Elliot B. Posted January 11, 2018 Share Posted January 11, 2018 I have a Xenta VT-S205 1080p upscaling DVD player. It was purchased in December 2013 for £15 from Ebuyer. It hasn't been used in many years. I plugged it in today (via. several different HDMI cables) into a Samsung UE46ES5500 TV (a 2012 model). I've also tried two other HD TVs. All DVDs appear extremely pixelated. As in, below the standard DVD-Video resolution of 576p. They appear to be playing in half resolution. There aren't many settings to change but those that do exist are all set correctly: Aspect Radio: 16:9 View Mode: Original (not Pan & Scan or Zoom) TV System: PAL (I tried NTSC, just in case) Video Out: HDMI HD Resolution: 1080p (I've tried 1080i also) Anyone heard of anything like this happening before and what could be causing it? Link to comment https://www.neowin.net/forum/topic/1353154-upscaling-1080p-dvd-player-running-dvds-at-half-resolution/ Share on other sites More sharing options...
+InsaneNutter MVC Posted January 28, 2019 MVC Share Posted January 28, 2019 If you read the reviews for that DVD player quite a few do complain the picture is "grainy and pixelated". £15 seems incredibly cheap for a DVD player, I guess it's just luck of the draw if it actually ends up been any good unfortunately. Link to comment https://www.neowin.net/forum/topic/1353154-upscaling-1080p-dvd-player-running-dvds-at-half-resolution/#findComment-598412583 Share on other sites More sharing options...
Elliot B. Posted January 28, 2019 Author Share Posted January 28, 2019 10 minutes ago, InsaneNutter said: If you read the reviews for that DVD player quite a few do complain the picture is "grainy and pixelated". £15 seems incredibly cheap for a DVD player, I guess it's just luck of the draw if it actually ends up been any good unfortunately. Hold thread revival, Batman! I ended up throwing it away, in the end. Link to comment https://www.neowin.net/forum/topic/1353154-upscaling-1080p-dvd-player-running-dvds-at-half-resolution/#findComment-598412585 Share on other sites More sharing options...
+Eternal Tempest MVC Posted January 28, 2019 MVC Share Posted January 28, 2019 The PS3 up-converts dvd, if you have one of those lying around. Link to comment https://www.neowin.net/forum/topic/1353154-upscaling-1080p-dvd-player-running-dvds-at-half-resolution/#findComment-598412586 Share on other sites More sharing options...
Jason S. Global Moderator Posted January 28, 2019 Global Moderator Share Posted January 28, 2019 looks like this thread has founds its solution. closing. Link to comment https://www.neowin.net/forum/topic/1353154-upscaling-1080p-dvd-player-running-dvds-at-half-resolution/#findComment-598412587 Share on other sites More sharing options...
