Ludde Posted December 27, 2015 Share Posted December 27, 2015 Ive got a pioneer vsx-407 RDS reicever and audio pro B2.38 subwoofer my receiver has an output for subwoofer the only problem is that its rca while the subwoofer has these red and black copper cable input so right now its plugged into normal speakers and the bass is just really weak do i need a new receiver? Link to comment https://www.neowin.net/forum/topic/1283386-stereo-only-has-rca-output-for-subwoofer/ Share on other sites More sharing options...
+Raze Subscriber² Posted December 27, 2015 Subscriber² Share Posted December 27, 2015 (edited) Look for a RCA plug to speaker wire cable. Something like this - or and RCA to banana plug if you have that type of binding posts on the sub-woofer. Some speakers have 5-way binding posts. I was unable to find any info on your sub-woofer. The Evil Overlord 1 Share Link to comment https://www.neowin.net/forum/topic/1283386-stereo-only-has-rca-output-for-subwoofer/#findComment-597204704 Share on other sites More sharing options...
The Evil Overlord Posted December 28, 2015 Share Posted December 28, 2015 On 27/12/2015 at 19:28, Raze said: Look for a RCA plug to speaker wire cable. Something like this - Expand @Ludde You'll need 2 of these if your sub has dual inputs, also the placement of the subwoofer is important. The set up of the gain controls (and crossovers if applicable) is also important, to achieve the desired effect. How do you prefer the bass? Deep and low? Punchy? Soft? Link to comment https://www.neowin.net/forum/topic/1283386-stereo-only-has-rca-output-for-subwoofer/#findComment-597205168 Share on other sites More sharing options...
Dashel Posted December 30, 2015 Share Posted December 30, 2015 (edited) Can you take a pic of the connections on the sub? It should just be a straight RCA to RCA connection (you can ignore the Left RCA channel on the sub or buy a RCA splitter for the sub side - you shouldn't need on one most quality subs.) Link to comment https://www.neowin.net/forum/topic/1283386-stereo-only-has-rca-output-for-subwoofer/#findComment-597209336 Share on other sites More sharing options...
Phemo Posted December 30, 2015 Share Posted December 30, 2015 It seems your subwoofer is a passive subwoofer and the amp is designed to work with an active (ie. amplified) subwoofer. If this is the case then you'll either need a new active subwoofer or some kind of amp for it. After changing my amp recently recently I had exactly the same problem. I ended up cutting a bit out of the back of my subwoofer and buying a plate amp to basically 'convert' my passive sub into an active one. Link to comment https://www.neowin.net/forum/topic/1283386-stereo-only-has-rca-output-for-subwoofer/#findComment-597209366 Share on other sites More sharing options...
sc302 Veteran Posted January 7, 2016 Veteran Share Posted January 7, 2016 You would need a better subwoofer or a cheaper stereo. Rca is low pass or weak signal compared to the signal coming out of the speaker pairs. You shouldn't get more sound out of your woofer if you use the rca to bare wire, if anything less sound. You need a powered woofer to work with the rca cable. Link to comment https://www.neowin.net/forum/topic/1283386-stereo-only-has-rca-output-for-subwoofer/#findComment-597222254 Share on other sites More sharing options...
