oksiweles84 Posted November 20, 2020 Share Posted November 20, 2020 Hi experts, I have an iphone 11 and am having problems with making calls after updating to ios 14. The calls do not flash on my screen, and when I click on the side button, the call hangs up. I did not have this problem before updating the OS. I have no issues with other messaging apps, and have taken to using FB messenger to make voice calls, as it works much better then the telephone. I know other people have had this problem - is there an easy solution? The phone works well otherwise and I don't have display issues, just when I am on a phone call. I don't ever remember the side button hanging up calls on my other iphones, especially not on the iphone 11 where I need to lock it before putting it in my pocket on a call so I don't accidentally butt dial someone else. I sort of expect that this will be magically fixed in an update, but very frustrating to update and suddenly have a key function of the iphone - the actual phone bit! - suddenly not work as it used to. Link to comment https://www.neowin.net/forum/topic/1402512-problems-with-telephone-calling-on-ios14/ Share on other sites More sharing options...
Steven P. Administrators Posted November 20, 2020 Administrators Share Posted November 20, 2020 I don't have an iPhone but maybe some of these solutions will help? https://www.quora.com/How-do-I-disable-end-call-with-the-power-lock-button-feature-on-an-iPhone Link to comment https://www.neowin.net/forum/topic/1402512-problems-with-telephone-calling-on-ios14/#findComment-598604302 Share on other sites More sharing options...
Brandon H Supervisor Posted November 20, 2020 Supervisor Share Posted November 20, 2020 I have an iPhone XR that I recently updated to iOS 14 as well and have not experienced those issues. The update may not have installed correctly for you so I'd highly recommend a backup and restore be done on the device to see if that helps correct it. Link to comment https://www.neowin.net/forum/topic/1402512-problems-with-telephone-calling-on-ios14/#findComment-598604396 Share on other sites More sharing options...
Register a new accountSign in
