profoundwhispers Posted January 5, 2004 Share Posted January 5, 2004 After I substituted the normal windows folder icon with GANT's, I'm having ugly folder thumbnails in My Music and My Pictures folders. What can I do to fix that? Thank you. Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/ Share on other sites More sharing options...
icexswipe Posted January 24, 2004 Share Posted January 24, 2004 hey i was having that same problem hope someone helps us Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1643461 Share on other sites More sharing options...
Fly Soul Posted January 24, 2004 Share Posted January 24, 2004 right-click and select Refresh Thumbnails Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1643501 Share on other sites More sharing options...
icexswipe Posted January 24, 2004 Share Posted January 24, 2004 thanks for the reply but unfortunately that didnt work Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1644509 Share on other sites More sharing options...
cpugeniusmv Posted January 25, 2004 Share Posted January 25, 2004 show hidden and system files (in Folder Options) and then delete the instances of thumbs.db in the folders with ugly thumnails. alternatively in the command prompt (removes ALL thumbs.db's cd \ del /s/q thumbs.db Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1645119 Share on other sites More sharing options...
icexswipe Posted January 25, 2004 Share Posted January 25, 2004 well i thought tht wud work for sure but it didnt thanks tho i dunno what the problem is... Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1647654 Share on other sites More sharing options...
icecaveman Posted January 25, 2004 Share Posted January 25, 2004 the icon you selected does not support so large icons as thumbnails are, they have to be around 72x72 if I remember correctly. Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1647671 Share on other sites More sharing options...
icexswipe Posted January 25, 2004 Share Posted January 25, 2004 how can u configure the size of thumbnails? Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1648206 Share on other sites More sharing options...
Fly Soul Posted January 25, 2004 Share Posted January 25, 2004 you can use TweakUI from XP powertoys: Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1648550 Share on other sites More sharing options...
icexswipe Posted January 26, 2004 Share Posted January 26, 2004 thanks guys but the pictures still stick out. The whole thing just scales down, but the pictures are still larger than the folder. oh well, looks a little better when using small thumbnails. Link to comment https://www.neowin.net/forum/topic/129047-problem-with-folder-thumbnails/#findComment-1651646 Share on other sites More sharing options...
