tarifa Posted September 18, 2019 Share Posted September 18, 2019 hello dear experts I am currently working on a little project -code to use on a ESP 32 - generated with PlatformIO/VScode the question is: how to upload the code to the ESP32 (connected to the computer using USB) but the question is: there i need to find how to select the right USB port to upload the code. i need to specify an 'upload_port' for environment or i might go and use global '--upload-port' option. **How can I upload my code?** Well again; i think that it is pretty important to find the USB port: i have to use WindowsKey-X, and then i need to select Device Manager, afterward i have plug in the device and observe what's listed under Ports (COM & LPT) in other words; i will have plug in the device and observe what's listed under Ports the one that just appeared has the port in brackets (COMn). regarding the usage of PlatformIO in platformio.ini - the ini-file in our PlatformIo i need to initialise the project folder,i guess that i have to specify the port as a line under the platform section (env: square brackets line): here i have to set & configure the upload_port = comX,Y,Z or whatever we got from our Device Manager. Link to comment https://www.neowin.net/forum/topic/1387221-upload-little-project-code-to-use-on-a-esp-32-generated-with-platformiovscode%C2%A0/ Share on other sites More sharing options...
