RastaX Posted October 3, 2014 Share Posted October 3, 2014 InnoExtractor 4.8.1.160 Author Description InnoExtractor is a powerful and free application that helps you to unpack Inno Setup installers. With InnoExtractor you can explore the internal structure and content of the installer and you can to extract them to a local folder or a portable devices, without having to run the setup. InnoExtractor is available in English and in other 17 languages. Screenshot: Key features: - Simple and friendly GUI. - Open Inno Setup-based installers into the application by drag and drop executables from Windows Explorer. - Explore and inspect internal content (files and more) of the installer. - Get the full script content of installer. - Extract files to a local folder, to a zip package, to a self-extracting module (portable) or by drag and drop feature. - Dump/export "Code" (RemObjects Pascal in assemply code), "Registry" and "INI" sections from the script to a readable file. - Run files of the installer into the same application with double click. - Identify encrypted files of the installer. - Perform file searches by keyword. - Input panel, that allows you to enter a valid password to extract encrypted installers. - Properties panel to see advanced information about the installer. - History for recently opened installer. - Other miscellaneous options. - Support older and latest versions of Inno Setup. - Application available in multiple languages. - Designed for Windows 2000, XP, Vista, 7 and 8/8.1. - Full Unicode support. - Much more... System requirements: - Windows 2000/XP/Vista/7/8/8.1. - Inno Setup-based installers. Changelog: - Improved small issues for application installer. - Removed file encryption for the installer, so you can now open and extract the internal files of InnoExtractor installer with our own InnoExtractor application, as in the past. - Changed some small issues for credits in "About InnoExtractor" dialog. - Fixed a small bug in the installer discovered in previous build. Website for more info and Download Link to comment Share on other sites More sharing options...
