myxomatosis Posted August 21, 2017 Share Posted August 21, 2017 Hi guys, just wanted to be sure I'm not alone with that bug. I installed the Insider Preview (build 16251) from the Slow Ring yesterday and everything went smoothly (better than I expected compared to the insider builds I tried some months ago that were way mode buggy and unstable) The only more annoying issue I noticed: The sound volume in Edge is way way lower than in other browsers (tested on Vivaldi, Chrome and Firefox). By lower volume, I mean it's probably 25% lower if not more, and it lacks some depth/bass. Youtube, Plex, Dailymotion, etc. are all affected. For the record, I'm using a i7 Surface Pro 4. Eveything is OK in the "Volume Mixer" with Edge slided set at 100%. Re-installing the sound card drivers didn't help. Are you noticing the same problem? Link to comment https://www.neowin.net/forum/topic/1340158-insider-preview-build-16251-slow-ring-sound-issue-with-edge/ Share on other sites More sharing options...
