jnelsoninjax Posted November 13, 2018 Share Posted November 13, 2018 First of all I am not 100% sure where to post this, but web browser made the most sense. The issue is I am using a pair of Cowin E7 bluetooth noise cancellation headphones and watching Netflix and I am noticing that the audio at times seems slightly out of sync, by perhaps a second at most, but noticeable none the less. My system, AMD Ryzen 7 2700X 3.7Ghz, 32 GB's ram, and the motherboard is an Asus ROG Crosshair VII Hero with build-in bluetooth support. My ISP is Comcast with speeds showing 175/11 so speed is not the issue. Any thoughts on this would be appropriated. Link to comment https://www.neowin.net/forum/topic/1376425-netflix-in-ff-6301-on-bluetooth-headphones-audio-slightly-out-of-sync/ Share on other sites More sharing options...
Circaflex Posted November 13, 2018 Share Posted November 13, 2018 Does this issue happen if you use Edge or Chrome? Are you using the latest bluetooth drivers available? Link to comment https://www.neowin.net/forum/topic/1376425-netflix-in-ff-6301-on-bluetooth-headphones-audio-slightly-out-of-sync/#findComment-598386635 Share on other sites More sharing options...
jnelsoninjax Posted November 13, 2018 Author Share Posted November 13, 2018 8 hours ago, Circaflex said: Does this issue happen if you use Edge or Chrome? Are you using the latest bluetooth drivers available? Have not checked in other browsers. Yes drivers are up to date. Link to comment https://www.neowin.net/forum/topic/1376425-netflix-in-ff-6301-on-bluetooth-headphones-audio-slightly-out-of-sync/#findComment-598386736 Share on other sites More sharing options...
HoochieMamma Posted November 13, 2018 Share Posted November 13, 2018 Narrow it down, check other browsers, check if it happens with different headphones, check with a different computer with the same bluetooth heqadphones etc so you know where to focus your attention. Link to comment https://www.neowin.net/forum/topic/1376425-netflix-in-ff-6301-on-bluetooth-headphones-audio-slightly-out-of-sync/#findComment-598386737 Share on other sites More sharing options...
