ahmz Posted November 27, 2013 Share Posted November 27, 2013 Hi The buttons on the right side of my controller do not work anymore. The only way I can get them to work is if I connect the red contact patch with any of the yellow contacts via a piece of aluminium foil (see image below). http://i.imgur.com/mSxzj2d.jpg Does anyone know how to solve this problem? Thanks Link to comment https://www.neowin.net/forum/topic/1190357-ps2-controller-button-problems/ Share on other sites More sharing options...
xendrome Posted November 27, 2013 Share Posted November 27, 2013 http://www.amazon.com/Analog-Controller-DUAL-SHOCK-Sony-PlayStation/dp/B0032GVBS4/ref=sr_1_1?ie=UTF8&qid=1385585551&sr=8-1&keywords=Playstation+2+controller Don't forget to Mark Solved for me. Link to comment https://www.neowin.net/forum/topic/1190357-ps2-controller-button-problems/#findComment-596132793 Share on other sites More sharing options...
ahmz Posted November 27, 2013 Author Share Posted November 27, 2013 Thanks for linking me to a 3rd-party controller. I don't need a new controller, I'm just trying to figure out how this can be fixed. Link to comment https://www.neowin.net/forum/topic/1190357-ps2-controller-button-problems/#findComment-596132813 Share on other sites More sharing options...
xendrome Posted November 27, 2013 Share Posted November 27, 2013 On 27/11/2013 at 20:58, ahmz said: Thanks for linking me to a 3rd-party controller. I don't need a new controller, I'm just trying to figure out how this can be fixed. It's not 3rd party, it's a PS2 controller. And I'd guess it's because the controller you have is just worn out, the contacts/pcb board etc. So wouldn't it be worth the $10 to just replace it? I'm sure you could find a local game store that has them used for probably even less. Link to comment https://www.neowin.net/forum/topic/1190357-ps2-controller-button-problems/#findComment-596132817 Share on other sites More sharing options...
