Technique Posted September 3, 2016 Share Posted September 3, 2016 This morning i stripped the PC to clean out all the dust. The only problem is i can't remember which way the rear case fan was facing. It is an Akasa fan. On one side is a foil akasa badge in the middle with nothing covering the fan blades. On the other side is a red akasa badge in the middle with like 'spider' legs blocking (if you will) access to the blades. Also on this side is the wiring for the fan. There are 2 arrows on the base of the fan. One points to the side corner where the wiring has been ran to & the other arrow points towards the side that has the 'spider legs' & the red Akasa badge. I'm just wondering which side of the fan should face OUTWARDS? Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/ Share on other sites More sharing options...
+Gary7 Subscriber² Posted September 3, 2016 Subscriber² Share Posted September 3, 2016 It is to face so that it exhausts hot air out of your PC, usually that will be with the logo on the inside of tha case. Most fans also have an arrow telling you the direction of air flow. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597569950 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted September 3, 2016 Global Moderator Share Posted September 3, 2016 The sticker side, or the grill, is the output. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597569984 Share on other sites More sharing options...
Technique Posted September 3, 2016 Author Share Posted September 3, 2016 (edited) Well either i've now installed it incorrectly (i've just put the label with the red writing to the outside) or i've had it installed incorrectly for years because the wire that connects to the motherboard is now no longer long enough (without loosening the tie). The arrow is pointing to the outside now anyway. Oh 7 i also have a front fan. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570104 Share on other sites More sharing options...
George P Global Moderator Posted September 3, 2016 Global Moderator Share Posted September 3, 2016 As far as I know, the rear fan is always pushing air out, specially if you have front fans which pull air inside. Fans on the bottom should also pull air in while fans on the top, IMO, should push air out as well, because hot air goes up. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570106 Share on other sites More sharing options...
Technique Posted September 3, 2016 Author Share Posted September 3, 2016 On 03/09/2016 at 18:58, George P said: As far as I know, the rear fan is always pushing air out, specially if you have front fans which pull air inside. Fans on the bottom should also pull air in while fans on the top, IMO, should push air out as well, because hot air goes up. Expand Yeah that's what i was thinking also. But i was at the time wondering which way around i should place the fan. Side 1 or side 2. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570112 Share on other sites More sharing options...
+Gary7 Subscriber² Posted September 3, 2016 Subscriber² Share Posted September 3, 2016 On 03/09/2016 at 19:09, Technique said: Yeah that's what i was thinking also. But i was at the time wondering which way around i should place the fan. Side 1 or side 2. Expand Your question was answered many times. The side with the logo faces in to the case the side without the logo faces towards the rear. That side blow the air out of the case. If you want to test it hold a tissue on it, it will go with the air flow. Hum 1 Share Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570308 Share on other sites More sharing options...
xendrome Posted September 3, 2016 Share Posted September 3, 2016 There are typically arrows on the plastic that show the airflow direction, but yes, air should flow from front to back. Hum 1 Share Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570312 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted September 3, 2016 Global Moderator Share Posted September 3, 2016 On 03/09/2016 at 22:54, xendrome said: There are typically arrows on the plastic that show the airflow direction, but yes, air should flow from front to back. Expand Not all, but yes most Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570316 Share on other sites More sharing options...
+Gary7 Subscriber² Posted September 3, 2016 Subscriber² Share Posted September 3, 2016 I had no idea it took so may posts to determine the direction of air flow on a case fan. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570320 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted September 3, 2016 Global Moderator Share Posted September 3, 2016 On 03/09/2016 at 23:03, Gary7 said: I had no idea it took so may posts to determine the direction of air flow on a case fan. Expand I think he just missed the point with our other information... Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570330 Share on other sites More sharing options...
Rail Grinder Posted September 3, 2016 Share Posted September 3, 2016 (edited) The arrows are actually right there on the 3rd picture above your thumb. The one pointing to the edge points to the direction of airflow, while the one pointing along the fan indicates rotation (not as important). You would want to install the fan so that the arrow points to where you want the air to flow. Optimal direction for the rear is outwards as per everyone else's suggestion. Hum 1 Share Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570332 Share on other sites More sharing options...
Hum Posted September 4, 2016 Share Posted September 4, 2016 Without looking at others posts, I always thought Rear fans sucked out heat, while a Front fan blew in air. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570450 Share on other sites More sharing options...
Rail Grinder Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 02:58, Hum said: Without looking at others posts, I always thought Rear fans sucked out heat, while a Front fan blew in air. Expand Yeah, that's the most logical and traditional airflow method. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570464 Share on other sites More sharing options...
techbeck Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 02:58, Hum said: Without looking at others posts, I always thought Rear fans sucked out heat, while a Front fan blew in air. Expand Always made sense to me considering that the PSU blows out. Anytime I built a PC (which has been a while) I always faced the rear fans out. Side fans out as well as the top fans. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570466 Share on other sites More sharing options...
DevTech Posted September 4, 2016 Share Posted September 4, 2016 My post from another thread: There is rarely such as thing as "good air flow" - most people use the term mean some sort of imaginary diagram in their head of what the air is doing but in almost every case where is gets a real world test with a heat sensor gun, the imagination is wrong because humans and air think differently. Without test equipment, the single thing completely in your power to accomplish is to aim a fan straight at the item you want to cool. With a modern mobo, it becomes trivial and most people use too many fans. 1. blow cool air from outside across cpu water radiator - in typical case, this means turning the fans around to blow the other way. 2. only in rare cases can you do anything about the typically weird GPU cooling, but when lucky give it cool air. 3. power supply comes with a fan - usually not much can be done with it 4. a case fan to blow cool outside air on mobo - usually any slow air movement is good enuff 5. a case fan to blow cool outside air on hard drives - usually any slow air movement is good enuff 6. rip out all other case fans - they typically just mess things up ------------------------------------------------------------- It is so hard to get people to wrap there head around a subject where "everybody knows" the answer. The old suck cool air in the front, blow out back myth was promoted by OEM manufacturers like Dell and HP during a time in computer history when components generated far less heat and the OEMS would also tweak the system with tight fitting cases and plastic air ducts all over the place. So since I had a recent post handy, who knows, I might help somebody consider the mythology involved: 1. Sucking air requires suction! Suction requires a completely air tight enclosure. 2. Blowing air out of the case is similar to suction. A fan blowing outwards will grab the easiest available air which is usually nearby holes in the case. A fan blowing out is just generating Noise for almost no cooling effect. 3. Even if you had completely sealed suction which NEVER happens in real life, the air can still decide to do weird things which is why in the real engineering world air flow gets TESTED. Cars, airplanes, computer cases - all the same mysteries of Fluid Dynamics and Turbulence. So if you don't own a Heat Sensor Gun, it's all just guesswork. 4. What happens if you blow air inwards instead? A) it is cool air B) you know where it is going for about 6 inches C) it has no problem finding an exit route in a typical leaky case Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570468 Share on other sites More sharing options...
DevTech Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 03:35, techbeck said: Always made sense to me considering that the PSU blows out. Anytime I built a PC (which has been a while) I always faced the rear fans out. Side fans out as well as the top fans. Expand Wow - that's a lot of fans doing nothing. Rip out all the fans blowing air out and leave the nice big air holes in their place. Most likely your temp measurements will be the same or lower and your ears will feel a liitle bit better. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570472 Share on other sites More sharing options...
DevTech Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 03:22, Rail Grinder said: Yeah, that's the most logical and traditional airflow method. Expand Traditional = Yes. Logical = No. The fault in the logic is the word "suck" - there is simply zero "suck" in a typical computer case. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570476 Share on other sites More sharing options...
+JHBrown Subscriber¹ Posted September 4, 2016 Subscriber¹ Share Posted September 4, 2016 For optimal performance, exhaust on the rear/top of the case, and intake up front. Here is the best for gaming, more FPS(Uber GPU cooling)... Hum 1 Share Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570480 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted September 4, 2016 Global Moderator Share Posted September 4, 2016 Dev, just drop it. The OP got the message, don't give him a history lesson... Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570482 Share on other sites More sharing options...
techbeck Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 03:48, DevTech said: Wow - that's a lot of fans doing nothing. Rip out all the fans blowing air out and leave the nice big air holes in their place. Most likely your temp measurements will be the same or lower and your ears will feel a liitle bit better. Expand Just one case I bought. Back when I wanted one that had blue lights and everything. Had two big fans on the front blowing air in....small fan on the back, top, and side across from the CPU fan. Fans didnt cause a lot of noise actually. And that was back when the IDE ribbon cables were a PITA the route so they did not block airflow. So helped lower the temp a little. Most cases I bought just had a couple in the front and then the back. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570484 Share on other sites More sharing options...
techbeck Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 03:56, JHBrown said: For optimal performance, exhaust on the rear/top of the case, and intake up front. This is best for gaming, more FPS(Uber GPU cooling)... Expand Geesh....guy i used to work with actually suggested this. Coworkers CPU fan died and his fix was to leave the case open and place a desktop fan to blow air on the CPU to keep it cool. Needless to say, he was not around much after. +JHBrown 1 Share Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570486 Share on other sites More sharing options...
Hum Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 03:56, JHBrown said: Expand I've done just that when the weather was hot and I had a case heating problem. I simply set a floor fan aimed in the case and let it blow in. +JHBrown 1 Share Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570490 Share on other sites More sharing options...
DevTech Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 03:56, Mindovermaster said: Dev, just drop it. The OP got the message, don't give him a history lesson... Expand Oh but that is too narrow a point of view. If I thought that the only recipient of what I type in any thread was the OP then I wouldn't be bothering with any of this. I am trying to help people for the benefit of all mankind so to speak since this information is available to the mighty Google. Of course in this particular case I have almost no chance of stemming the tide of miss-information in the old and tired "blow air in the front and suck it out the back at the top because heat rises blah de blah useless meme" Science is not about logical thinking which in this case seems to totally fail people, but instead the root of all Science is TESTING. You can use logic to form a starting hypothesis, but in the end the TESTING is the Science. Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570492 Share on other sites More sharing options...
DevTech Posted September 4, 2016 Share Posted September 4, 2016 On 04/09/2016 at 03:56, JHBrown said: For optimal performance, exhaust on the rear/top of the case, and intake up front. Here is the best for gaming, more FPS(Uber GPU cooling)... Expand If you read my posts here, your part A) does nothing But your part B) blow air right on the thing that needs cooling is exactly right and the picture is a great example of something that would actually work. If the fan has good bearings and runs at a slow speed, it will cool better and quieter than most solutions! Now spray the whole thing in lime green paint and slap a NVIDIA logo on it... Link to comment https://www.neowin.net/forum/topic/1307720-which-direction-for-rear-case-fan-to-face/#findComment-597570494 Share on other sites More sharing options...
