Guest Posted January 7, 2013 Share Posted January 7, 2013 So, bluetooth adapters have got tiny now, does anyone happen to know if a micro-usb dongle can be purchased anywhere now? I ask because I want bluetooth on a tablet which I bought which I didn't realize came without bluetooth and otherwise, it means using a microusb to usb adapter which is a bit of a pain. Thanks, Mark. Link to comment https://www.neowin.net/forum/topic/1129456-micro-usb-bluetooth-dongle/ Share on other sites More sharing options...
+jamesyfx Subscriber² Posted January 7, 2013 Subscriber² Share Posted January 7, 2013 I've not heard of any sort of USB accessory that goes direct from MicroUSB. As far as I know you will always need an adaptor unless the tablet you have uses full-sized USB ports, which some do. Link to comment https://www.neowin.net/forum/topic/1129456-micro-usb-bluetooth-dongle/#findComment-595437246 Share on other sites More sharing options...
PNWDweller Posted January 7, 2013 Share Posted January 7, 2013 Might look oddball but something like this might work? http://www.amazon.co...r/dp/B0023FTRUO Raa 1 Share Link to comment https://www.neowin.net/forum/topic/1129456-micro-usb-bluetooth-dongle/#findComment-595437256 Share on other sites More sharing options...
Guest Posted January 8, 2013 Share Posted January 8, 2013 Might look oddball but something like this might work? http://www.amazon.co...r/dp/B0023FTRUO Possibly but I'm not sure it'll fit into my connection. I was hoping to find something that was concealed by my tablets casing: I'm still not totally sure it'll gain full bluetooth capability anyway, my girlfriend has a pipo S1 and I plugged it in, the dongle lit up but nothing happened. I edited build.prop to enable bluetooth. The panel shows up in settings but it's empty, I assume they stripped out the bluetooth capability on hers totally. Not sure about mine, it should arrive in about one hour @_@ Link to comment https://www.neowin.net/forum/topic/1129456-micro-usb-bluetooth-dongle/#findComment-595439740 Share on other sites More sharing options...
