LowVolt Posted March 8, 2017 Share Posted March 8, 2017 I recently bought the switch and five of the AP's for $150. I am wanting to get this gear programmed and running my network at home. I work as a AV Technician/Consultant and have very little IT knowledge compared to most people here on the forum. A lot of the equipment we install is IP but again we are just using the bare bones basics to get our gear up and running. With that said, I have gotten the switch reset to factory. I have watched a few videos on some basic things to configure on the switch. It seems like it passes internet fine but I really don't know if it set up correctly. So I moved onto the AP's. It seems like I can get them reset. https://popravak.wordpress.com/2014/08/26/resetting-cisco-capwaplwap-access-point-to-factory-defaults/ After that I am falling on my face. Just to be clear these ARE NOT the lightweight models. They are the AP1142N. I have had this gear hooked up to my combination cable modem/wifi router with the modem acting as the DHCP and the AP was getting an IP address. I tried typing in that ip address in the address bar and never get the GUI. I have also tried to set the ip address of the AP using the console port and the configure terminal command does not work. Any help would be greatly appreciated. Thank you Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/ Share on other sites More sharing options...
TPreston Posted March 8, 2017 Share Posted March 8, 2017 (edited) To get the aironet's up and running you have to have the BVI Ethernet and subinterface showing status "UP" in Show IP Int Br Check the guide here https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template After which you can use the web ui to setup the Aironet access point or Cisco Configuration Professional. LowVolt 1 Share Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818530 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 It does give me a status of "UP". There is no ip address assigned. To set the BVI1 ip address, do I need to be in Global Configurator mode using the "configure terminal" command? If yes that is one of my problems. The AP is not recognizing the "configure terminal" command. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818604 Share on other sites More sharing options...
TPreston Posted March 8, 2017 Share Posted March 8, 2017 On 08/03/2017 at 17:53, LowVolt said: It does give me a status of "UP". There is no ip address assigned. To set the BVI1 ip address, do I need to be in Global Configurator mode using the "configure terminal" command? If yes that is one of my problems. The AP is not recognizing the "configure terminal" command. Expand The IP Should usually be on the BVI here is a working example ! ! Last configuration change at 00:36:42 UTC Mon Mar 1 1993 version 15.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname SomeOrgAP1 ! ! logging rate-limit console 9 enable secret 5 ! no aaa new-model no ip routing no ip cef ip domain name SomeOrg.Local ! ! ! dot11 syslog ! dot11 ssid SomeOrg vlan 10 authentication open authentication key-management wpa version 2 guest-mode mbssid guest-mode wpa-psk ascii 7 information-element ssidl wps ! ! crypto pki token default removal timeout 0 ! ! username Admin1 secret 5 ! ! bridge irb ! ! ! interface Dot11Radio0 no ip address no ip route-cache ! encryption vlan 10 mode ciphers aes-ccm ! ssid SomeOrg ! antenna gain 0 stbc beamform ofdm mbssid station-role root ! interface Dot11Radio0.10 encapsulation dot1Q 10 native no ip route-cache bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface GigabitEthernet0 no ip address no ip route-cache duplex auto speed auto ! interface GigabitEthernet0.10 encapsulation dot1Q 10 native no ip route-cache bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface BVI1 ip address 192.168.1.11 255.255.255.0 ip helper-address 192.168.1.100 no ip route-cache ! ip default-gateway 192.168.1.1 ip forward-protocol nd ip http server no ip http secure-server ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ! bridge 1 route ip ! ! ! line con 0 line vty 0 4 login local transport input ssh ! end Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818620 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 (edited) version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname APd867.d9e1.2f9f ! logging rate-limit console 9 enable secret 5 $1$ycIE$1nBu5WabKjLD0YvRNt.Ye1 ! ! crypto pki trustpoint Cisco_IOS_MIC_cert revocation-check none rsakeypair Cisco_IOS_MIC_Keys ! crypto pki trustpoint cisco-root-cert revocation-check none rsakeypair Cisco_IOS_MIC_Keys ! crypto pki trustpoint airespace-device-root-cert revocation-check none rsakeypair Cisco_IOS_MIC_Keys ! crypto pki trustpoint airespace-new-root-cert revocation-check none rsakeypair Cisco_IOS_MIC_Keys ! crypto pki trustpoint airespace-old-root-cert revocation-check none rsakeypair Cisco_IOS_MIC_Keys ! ! crypto pki certificate chain Cisco_IOS_MIC_cert certificate 309C68F0000000041BC7 30820470 30820358 A0030201 02020A30 9C68F000 0000041B C7300D06 092A8648}}}}}}}}more of these just deleted them{{{{{{{{{ 16A9BFF5 08ECEDB3 801A5838 34B1252B 0F9D18CC quit certificate ca 6A6967B3000000000003 308204D9 308203C1 A0030201 02020A6A 6967B300 00000000 03300D06 092A8648 }}}}}}}}more of these just deleted them{{{{{{{{{ quit crypto pki certificate chain cisco-root-cert certificate ca 5FF87B282B54DC8D42A315B568C9ADFF 30820343 3082022B A0030201 0202105F F87B282B 54DC8D42 A315B568 C9ADFF30 }}}}}}}}more of these just deleted them{{{{{{{{{ quit crypto pki certificate chain airespace-device-root-cert certificate ca 03 3082047F 308203A8 A0030201 02020103 300D0609 2A864886 F70D0101 04050030 }}}}}}}}more of these just deleted them{{{{{{{{{ *Jun 18 11:38:19.854: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !! 430 2206092A 864886F7 0D010901 16157375 70706F72 74406169 72657370 6163652E 636F6D30 81DF300D 06092A86 4886F70D }}}}}}}}more of these just deleted them{{{{{{{{{ quit crypto pki certificate chain airespace-new-root-cert certificate ca 00 3082045A 30820383 A0030201 02020100 300D0609 2A864886 F70D0101 04050030 }}}}}}}}more of these just deleted them{{{{{{{{{ *Jun 18 11:38:29.855: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !! E6241198 B0E002DE 9E06D64F 0D538987 96C1C0DB 12B0F581 6FED quit crypto pki certificate chain airespace-old-root-cert certificate ca 00 30820406 3082032F A0030201 02020100 300D0609 2A864886 F70D0101 04050030 }}}}}}}}more of these just deleted them{{{{{{{{{ quit username Cisco secret 5 $1$MuuP$UXB9FwWm0hKrgr5jHE7EW1 ! ! ! interface GigabitEthernet0 ip address dhcp client-id GigabitEthernet0 no ip route-cache duplex auto speed auto no keepalive ! ! line con 0 line vty 0 4 login ! end Just to be clear I am about as Green as they come. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818648 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 Right now I have the AP hooked up to a Cisco 2960 SI PoE-24 on my desk at work trying to get to the GUI interface. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818674 Share on other sites More sharing options...
TPreston Posted March 8, 2017 Share Posted March 8, 2017 (edited) On 08/03/2017 at 19:04, LowVolt said: Right now I have the AP hooked up to a Cisco 2960 SI PoE-24 on my desk at work trying to get to the GUI interface. Expand Here is what you need to do. First unplug it from the switch and plug it into a real network. (that will eliminate the switch) Then login to the ap via ssh or console and add the following in config terminal mode. interface GigabitEthernet0.10 encapsulation dot1Q 10 native no ip route-cache bridge-group 1 interface BVI1 ip address 192.168.1.11 255.255.255.0 ip helper-address 192.168.1.100 no ip route-cache ip default-gateway 192.168.1.1 Replaceing the ips with those for your network. After you do this you should be able to access the web page for the device by putting the ip into the browser. From there you can use Cisco Configuration Professional to set things up using a GUI. LowVolt 1 Share Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818688 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 APd867.d9e1.2f9f# *Jun 18 11:56:33.965: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP. Not in Bound state. *Jun 18 11:56:42.844: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.100, mask 255.255.255.0, hostname APd867.d9e1.2f9f Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.1.99) *Jun 18 11:56:50.467: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP. Translating "CISCO-LWAPP-CONTROLLER"...domain server (192.168.1.99) *Jun 18 11:56:59.467: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER *Jun 18 11:57:08.467: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER APd867.d9e1.2f9f# This is what I get when I take a crap Linksys Wireless Router and plug it into the Cisco 2960 SI POE 24. I know that you want me to plug it into a known Working switch/network but I am unable to do so. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818716 Share on other sites More sharing options...
TPreston Posted March 8, 2017 Share Posted March 8, 2017 On 08/03/2017 at 19:27, LowVolt said: APd867.d9e1.2f9f# *Jun 18 11:56:33.965: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP. Not in Bound state. *Jun 18 11:56:42.844: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 192.168.1.100, mask 255.255.255.0, hostname APd867.d9e1.2f9f Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.1.99) *Jun 18 11:56:50.467: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP. Translating "CISCO-LWAPP-CONTROLLER"...domain server (192.168.1.99) *Jun 18 11:56:59.467: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER *Jun 18 11:57:08.467: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER APd867.d9e1.2f9f# This is what I get when I take a crap Linksys Wireless Router and plug it into the Cisco 2960 SI POE 24. I know that you want me to plug it into a known Working switch/network but I am unable to do so. Expand That looks like the output from the access point not the switch. it is looking for an access point controller. If you cant plug the AP into a working network then you should start with the switch. Look at the config there should be at least 1 vlan which you need to assign a management IP address to. The config I posted is for the same model AP1142N so if you paste it into the console port via hyperterminal it should work. Do you have the access points connected to your PC via their console ports (Serial) ? Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818740 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 Yes you are correct. Right now I am hooked up to the AP console port with the serial cable. And no I have not set up any vlan on the switch. In the first video I posted above he does something with a vlan. I am not sure if that is what you are wanting me to do. I know nothing. Step by step videos like the one posted above is all I have looked at. I am just doing what they do and not really knowing exactly what is really happening. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818756 Share on other sites More sharing options...
TPreston Posted March 8, 2017 Share Posted March 8, 2017 (edited) Well if you use hyperterminal or putty to connect to the cisco AP using the console cable and then enter config mode you can just paste in this code here The only things you need to change are the IP addresses, Access point names and passwords that you want for your home network. The switch is much easier to configure if you connect to that and enter Show Run it should give the config post that here removing any passwords and I can show what to do in order to get that setup also. I was the same when I started but this is a great way to learn. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818792 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 I cannot enter global configurator using the configure terminal or conf t command. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818808 Share on other sites More sharing options...
TPreston Posted March 8, 2017 Share Posted March 8, 2017 Ok can you paste in "show version" and hit enter then post the results here ? Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818812 Share on other sites More sharing options...
sc302 Veteran Posted March 8, 2017 Veteran Share Posted March 8, 2017 Double check that model number. Air-Lap1142n-a-k9 isn't the same as air-ap1142n-a-k9. Lap=requires controller, ap does not. TPreston 1 Share Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818832 Share on other sites More sharing options...
+John Teacake MVC Posted March 8, 2017 MVC Share Posted March 8, 2017 It sounds like you might have the "wrong" software version. If I remember rightly there are two versions. Lightweight (LWAPP I think) and Autonomous (CAPWAP) Lightweight boots up and looks for a Cisco WLC (Wireless LAN controller), Autonomous has the Web GUI of which you speak. https://learningnetwork.cisco.com/thread/14405 There are lots of good Youtube guides how to switch between the two, They are all pretty much the same. https://www.google.co.uk/search?client=ubuntu&channel=fs&q=convert+lightweight+to+autonmous&ie=utf-8&oe=utf-8&gfe_rd=cr&ei=aHjAWNqsAq3_8Af334nQCA#channel=fs&q=convert+lightweight+to+autonomous+youtube&* Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818870 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 AP44d3.cafa.ae07#show version *Jun 18 11:07:28.818: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !! AP44d3.cafa.ae07#show version Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(21a)JA2, RELE ASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2009 by Cisco Systems, Inc. Compiled Mon 02-Nov-09 18:35 by prod_rel_team ROM: Bootstrap program is C1140 boot loader BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA1, RELEASE SOFTWARE (fc1) AP44d3.cafa.ae07 uptime is 8 minutes System returned to ROM by reload System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" Last reload reason: This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable --More-- *Jun 18 11:07:38.818: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not haveto comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at:http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-AP1142N-A-K9 (PowerPC405ex) processor (revision A0) with 98294K/32 768K bytes of memory. Processor board ID FTX1532EB61 PowerPC405ex CPU at 586Mhz, revision number 0x147E Last reset from reload LWAPP image version 3.0.51.0 1 Gigabit Ethernet interface 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 44:D3:CA:FA:AE:07 Part Number : 73-12836-03 PCA Assembly Number : 800-33767-03 PCA Revision Number : A0 PCB Serial Number : FOC152822Q1 Top Assembly Part Number : 800-33775-02 Top Assembly Serial Number : FTX1532EB61 Top Revision Number : A0 Product/Model Number : AIR-AP1142N-A-K9 Configuration register is 0xF AP44d3.cafa.ae07# Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818874 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 So just an FYI. I am now at home operating on the 48 port switch and a different, but same model AP. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818878 Share on other sites More sharing options...
TPreston Posted March 8, 2017 Share Posted March 8, 2017 (edited) On 08/03/2017 at 21:34, LowVolt said: AP44d3.cafa.ae07#show version *Jun 18 11:07:28.818: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !! AP44d3.cafa.ae07#show version Cisco IOS Software, C1140 Software (C1140-RCVK9W8-M), Version 12.4(21a)JA2, RELE ASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2009 by Cisco Systems, Inc. Compiled Mon 02-Nov-09 18:35 by prod_rel_team ROM: Bootstrap program is C1140 boot loader BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA1, RELEASE SOFTWARE (fc1) AP44d3.cafa.ae07 uptime is 8 minutes System returned to ROM by reload System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" Last reload reason: This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable --More-- *Jun 18 11:07:38.818: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not haveto comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at:http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-AP1142N-A-K9 (PowerPC405ex) processor (revision A0) with 98294K/32 768K bytes of memory. Processor board ID FTX1532EB61 PowerPC405ex CPU at 586Mhz, revision number 0x147E Last reset from reload LWAPP image)version 3.0.51.0 1 Gigabit Ethernet interface 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 44:D3:CA:FA:AE:07 Part Number : 73-12836-03 PCA Assembly Number : 800-33767-03 PCA Revision Number : A0 PCB Serial Number : FOC152822Q1 Top Assembly Part Number : 800-33775-02 Top Assembly Serial Number : FTX1532EB61 Top Revision Number : A0 Product/Model Number : AIR-AP1142N-A-K9 Configuration register is 0xF AP44d3.cafa.ae07# Expand Yeah someone has loaded the controller based firmware (LWAPP image) onto it. You need to flash it with c1140-k9w7-tar.153-3.JD3.tar https://software.cisco.com/download/release.html?mdfid=282439881&flowid=6789&softwareid=284180979&release=15.3.3-JD3&relind=AVAILABLE&rellifecycle=ED&reltype=latest After you flash this image youll be able to access config mode. LowVolt 1 Share Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818894 Share on other sites More sharing options...
LowVolt Posted March 8, 2017 Author Share Posted March 8, 2017 Ok. So I need a login username and password to download the file. I guess u have to be a dealer or something. Is there anywhere else I can Download the firmware? Reveal hidden contents Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597818910 Share on other sites More sharing options...
LowVolt Posted March 11, 2017 Author Share Posted March 11, 2017 Trying to get ahold of the file or a username and password. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597821438 Share on other sites More sharing options...
+BudMan MVC Posted March 11, 2017 MVC Share Posted March 11, 2017 There are lots of places to download cisco software. The only "official" place would be cisco - and yes for some software you need to have an account that is backed by a support contract with them, or licensing, etc. LowVolt 1 Share Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597821602 Share on other sites More sharing options...
LowVolt Posted March 11, 2017 Author Share Posted March 11, 2017 Do you know any reputable ones that don't bombard my pc/phone with malware/pop-ups? Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597821674 Share on other sites More sharing options...
+BudMan MVC Posted March 12, 2017 MVC Share Posted March 12, 2017 I know quit a few places.. None of which are something that should be posted here - nor would I give them to you in PM, so don't bother.. There are few people here I have shared such info, but its clearly against this boards policy, etc. And no offense but 12 posts.. Maybe your the cisco police heheeh LowVolt 1 Share Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597821984 Share on other sites More sharing options...
LowVolt Posted March 14, 2017 Author Share Posted March 14, 2017 Well that is pretty much what I figured. Yeah you always need to question NFG'S. I should have made that my username.....Cisco 5-0. Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597824102 Share on other sites More sharing options...
LowVolt Posted April 24, 2017 Author Share Posted April 24, 2017 Can anyone help me acquire this firmware I need? Link to comment https://www.neowin.net/forum/topic/1324598-cisco-2960-si-poe-48-and-air-ap1142n-a-k9-programmed-for-a-home-network/#findComment-597871308 Share on other sites More sharing options...
