Nero Problem
Software
Nero Burning ROM v5.5.3.5
Writer Used
Traxdata 8x4x32
Media
Diskhouse 80 min Grade A CDR
What's Being Copied
One folder (location: C:WindowsDesktopBackupUnreal)
Size of folder contents: 585 Mb
The Problem
For the following two problems, check out the log at the bottom of this post. Anyway, here:
1. Why did the write speed change?
2. Why did it fail at roughly 80% (didn't check, watching TV)
The Log
18:57:27 Caching of files started
18:57:28 Caching of files completed
18:57:28 Burn process started at 8x (1200 KB/s)
18:59:15 R/RW 8x4x32
Write speed changed due to media
19:11:21 R/RW 8x4x32
Internal target failure
Invalid writestate
Could not perform EndTrack
19:11:21 Burn process failed at 4x (600 KB/s)
https://www.neowin.net/forum/topic/1100-nero-problem/
4 answers to this question
Could it be a problem with your computer running out of resources, as I see that you are using Windows 98SE.
One thing you could try is to see if it happens on the first burn AFTER a fresh reboot. This could tell you whether it's a hardware issue or an OS issue in regards to the running software in the computer etc etc etc...
https://www.neowin.net/forum/topic/1100-nero-problem/#findComment-4604
I always do this before copying CDs. Here:
Start > Programs > Accessories > System Tools > System Information > Tools > System Configuration Utility > Startup Tab... then disable everything. Press OK, and restart. It still comes up...
https://www.neowin.net/forum/topic/1100-nero-problem/#findComment-4673
