rpG Posted October 16, 2003 Share Posted October 16, 2003 I have included an image of my problem. The theme I am using is "Luna Reborn v1" by unique, but this problem is persistent among most thin-taskbar themes I try to use, for example the "teknision" theme. The thing is, when I install a thin-taskbar theme, I want the taskbar to be thin, but as you can see, on my PC, the taskbar is still not "thin". It's not too easy to explain, so I hope the picture will suffice. Can anyone help? Thanks in advance. Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/ Share on other sites More sharing options...
devBrian Posted October 16, 2003 Share Posted October 16, 2003 Hum... lock the taskbar? I think that's whats happening there... rightclick the taskbar and click "Lock the Taskbar" Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1264694 Share on other sites More sharing options...
rpG Posted October 17, 2003 Author Share Posted October 17, 2003 Well, I've locked it, still the same. Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1264705 Share on other sites More sharing options...
rpG Posted October 17, 2003 Author Share Posted October 17, 2003 Did I post this topic in the wrong forum? Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1268134 Share on other sites More sharing options...
Hypoxiaicon Posted October 17, 2003 Share Posted October 17, 2003 lol. put your start bar across the bottom and see if you have the same problem (unless it is, just pic look like its across the top) Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1268153 Share on other sites More sharing options...
rpG Posted October 17, 2003 Author Share Posted October 17, 2003 It actually is on the bottom, I cropped out my wallpaper. :no: Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1268387 Share on other sites More sharing options...
ServaCom Posted October 17, 2003 Share Posted October 17, 2003 Try this: Make sure auto arrange IS NOT selected and align to grid IS, in this menu: Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1268410 Share on other sites More sharing options...
rpG Posted October 17, 2003 Author Share Posted October 17, 2003 Tried the above suggestion, no luck. :( Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1268415 Share on other sites More sharing options...
..... Posted October 17, 2003 Share Posted October 17, 2003 If you have the taskbar autohiding it'll look like it's unlocked. Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1268432 Share on other sites More sharing options...
vomit Posted October 18, 2003 Share Posted October 18, 2003 I dont like big bars either. You need to go to the apearance tab in display properties and mess about with the bar sizes and font sizes, then it will shrink. if you go to thin though the icons will look scruffy and unpleasant. I hope that helps to fix it for you. Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1268455 Share on other sites More sharing options...
rpG Posted October 18, 2003 Author Share Posted October 18, 2003 Ahh!! Thanks so much everyone. Andrewfee, you nailed it; I had it on auto-hide. Thanks again for all comments and suggestions! :D Link to comment https://www.neowin.net/forum/topic/108523-thin-taskbar-problems/#findComment-1269709 Share on other sites More sharing options...
