Linux System Stats Script - Version 2.2.1 Released
Haggis Stats
Some of you might remember that Haggis announced on this forum late last year that he was writing a simple Linux system stats script. At first it started out really basic, but with the encouragement of other Neowin members he continued to improve it. Several of us even offered pointers or submitted patches to help fix bugs. As it evolved over the next several months Haggis added features and stability improvements until it became what I believe is one of the best scripts of its kind.
Since Haggis has not had much free time to work on it recently, I set out to fix some bugs in the script last weekend. In particular I noticed that while the script works well on my distro of choice, it spit out many ugly errors on typical Arch Linux installations. In the process of tracing and fixing these bugs I decided to rewrite the script in Perl. This major revision of Stats is much more fault tolerant, has explicit support for the most popular Linux distributions and desktop environments, has new switches to control behavior, and has significantly more documentation than the old BASH script.
Therefore Haggis and I are proud to present Haggis Stats 2.0!
About
Stats is a simple script to print basic system statistics and immortalize those results with a screenshot on GNU/Linux systems. The most popular Linux distributions are officially supported by this script, although any reasonable, modern GNU/Linux system should have no problem running it. It was written with typical end-user desktop installations in mind, but a limited subset of the functionality afforded to those systems is provided on headless machines. This script will automatically detect the functionality available and print the associated system information accordingly, or fail gracefully if it cannot.
Officially Supported Operating Systems
  • Red Hat Enterprise Linux >= 6.0
  • CentOS >= 6.0
  • Fedora >= 15
  • Debian >= 6.0
  • Ubuntu >= 12.04
  • Linux Mint >= 13
  • Elementary OS >= 0.2
  • Arch Linux
  • openSUSE >= 12.3
Dependencies
      Base Dependencies
  • Perl 5.10 or later
  • Perl Switch module
  • Linux Standard Base core
      Recommended Utilities
  • GNU Coreutils
  • GNU PS
  • xrandr
  • scrot
Installation
In most cases Stats really does not need to be installed. You can invoke it from the top level of its source directory using the command below.
$ ./src/stats.pl
If you wish to install Stats so it is available to all users on your system, you can do so one of two ways. If you are running Debian or a Debian-based distribution such as Ubuntu or Linux Mint, you can install the Debian package in the section below. Otherwise you can run the commands listed below as root to install the script manually. Typically prefixing each command with "sudo" or "su -c" will run it as root if you have not already assumed those privileges since entering the top-level of the Stats source directory.
# install -m 755 ./src/stats.pl /usr/local/bin/haggis-stats
# install -m 755 -d /usr/local/man/man1
# install -m 644 ./man/stats.1 /usr/local/man/man1/haggis-stats.1
# gzip /usr/local/man/man1/haggis-stats.1
Packages
In addition to the manual installation method described above, I also developed a Debian package for Stats. I recommend that you use this package if you are running Debian, Ubuntu, or another Debian derivative. You can either click the appropriate link in the next section to download the package and double-click it in your file manager to install it with Synaptic, GDebi, Ubuntu Software Center, or your other graphical package manager of choice; or follow the instructions below to install it from the command line.
Debian/Ubuntu Installation:
$ wget http:\\www.haggistech.co.uk\stats\haggis-stats_2.2.1_all.deb
$ sudo apt-get install scrot
$ sudo dpkg -i haggis-stats*.deb
$ sudo apt-get install -f
$ haggis-stats
Majesticmerc has also written an Arch Linux package for Stats which he uploaded to the Arch User Repository. I recommend that you use this package if you are running Arch Linux or a derivative. You can download the PKGBUILD from the haggis-stats AUR page and install it using your preferred method, or follow the instructions below.
Arch Linux AUR Installation:
$ wget https://aur.archlinux.org/packages/ha/haggis-stats/haggis-stats.tar.gz
$ tar xzf haggis-stats.tar.gz
$ cd haggis-stats
$ makepkg -s
$ sudo pacman -U haggis-stats*.pkg.tar.xz
Links
Stats 2.2.1 Debian Package: http:\\www.haggistech.co.uk\stats\haggis-stats_2.2.1_all.deb
Stats GitHub Repository: https://github.com/xorangekiller/haggis-stats
Stats 1.x Thread: https://www.neowin.net/forum/topic/1119502-linux-system-stats-script
ChangeLog
Version 2.2.1
  • New Feature: Added ability to pipe to file without coloring
  • New Feature: Setting HAGGIS_STATS_SCREENSHOT_DIR variable will default the screenshot folder
  • Cosmetic Change: made ram display as Used/Available instead of Available/Used
Version 2.1.0
  • New Feature: Elementary OS support
  • New Feature: --output-dir option
  • Bugfix: No screenshot attempt without an X session
  • Bugfix: Improved support for headless systems
  • Bugfix: Defaulted screenshot utility to scrot to fix "black" screenshots
Version 2.0.0
  • Complete rewrite in Perl
  • New Feature: Command line switches
  • New Feature: Diagnostic report generation
  • New Feature: RHEL, CentOS, Arch, and openSUSE support
  • Bugfix: lsb_release is no longer strictly required
  • New File: ChangeLog and NEWS
  • New File: README
  • New File: INSTALL
  • New File: AUTHORS
  • New File: Stats man page
Bugs
We encourage you to test the script on your systems and report any bugs you encounter; even if they are for Linux distributions we do not officially support we will still try to fix them. For now this thread is the preferred form contact, although you are also welcome to PM Haggis or I if you wish.
When you report bugs it would be very helpful if you could include either a screenshot of Stats' output or a textual copy of the buggy output, and a diagnostic report. Diagnostic reports can be generated by the script using the "report" action. An example of a Stats report is below.
$ ./src/stats.pl report
Diagnostic report written to /home/karl/stats-2.0.0/stats_report_karl_20130927.204227.log
Screenshot
Edited by Haggis
  • Like 4
I could only get it to work by the command line...I installed the package, and it's not under the K-menu...
But using command line, and cding to the stats directory, and running '/src/stats.pl' worked for me, just doesn't seem to do anything when I install, even though it said it installed..lol
But works it works good :)
  On 01/10/2013 at 02:17, Mindovermaster said:
Sorry to be a pest, but how do you run it after you install it the Debian/Ubuntu way? doesn't seem to be anything in ./src/stats.pl. :huh:
If you installed the Debian package it is available from the terminal as haggis-stats.
# Run Stats after it has been installed via the Debian package:
haggis-stats
# View the Stats manual after it has been installed via the Debian package:
man haggis-stats
# Search for Stats if you can't remember the name of the command:
apropos stats
But using command line, and cding to the stats directory, and running "./src/stats.pl" worked for me, just doesn't seem to do anything when I install, even though it said it installed..lol
Since it is not a graphical application Stats does not have a menu entry. I will update the documentation to include the executable name once the package has been installed. I guess it was only clear to me because I wrote the packaging. Oops.
Edit: The opening post has been updated with the new documentation.
No problem. Don't be afraid to ask questions. That's how you learn. I know that Neowin was started to report on Windows development and remains a very Windows-centric community, but there are those of us here who will do our best to help you understand Linux. I started out as a Windows power user who didn't understand the point of Linux. I understand. There is no shame in asking for help when you don't understand something. I will not mock you or ridicule you. My only request is that are willing to drop your presuppositions and learn something new when you ask a question.
  • Like 3
And that is one reason that you're an m.v.c. and one reason why I switched from Fedora to Debian lol You'e done a great job in the Linux section :)
Glad to see you guys like it, Orangekiller is a god in here lol
The only thing i cant get to work was the switches for no screenshot etc
although i did try it working on only 4 hours sleep so i might just be being dumb
Looking good guys! Just finished doing an Arch PKGBUILD script to allow people to install it properly. Others on Arch wanting it "properly installed" can use the PKGBUILD found here: https://spideroak.com/storage/NVQWUZLTORUWG3LFOJRQ/shared/161658-1-2598/PKGBUILD?f0bdbf52bcb9fe26abb01916c8865fd2
Haggis/xorangekiller - Do you guys have any objections to me putting the script on the Arch AUR? That'll make it accessible for more people, and integrate it with the AUR-capable package managers (yaourt, packer, etc).
Doesn't seem very accurate for elementary OS; and it appears buggy when taking screen shots.
compared to ...
Also it would be nice if it placed screenshots in my ~/Pictures folder instead and it would be even nicer to run it without taking a screenshot just to see the output.
Can you add a logo for elementary OS?
That would be fantastic! The only reason I did not do this myself is that I am not experienced with Arch packaging. Let me know when you do, and I will add it to the official documentation.
I noticed the same bug in ImageMagick::Import when I was doing my initial testing, but in an effort to remain consistent with Stats 1.x I let it be. That said, I have a potential fix for the screenshot bug, I just need to do a little more testing to make sure it doesn't breaking anything else.
You can control the output directory for the screenshot by moving to it before executing the script. However I can add a switch to modify this behavior if you wish. I will try to add the Elementary OS logo, fix the screenshot bug, and add a switch for controlling the output directory in the next release.
Awesome man! You rock! And a switch would be nice; two switches actually, one to specify picture output and one to suppress taking a screenshot. Great work otherwise.
  On 03/10/2013 at 20:16, Haggis said:
Hey Guys sorry been busy with work
Into Aur would be amazing
Orange your doing an amazing job :)
Done and done...
Direct link: https://aur.archlinux.org/packages/haggis-stats/
I just updated the opening post. Stats 2.1.0 has been released!
Notably, the "black" screenshot bug has been fixed, you can now control the screenshot output directory using a switch, there is official Elementary OS support (which was trivial considering that Ubuntu 12.04 - its base distribution - was already supported), and I added instructions for installing Majesticmerc's package from the AUR.
  • Like 1
Is there any way to prevent the "stats" suffix being required when options are specified. For example:
# Works :D
$ haggis-stats --no-screenshot stats
# Fails :(
Invalid ACTION: --no-screenshot
I could add that feature, but it would make the argument processing logic a lot more complicated, which is why I opted not to so far. However, I will look into it for the next release. There might be a nice solution I haven't considered yet.
If anyone else has any feature requests, feel free to ask. I very much enjoy Perl programming (which I don't get to use often enough in my day job) and would love to make the script even more useful. Haggis might be willing to implement some new features too as he expands his knowledge of Perl.
