Cosmin Posted January 18, 2004 Share Posted January 18, 2004 When I'm trying to change default icons with some else on WXP after restart those default comes back :rolleyes: .. Why ? ; and what can be done .. ? [ attached an image ] Thanks , Cosmin .. Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/ Share on other sites More sharing options...
Fedorpheux Posted January 18, 2004 Share Posted January 18, 2004 how exactly are you trying to change them? Display Properties -> Desktop -> Customize Desktop ? that's how i do it and i have no problems Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/#findComment-1616884 Share on other sites More sharing options...
Cosmin Posted January 18, 2004 Author Share Posted January 18, 2004 I mean there are not saving as i customize them. Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/#findComment-1616900 Share on other sites More sharing options...
Fedorpheux Posted January 18, 2004 Share Posted January 18, 2004 Cosmin said: I mean there are not saving as i customize them. but you said "after restart those default comes back" care to explain a little more clearly and detailed? :wacko: Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/#findComment-1616946 Share on other sites More sharing options...
Dogan Posted January 18, 2004 Share Posted January 18, 2004 Do u have a Nvidia card? If so, the new drivers seems to have that problem. The icons change back to default when u restart your comp. Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/#findComment-1616955 Share on other sites More sharing options...
Cosmin Posted January 20, 2004 Author Share Posted January 20, 2004 yes (you've understood :cool: ) , I own an nvidia card .. but what can be done ? [ drivers installed 53.03 ] Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/#findComment-1625993 Share on other sites More sharing options...
BroChaos Veteran Posted January 20, 2004 Veteran Share Posted January 20, 2004 i had to revert back to some 4x.xx drivers. Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/#findComment-1626009 Share on other sites More sharing options...
uniacidz Posted January 20, 2004 Share Posted January 20, 2004 Or change them manually via hackin the Shell32 and Explorer.exe. Welcome to some nvidia annoyances with their drivers. Link to comment https://www.neowin.net/forum/topic/133123-wierd-problem/#findComment-1626029 Share on other sites More sharing options...
