Technique Posted December 21, 2013 Share Posted December 21, 2013 This hasn't always been there & i've not installed any new hardware. See the attachment for the problem. What is this & how do you put it right? I did a bit of googling & it says something about the motherboard CD, but i installed those drivers?? Link to comment https://www.neowin.net/forum/topic/1193745-marvell-91xx-config-ata-device-problem-in-device-manager/ Share on other sites More sharing options...
0 Phouchg Posted December 21, 2013 Share Posted December 21, 2013 Assumed you have this controller somewhere on the motherboard itself, but there's none of that sort. You will need to install drivers for this expansion card then. Technique 1 Share Link to comment https://www.neowin.net/forum/topic/1193745-marvell-91xx-config-ata-device-problem-in-device-manager/#findComment-596176543 Share on other sites More sharing options...
0 Phouchg Posted December 21, 2013 Share Posted December 21, 2013 ATA device is a giveaway - it's a storage controller. What motherboard (make and model) do you have there? Link to comment https://www.neowin.net/forum/topic/1193745-marvell-91xx-config-ata-device-problem-in-device-manager/#findComment-596176507 Share on other sites More sharing options...
0 spaceelf Posted December 21, 2013 Share Posted December 21, 2013 This hasn't always been there & i've not installed any new hardware. See the attachment for the problem. What is this & how do you put it right? I did a bit of googling & it says something about the motherboard CD, but i installed those drivers?? Marvell.jpg The Marvell driver installs two entries in the Device Manager....looks like the second one got messed up somehow. While the driver from your motherboard support site would most likely fix it, there's a good chance it's outdated. I recommend the 1.2.0.1039 here http://station-drivers.com/index.php/10-drivers/47-marvell (ignore the MSU) Link to comment https://www.neowin.net/forum/topic/1193745-marvell-91xx-config-ata-device-problem-in-device-manager/#findComment-596176511 Share on other sites More sharing options...
0 Technique Posted December 21, 2013 Author Share Posted December 21, 2013 MOBO: Asus M4A88TD-V EVO/USB3 I have 2 different SSD drives in there & 2 HDDs. I ran out of SATA ports so had to get one of those cards to allow another connection. I have my blu ray DVD drive attached to this. Link to comment https://www.neowin.net/forum/topic/1193745-marvell-91xx-config-ata-device-problem-in-device-manager/#findComment-596176517 Share on other sites More sharing options...
0 Reverse Engineer Posted December 21, 2013 Share Posted December 21, 2013 firstly, right click on it and select update driver, see what happens. if you have no joy, a lot of the times you can resolve issues like this by right clicking on it, uninstalling, then reboot. best outcome is windows finding the appropriate driver when it rescans your hardware, and the worst is you'll be in the same position. Link to comment https://www.neowin.net/forum/topic/1193745-marvell-91xx-config-ata-device-problem-in-device-manager/#findComment-596176555 Share on other sites More sharing options...
Technique
https://www.neowin.net/forum/topic/1193745-marvell-91xx-config-ata-device-problem-in-device-manager/Share on other sites
5 answers to this question
