ionut.zegrean Posted April 26, 2021 Share Posted April 26, 2021 Hello everyone, we all know there are some problmes with these boards, maybe someone can help me to solve the problem. So after power button/switch is pressed in the left up corner of the monitor screen apears this underline mark: "_" that blinks for 20-25 seconds while on the mother board a red led near ram for VGA blinks for the same period of time, after that the underline on the screen at the same time with the led near ram memory for VGA both disappear and the bios begin to boot/post. Every change or update made in bios ( I have latest update), does not change this 20+ seconds before post/boot. During this time any bios setup cannot make sense because during this time the bios does not post/boot. From what I understand the board makes some check for videocard or I dont know what but just after this period the check beeps meaning ok test is done and then the boot/post process begins. Any Ideas? Do you have or had same issue? The videocard is Nvidia quadro 2000 and I use Display Port cable which came whit the Dell Monitor. The card only has DP and DVI outputs, no HDMI, could this be linked to DP port/cable? Thanks you very much ! Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/ Share on other sites More sharing options...
Steven P. Administrators Posted April 26, 2021 Administrators Share Posted April 26, 2021 After doing a quick search it seems that the biggest complaint about this board is the slow boot up. Is there no Fast Boot option in the BIOS? The fact is that most motherboards have the "old way" of booting which means the BIOS checks everything first before booting, you can override some checks by enabling "Fast Boot" in the BIOS. Another search shows that if you have v1.5 BIOS update it should make it quicker to boot, but I would first check you aren't letting the BIOS do a bunch of checks before booting. Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640314 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted April 26, 2021 Global Moderator Share Posted April 26, 2021 ^ Yeah, Fast Boot will help. Get the latest BIOS and get better. Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640328 Share on other sites More sharing options...
ionut.zegrean Posted April 26, 2021 Author Share Posted April 26, 2021 Fast boot is enabled but all bios settings come alive only when posting after that 25 seconds of VGA led blink. First the mobo makes that check blinking the VGA led before boot/post time. During this time you cannot enter bios settings. Second it runs the bios boot/post and the bios comes alive and only now I can enter setup. After booting windows come alive. Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640375 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted April 26, 2021 Global Moderator Share Posted April 26, 2021 Can you test this with a spare GFX card or just use onboard? Most likely there is something stopping Boot Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640387 Share on other sites More sharing options...
Steven P. Administrators Posted April 26, 2021 Administrators Share Posted April 26, 2021 Yeah I wonder if the BIOS is being set to use the GPU because that is also a BIOS setting, use onboard gfx or PCIe slot (GPU) it could help to check. Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640394 Share on other sites More sharing options...
+Zlip792 MVC Posted April 26, 2021 MVC Share Posted April 26, 2021 Newer GPU includes UEFI support rather than BIOS. I think your GPU does not support UEFI (at least as per TPU repository) and your motherboard BIOS is not able to handle it gracefully as a result you are getting slow 20+ seconds lag. Steven P. 1 Share Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640399 Share on other sites More sharing options...
ionut.zegrean Posted April 26, 2021 Author Share Posted April 26, 2021 Zlip792 you might be right. I should check with another videocard because the CPU doesn`t include graphics onboard. Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640426 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted April 26, 2021 Global Moderator Share Posted April 26, 2021 On 26/04/2021 at 18:32, Zlip792 said: Newer GPU includes UEFI support rather than BIOS. I think your GPU does not support UEFI (at least as per TPU repository) and your motherboard BIOS is not able to handle it gracefully as a result you are getting slow 20+ seconds lag. Expand Well, if his motherboard doesn't support UEFI, that really doesn't matter. I looked at it online, and it doesn't look like it supports UEFI. Link to comment https://www.neowin.net/forum/topic/1407309-msi-b350-tomahawk-takes-20-seconds-before-starts-to-postboot-while-vga-led-blinks/#findComment-598640427 Share on other sites More sharing options...
Register a new accountSign in
