Dinggus Posted November 22, 2013 Share Posted November 22, 2013 I'm looking to get a nice multiple HDMI port wall panel, can anyone suggest a nice wall panel to use? I have 4 HDMI cables and a digital optic cable, just tired of taking the TV off the wall, and running cables down the wall. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/ Share on other sites More sharing options...
TAZMINATOR Posted November 22, 2013 Share Posted November 22, 2013 What you mean? You mean you look for wall mount for TV? Or cover for the wires? Or hole outlet for behind the wall cables? Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122535 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 Something like this: I just want it easier to connect cables. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122569 Share on other sites More sharing options...
Rohdekill Posted November 23, 2013 Share Posted November 23, 2013 Ok...I'll go ahead and say what everyone is thinking.... Seems to me you answered your very own question. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122579 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 Sort of, I'm looking for other opinions. Also, do I run the cable from the TV to the back of this? Then another cable from this to the device? Seems like alot of cables. Then you got high end cables for low end cables or are all HDMI cables the same? Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122621 Share on other sites More sharing options...
TAZMINATOR Posted November 23, 2013 Share Posted November 23, 2013 I couldn't find them but I like my way better because you will need the following items: hdmi cables (10 ft or larger depends the length in your entertainment project). other cables (10ft or larger.) Once you hook them up.. leave the cables behind the walls... You will need extra cables for travel or other rooms.. so you don't have to take them down and re-install all over again. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122629 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 I couldn't find them but I like my way better because you will need the following items: hdmi cables (10 ft or larger depends the length in your entertainment project). other cables (10ft or larger.) Once you hook them up.. leave the cables behind the walls... You will need extra cables for travel or other rooms.. so you don't have to take them down and re-install all over again. Thank you, assumed I was going to have to do that. What about the difference between the cables, is there any? Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122645 Share on other sites More sharing options...
TAZMINATOR Posted November 23, 2013 Share Posted November 23, 2013 Thank you, assumed I was going to have to do that. What about the difference between the cables, is there any? Whatever you have for your entertainment system... HDMI? digital optic cable? speaker cables? Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122661 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 Whatever you have for your entertainment system... HDMI? digital optic cable? speaker cables? What I'm trying to ask is do I need to buy all new HDMI cables for this, and then use the same brand of cables or can I mix HDMI cables up? I'll be running 4 HDMI cables and a digital optic cable. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122693 Share on other sites More sharing options...
TAZMINATOR Posted November 23, 2013 Share Posted November 23, 2013 What I'm trying to ask is do I need to buy all new HDMI cables for this, and then use the same brand of cables or can I mix HDMI cables up? I'll be running 4 HDMI cables and a digital optic cable. All the same brands and versions... such as HDMI cable can be used 3D, 1080p/i, etc. If you don't need extra cables... and that all you need 4 hdmi and 1 DOC line, then do not need to buy extras. Just leave them alone... If you need cables for something else, just buy extra cables and leave the 'behind the wall' cables alone. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122701 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 All the same brands and versions... such as HDMI cable can be used 3D, 1080p/i, etc. If you don't need extra cables... and that all you need 4 hdmi and 1 DOC line, then do not need to buy extras. Just leave them alone... If you need cables for something else, just buy extra cables and leave the 'behind the wall' cables alone. Won't I need 4 cables to hook from TV to a the back of a 4 HDMI port outlet (wires in the wall)? Then a HDMI cable for each of my device to hook to the outlet? Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122711 Share on other sites More sharing options...
TAZMINATOR Posted November 23, 2013 Share Posted November 23, 2013 Won't I need 4 cables to hook from TV to a the back of a 4 HDMI port outlet (wires in the wall)? Then a HDMI cable for each of my device to hook to the outlet? That is fine if you have the outlet.... If no outlet, then run the cables from the devices and into the bottom hole in the wall and run up to another hole and out to the TV like this: Mine didn't have the plug outlet behind the TV like the picture above but I got 10ft power cable for TV so it can be run behind the wall along with other cables. So they can be plugged in the outlet behind the TV stand/table. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122717 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 That is fine if you have the outlet.... If no outlet, then run the cables from the devices and into the bottom hole in the wall and run up to another hole and out to the TV like this: DT503321WHKIT_diagram.jpg Mine didn't have the plug outlet behind the TV like the picture above but I got 10ft power cable for TV so it can be run behind the wall along with other cables. So they can be plugged in the outlet behind the TV stand/table. Yeah I planned on buying the outlet, becuase I have what you show minus the power outlet. I just am tired of runing wires back forth, when I could plug in 4 HDMI cables to my TV to the back of the HDMI outlet, then plug in HDMI in the front of the outlet to the devices I have. That way I won't have to unmount my TV anymore. 70 inch TV isn't light, lol. I just want to verify I can mix HDMI cables. Like they don't need to be the same brand or high priced cables vs low priced cables. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122721 Share on other sites More sharing options...
Rohdekill Posted November 23, 2013 Share Posted November 23, 2013 I just use these to hide HDMI, power and CAT cabling. http://www.menards.com/main/electrical/wall-plates/accessories/in-wall-cable-access-port/p-2006751-c-6473.htm Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122729 Share on other sites More sharing options...
TAZMINATOR Posted November 23, 2013 Share Posted November 23, 2013 Yeah I planned on buying the outlet, becuase I have what you show minus the power outlet. I just am tired of runing wires back forth, when I could plug in 4 HDMI cables to my TV to the back of the HDMI outlet, then plug in HDMI in the front of the outlet to the devices I have. That way I won't have to unmount my TV anymore. 70 inch TV isn't light, lol. I know TV is heavy ... Mine is as well.. I just want to verify I can mix HDMI cables. Like they don't need to be the same brand or high priced cables vs low priced cables. Like I said earlier, same brands... make sure that they are 1080p/i and 3D compatible. Cheap ones are fine as long as they are from the reliable/respectable source. Don't use the monster cables... Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122735 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 I know TV is heavy ... Mine is as well.. Like I said earlier, same brands... make sure that they are 1080p/i and 3D compatible. Cheap ones are fine as long as they are from the reliable/respectable source. Don't use the monster cables... Oops, didn't see that. I was going to run these: http://www.amazon.com/gp/product/B0052SCU8U/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122747 Share on other sites More sharing options...
TAZMINATOR Posted November 23, 2013 Share Posted November 23, 2013 That is fine. Mine is at 10ft. Enough room for tilt and swivel mounted TV. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122753 Share on other sites More sharing options...
Dinggus Posted November 23, 2013 Author Share Posted November 23, 2013 That is fine. Mine is at 10ft. Enough room for tilt and swivel mounted TV. Okay, yeah I'm going to need a new mount as well. I would like a tilt or full motion would be good. Link to comment https://www.neowin.net/forum/topic/1189545-wall-panels-for-mounted-tvs/#findComment-596122759 Share on other sites More sharing options...
