Blaze_Zewi Posted April 6, 2015 Share Posted April 6, 2015 So my PSU fan just kick the bucket. No matter where I look, ebay or Amazon. There are no listing for 135mm with 2 pin (black / red connector). However both do list 135mm fan with 3 pin though Maybe the fan on my PSU are not replaceable? Using my Macyver skills, I install a 120mm on my PSU with zip tie. Untill I can find a replacement fan. BTW Its a HIPER HPU-4M880-PS TYPE M PSU bough it back in 2009. And its still kicking butts. I am looking at the EVGA Supernova 750W G2 if I decide to get a new PSU. Anyone has this PSU? Mind sharing your thoughts about it? This is the type of connector that is on my dead PSU fan. Link to comment https://www.neowin.net/forum/topic/1252558-135mm-w-2-pin-psu-fan-replacement/ Share on other sites More sharing options...
Tha Bloo Monkee Posted April 6, 2015 Share Posted April 6, 2015 Buy fan with 3-pin connector, cut the end off, attach 2-pin connector by either stripping the wire and soldering the 2-pin connector (ideal) or just twist them together. Then use electrical tape, and done. The 3rd wire for 3-pin fans is the sensor so it knows how fast the fan spinning, so just leave it. Link to comment https://www.neowin.net/forum/topic/1252558-135mm-w-2-pin-psu-fan-replacement/#findComment-596808240 Share on other sites More sharing options...
