131.153) 19.468 ms 19.426 ms 20.286 ms <snipped> So I snipped out the rest of that, and snipped the last couple of octets off my ISP gateway, no reason to give you the network I am on. You can see pfsense is my router. What you don't see is the SB6120 Motorola cable modem that is between my router and the isp. Nor do you see the AP that has an ip of 192.168.1.252 on my network that the traffic flows through as well. Even if I had a reason to repeat that wireless signal - because I could not run a wire to the AP to extend my wireless network. For example like this You would not see those devices in the trace, even if there were multiples of them chained out.. Just your wireless speed would be cut in half for every repeat. Link to comment https://www.neowin.net/forum/topic/1079845-how-do-i-check-if-my-wireless-repeater-is-working-or-not/#findComment-594895297 Share on other sites More sharing options...
