lastpass help
5 answers to this question
Moved to Software Discussion and Support
For the mobile app,
1. Tap the hamburger menu
2. Settings
3. Autofill
4. App settings
5. Tap the app (Uber for example)
6. Select Do not show fill windows.
There should be something similar for the browser extension
https://www.neowin.net/forum/topic/1397385-lastpass-help/#findComment-598562071
2 hours ago, SnoopZ said:
For the browser extension on a PC i believe you can find what you're looking for here.
1. Tap Lastpass icon
2. Account options
3. Extension preferences
4. Notifications
Thx for that but i meant to say for single sites, not all. My bad. Sorry. :)
https://www.neowin.net/forum/topic/1397385-lastpass-help/#findComment-598562134
Maybe this is what you're looking for but I've not tested it.
https://support.logmeininc.com/lastpass/help/disable-lastpass-for-specific-sites-lp040006
https://www.neowin.net/forum/topic/1397385-lastpass-help/#findComment-598562138
Register a new account
Sign in
