Hitman first season issue
Besides making sure you have typed in the correct code, there is little we can do to help. Double check i's for l/1's or o's for 0's etc.
If you're 100% sure you have typed the right code, you'll need to contact IO / SE directly for a replacement.
Just now, wendy oltman said:
i didnt try that. Will contact them right now. I was so confused when my account got deleted for no reason
Perhaps contact them to see if you can get a reason, it's a bit odd for them to just remove an account.
thanks everyone for the help. I will try contacting them and will update here what happened
Just now, Andrew said:
Just a thought, but does Hitman have a "redeem code" option in the main game menu? It might be possible it's not a PSN code entered in the Store app.
its written on the paper inside the disc that it has to be put in psn store redeem code box
Ok, I haven't played it but thought it might be worth checking.
On the off chance it's an issue with the PS4 app, you could try to redeem it from the PSN account web site:
https://www.playstation.com/en-gb/get-help/help-library/store---transactions/voucher-redemption/how-to-redeem-a-voucher-code-using-playstation-app-or-web-browse/
  • Like 1
Just now, Nefarious Trigger said:
So it's an official, printed redemption code?  Cool - just thought you meant something hand written.
yes its official. i would be  incredibly stupid to trust an handwritten code :D
Thanks I would definitely try this, if i do not get a good response from the retailer
  • Like 1
59 minutes ago, wendy oltman said:
well nothing worked. Retailer said not his problem. Square Enix and PlayStation are not replying. The link given by Andrew also didn't work. Failed in getting the pack spectacularly
Have you tried contacting IO Interactive? Or even contacting IO / SE via Twitter?
  • Like 1
