Link_of_Hyrule Posted January 13, 2017 Share Posted January 13, 2017 (edited) At random times the audio output will stop. The only way to fix it is to reboot or to open an elevated command prompt and run net stop AudioSrv and after that net start AudioSrv. Has anyone found a fix for this issue other than restarting the service? Please upvote this issue https://aka.ms/Kbrfi0 Link to comment https://www.neowin.net/forum/topic/1319140-audio-service-crashes-causing-audio-output-to-stop-on-build-15002/ Share on other sites More sharing options...
Circaflex Posted January 13, 2017 Share Posted January 13, 2017 Have you tried updating to 15007 yet? Link to comment https://www.neowin.net/forum/topic/1319140-audio-service-crashes-causing-audio-output-to-stop-on-build-15002/#findComment-597742406 Share on other sites More sharing options...
Link_of_Hyrule Posted January 13, 2017 Author Share Posted January 13, 2017 Nope didn't know it existed until you just posted! Awesome downloading now! Link to comment https://www.neowin.net/forum/topic/1319140-audio-service-crashes-causing-audio-output-to-stop-on-build-15002/#findComment-597742410 Share on other sites More sharing options...
Circaflex Posted January 13, 2017 Share Posted January 13, 2017 3 hours ago, Link_of_Hyrule said: Nope didn't know it existed until you just posted! Awesome downloading now! Seems like the issue might still be there for some https://www.reddit.com/r/windowsinsiders/comments/5nn3ay/announcing_windows_10_insider_preview_build_15007/dcd0uk7/ Link to comment https://www.neowin.net/forum/topic/1319140-audio-service-crashes-causing-audio-output-to-stop-on-build-15002/#findComment-597742848 Share on other sites More sharing options...
