patseguin Global Moderator Posted October 17, 2017 Global Moderator Share Posted October 17, 2017 We run Windows Server 2008 at work with 5 workstations on an AD domain. We run things like a Filemaker Pro database and some embroidery design software that runs on SQL server. The odd issue is that every night at midnight, the Filemaker Pro connection is interrupted and I have to restart it and so is the SQL based embroider database. This has seemingly only started happening in the last couple of months and we have been running this system for years. What could possibly be causing a time-based interruption in database connections like that? Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/ Share on other sites More sharing options...
sc302 Veteran Posted October 17, 2017 Veteran Share Posted October 17, 2017 Nic driver, some form of power saving, possible network congestion from backup. Check your event logs. See if there is an event around the time of drop. System and application events. Mando 1 Share Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067624 Share on other sites More sharing options...
patseguin Global Moderator Posted October 17, 2017 Author Global Moderator Share Posted October 17, 2017 1 hour ago, sc302 said: Nic driver, some form of power saving, possible network congestion from backup. Check your event logs. See if there is an event around the time of drop. System and application events. I went to device manager for the NIC on the server and disabled the option to allow power management to turn it off. Could that really be it? We'll see tomorrow I guess! Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067734 Share on other sites More sharing options...
sc302 Veteran Posted October 17, 2017 Veteran Share Posted October 17, 2017 All servers. Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067736 Share on other sites More sharing options...
patseguin Global Moderator Posted October 17, 2017 Author Global Moderator Share Posted October 17, 2017 2 minutes ago, Riva said: It could be your SQL backup software locking it up during the backup operation. Getting a disconnect issue with Filemaker too though... Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067754 Share on other sites More sharing options...
GrayW Posted October 17, 2017 Share Posted October 17, 2017 Was there anything in the event logs like @sc302 suggested? Does Filemaker keep logs? When in doubt, dive into your log files! Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067758 Share on other sites More sharing options...
xendrome Posted October 17, 2017 Share Posted October 17, 2017 So you are having to restart services to get it back up and running? Doesn't sound like a LAN issue, sounds like a process hanging or crashing. Have you run a chkdsk /f on that data volume and restarted the OS? Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067776 Share on other sites More sharing options...
+BudMan MVC Posted October 17, 2017 MVC Share Posted October 17, 2017 So what services are you restarting? The sql service.. Yeah not sounding like a network issue. When the service goes down can you ping the servers IP? Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067834 Share on other sites More sharing options...
patseguin Global Moderator Posted October 17, 2017 Author Global Moderator Share Posted October 17, 2017 I don't have to restart any services. I'll see a message on my workstations that it lost connection to Filemaker sever and the sql server. I just close the programs on the workstations (Filemaker Pro and Wilcom Design Workflow) and reopen them and it is fine. It's not a major issue, just annoying every morning having to do that. Not sure why it seems to be a time related thing that seems to happen at midnight every night. Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067856 Share on other sites More sharing options...
xendrome Posted October 17, 2017 Share Posted October 17, 2017 So check the power options on the NICs of the workstatons, make sure Energy Efficient Ethernet isn't turned on. And obviously that the workstations aren't going to sleep/hibernate. Wouldn't hurt to update the NIC driver on the workstations. Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598067860 Share on other sites More sharing options...
+BudMan MVC Posted October 17, 2017 MVC Share Posted October 17, 2017 So all the workstations do this? Are they wired or wireless? What is your dhcp lease time? Possible have a bit of a issue and not renewing their lease have to go to discover mode which could cause a blip in the network. Comes down to how sensitive these applications are to slight little blip.. Sometimes network connectivity coming out of standby can be a problem - especially if wifi, etc. Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598068050 Share on other sites More sharing options...
patseguin Global Moderator Posted October 20, 2017 Author Global Moderator Share Posted October 20, 2017 On 10/17/2017 at 3:49 PM, BudMan said: So all the workstations do this? Are they wired or wireless? What is your dhcp lease time? Possible have a bit of a issue and not renewing their lease have to go to discover mode which could cause a blip in the network. Comes down to how sensitive these applications are to slight little blip.. Sometimes network connectivity coming out of standby can be a problem - especially if wifi, etc. I feel like a complete moron. Just checked the problem PC's (Windows 10) and they are set to go to sleep after 4 hours... +BudMan, goretsky, upnorth and 1 other 2 2 Share Link to comment https://www.neowin.net/forum/topic/1345434-odd-lan-issue/#findComment-598071266 Share on other sites More sharing options...
