VII Posted August 8, 2015 Share Posted August 8, 2015 I'm setting up a corsair h100 on the top of my 780t and have read the differences between push and pull configurations for cooling and wanted to know whether anyone had recommendations for types of fans to use. I know the difference in temperatures are marginal between push or pull. I don't wish to do pull-push together, but rather only pull. I currently have a pair SP140 (corsair's static pressure fans) and wanted to know if that's something that should be sufficient. I'm running an overclock of 4.5ghz on a 5930k at 1.3v so want to keep the temps as cool as possible. Noise isn't too much a concern. Specifically I want to have the fans setup as exhaust, because otherwise I just have 1 noctua fan as exhaust and my GPU temps are getting really crazy I feel without extra exhaust. So exhaust, 2 140mm fans, in pull only on a corsair h100. What would you guys say for a great fan choice? Thanks! Link to comment https://www.neowin.net/forum/topic/1268006-push-vs-pull-on-240mm-radiator-need-fan-recc-pls/ Share on other sites More sharing options...
Anibal P Posted August 8, 2015 Share Posted August 8, 2015 Front fans pull, rear and rad fans push Really should have at lest one front fan pulling Link to comment https://www.neowin.net/forum/topic/1268006-push-vs-pull-on-240mm-radiator-need-fan-recc-pls/#findComment-596965050 Share on other sites More sharing options...
dafox Posted August 8, 2015 Share Posted August 8, 2015 On 08/08/2015 at 19:07, Anibal P said: Front fans pull, rear and rad fans push Really should have at lest one front fan pulling The SP140's are perfect. / Thread Link to comment https://www.neowin.net/forum/topic/1268006-push-vs-pull-on-240mm-radiator-need-fan-recc-pls/#findComment-596965062 Share on other sites More sharing options...
VII Posted August 11, 2015 Author Share Posted August 11, 2015 So setting it up with the SP140's I have it like this: White - Corsair AF140 x 2 - intake Purple - Corsair AF120 x 2 - intake Blue - Corsair SP140 x 2 - exhaust, as pull over H110 Brown - Noctua NF-A14 FLX - exhaust I notated that the video card isn't the blower type and that hot air just comes out the sides of the card and hopefully is blowing up and out of the case fast enough not to make a different in my cpu temps too much. Also do you think this setup has positive pressure? I know the noctua moves a lot of air, so i'm curious. Thanks guys! Link to comment https://www.neowin.net/forum/topic/1268006-push-vs-pull-on-240mm-radiator-need-fan-recc-pls/#findComment-596970304 Share on other sites More sharing options...
1WayJonny Posted August 11, 2015 Share Posted August 11, 2015 (edited) I have three Titan X's and separate CPU loop. The difference between push and pull will be minimal and should not effect your setup. What you should be more concerned about is getting the hot air off the RAD out of the case. That being said when doing a push or pull on the top of the case you will have to flip you fans the other way. When doing so make the fan hang and will cause havoc on the bearings. After a few months with a little dust the bearing will make noise and drive you nuts. The stress comes form point the fan down into the case vs laying them on the back and the fan/bearing have an easier time resting laying down then hanging on while spinning. Hope this makes sense. **UPDATE** Here is a link to my water rig, good luck: https://plus.google.com/111546510164538610330/posts/Voj6TxB8dj1 Edited August 11, 2015 by 1WayJonny Link to comment https://www.neowin.net/forum/topic/1268006-push-vs-pull-on-240mm-radiator-need-fan-recc-pls/#findComment-596970346 Share on other sites More sharing options...
