meirondamania Posted June 28, 2013 Share Posted June 28, 2013 Since my PC upgrade i have been facing random bsod's after usually a few hours from boot. This is what who crashed gave me. System Information (local) computer name: MEIRON-PCwindows version: Windows 7 Service Pack 1, 6.1, build: 7601windows dir: E:\WindowsCPU: AuthenticAMD AMD FX-8350 Eight-Core Processor AMD586, level: 218 logical processors, active mask: 255RAM: 8488140800 totalVM: 2147352576, free: 1993650176 Crash Dump Analysis Crash dump directory: E:\Windows\MinidumpCrash dumps are enabled on your computer.On Thu 6/27/2013 4:06:02 PM GMT your computer crashedcrash dump file: E:\Windows\Minidump\062713-25365-01.dmpThis was probably caused by the following module: ntoskrnl.exe (nt+0x7F1C0)Bugcheck code: 0x34 (0x50853, 0xFFFFF8800333F2E8, 0xFFFFF8800333EB40, 0xFFFFF80002EC5D22)Error: CACHE_MANAGERfile path: E:\Windows\system32\ntoskrnl.exeproduct: Microsoft? Windows? Operating Systemcompany: Microsoft Corporationdescription: NT Kernel & SystemBug check description: This indicates that a problem occurred in the file system's cache manager.This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.On Thu 6/27/2013 4:06:02 PM GMT your computer crashedcrash dump file: E:\Windows\memory.dmpThis was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)Bugcheck code: 0x34 (0x50853, 0xFFFFF8800333F2E8, 0xFFFFF8800333EB40, 0xFFFFF80002EC5D22)Error: CACHE_MANAGERBug check description: This indicates that a problem occurred in the file system's cache manager.This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.On Wed 6/12/2013 2:35:10 PM GMT your computer crashedcrash dump file: E:\Windows\Minidump\061213-24694-01.dmpThis was probably caused by the following module: ntoskrnl.exe (nt+0xAFD22)Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF80002F01D22, 0xFFFFF880033E0598, 0xFFFFF880033DFDF0)Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_Mfile path: E:\Windows\system32\ntoskrnl.exeproduct: Microsoft? Windows? Operating Systemcompany: Microsoft Corporationdescription: NT Kernel & SystemBug check description: This indicates that a system thread generated an exception which the error handler did not catch.This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time. My rig: AMD FX-8350,stock Asus M5a97 le r2.0 mobo 8gb ram sapphire radeon hd 7850 2gb 500W VIP gold psu and two hdds one 320 wd and other 640 caviar green wd. Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 Guys any help regarding this will be greatly appreciated i am tired of constant bluescreens thanks. Link to comment Share on other sites More sharing options...
goretsky Supervisor Posted June 28, 2013 Supervisor Share Posted June 28, 2013 Hello, Can you tell us more about the upgrade you mentioned, or include a link to it if it's something you posted? Regards, Aryeh Goretsky Link to comment Share on other sites More sharing options...
John.D Posted June 28, 2013 Share Posted June 28, 2013 Are you overclocking? Try bluescreenview see if it gives you any other files (that maybe the cause). Test your ram with memtest Link to comment Share on other sites More sharing options...
articuno1au Posted June 28, 2013 Share Posted June 28, 2013 Sounds like you might have an issue with your memory.. Take a look at: http://www.memtest86.com/ Download, install to a CD and run the test. Let it finish 3 times and let us know the results :) Link to comment Share on other sites More sharing options...
Dutchie64 Posted June 28, 2013 Share Posted June 28, 2013 Had similar issues, turned out to be an old BIOS on the SSD. Upgraded it to the latest, never had any problems after that. In your case, it could be RAM. So get memtest, or run the mem checker in w7 from the bootmenu. Link to comment Share on other sites More sharing options...
von kain Posted June 28, 2013 Share Posted June 28, 2013 update bios and ssd firmware disable virtual memory. download core temp and check cpu tempeture, download msi afterburner and check gpu tempeture. Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 The RAM has already been checked by my technician when this problem started.my upgrade was from an i3 540 and an intel dh55tc mother board to amd fx-8350 and asus m5a97 le r2.0 mobo. my cpu temp on idle is 42 and gpu is 39.is my psu of 500w okay for this setup? I have not overclocked my cpu or my gpu. and any idea as to how i can update my bios i have no idea how to with this motherboard. anyway running memtest.will let you know about the results thanks. :) Link to comment Share on other sites More sharing options...
articuno1au Posted June 28, 2013 Share Posted June 28, 2013 For ###### and giggles, after you've run Memtest, uninstall your USB3 drivers and see if that helps. I had the same generation of board that was causing a BSoD that looked like a memory issue due to USB3 drivers. Worth a test at the very least. Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 Ok how do i uninstall usb 3 drivers.sorry im stupid at times:P Link to comment Share on other sites More sharing options...
articuno1au Posted June 28, 2013 Share Posted June 28, 2013 Control Panel -> Device Manager -> Universal Serial Bus Controllers -> <Find your USB 3 controller, it's an ASMedia one> -> Right click -> Properties -> Driver -> Uninstall -> Check tickbox -> Hit Ok. Site if you need to get the drive again afterwards: http://www.asus.com/Motherboards/M5A97_LE_R20/#support_Download Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 Okay my comp just bluescreened and gave this error whocrashed couldnt get the dumpfiles but it said the system has encountered an uncorrectable hardware error and once it restarted it just hung in 5 mins i really need help from you guys im going nuts i dont know what to do now. anyway im trying updating the bios. Link to comment Share on other sites More sharing options...
articuno1au Posted June 28, 2013 Share Posted June 28, 2013 I take it Memtest didn't return anything? Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 memtest was all clear there is no ram issue updated bios now what else can i do its been an hour without a bluescreen but i need a permanent solution. Link to comment Share on other sites More sharing options...
von kain Posted June 28, 2013 Share Posted June 28, 2013 an uncorrectable hardware error and once it restarted it just hung in 5 mins . oh come on this really looks like a tempeture problem. have you in any way configure your bios? run a stress test (gpu and cpu while looking the cpu-gpu tempertures). have you format the pc after first time encounter the problem? as for the 500W psu which bradn is it ? have you check it fan? Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 ok just used driver verifier comp crashed on startup using safe mode with networking. I HAVE NO IDEA WHAT TO DO NOW! Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 okay driver verifier is doing its job im on normal windows. p.s temps gpu under load touches a 68 cpu touches 61 whilst running crysis 3. and yes i did format more than thrice after i got the bsod fan on psu is moving but at times under heavy load it does get a bit hot can that be causing the bsod? no i have not configured my bios in anyway nor have i overclocked any of my components. no i have not configured my bios in anyway nor have i overclocked any of my components. Link to comment Share on other sites More sharing options...
John.D Posted June 28, 2013 Share Posted June 28, 2013 If its a x124 stop error, this is usually CPU / hardware related. It maybe an option in the BIOS that is buggy. If you installed the CPU, make sure its installed properly Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 okay all my hardware components have been installed correctly just rechecked.I still have no idea what is causing the bsod. Link to comment Share on other sites More sharing options...
John.D Posted June 28, 2013 Share Posted June 28, 2013 It maybe a faulty CPU too. When you get that 0x124 stop error Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 okay just saying CPU,MOBO and graphics card are brand new what do i do?DO i ask my technician to take it back because this is getting on my nerves. Link to comment Share on other sites More sharing options...
John.D Posted June 28, 2013 Share Posted June 28, 2013 I would replace the CPU. Just because it's new, it doesn't mean it cant be faulty. Link to comment Share on other sites More sharing options...
meirondamania Posted June 28, 2013 Author Share Posted June 28, 2013 Ok so well its 3 am here tomorrow morning i shall make a call to my technician and ask him to take my desktop for a thorough evaluation as to what is the issue and what is not and if its a cpu or mobo,graphical issue it will get replaced. Thanks a lot for your assistance.The only issue is this is india getting a functioning proper replacement is like so rare. Link to comment Share on other sites More sharing options...
goretsky Supervisor Posted June 29, 2013 Supervisor Share Posted June 29, 2013 Hello, You mentioned that upgraded from a different CPU and motherboard to new ones. Does this mean that a brand new clean installation of Windows was performed? Or just that the hardware was upgraded and Windows allowed to find new device drivers? Regards, Aryeh Goretsky Link to comment Share on other sites More sharing options...
meirondamania Posted July 1, 2013 Author Share Posted July 1, 2013 A new clean installation of windows was done thrice actually. Link to comment Share on other sites More sharing options...
