Difference in performance on USB-C from an USB-hub; connection via adapter USB3.1-to-USB-C or direct connection
I'm having an Anker 4-port USB 3.0 Ultra Slim Data Hub (USB 3.1) (causing interference with my mouse).
I can connect the USB-hub to an adapter USB3.1 to USB-C (see pic with the 'B') and plug it in my computer, and have the USB-dongle for my mouse be in the generic USB 3.1 port.
My question performance wise (and maybe even also 'power wise'): is it better to have a "native" USB-C type usb-hub? Or can I also use an adapter from USB-C to USB 3.1 and have the same performance?
I would like to have this USB-hub powerless/no power supply.
In case of a direct connection a new USB-hub has to be bought by me (like e.g. this Satechi as attached)
The difference is negligible as long as the adapter is the same speed/usb version as what is plugging into it.
OK. So USB3.1 device/hub into this adapter still brings it (down) to USB3.1. I get that ;)
So, technically it's better to have a 100% USB-C usb-hub, like e.g. the Satechi I posted here).
The devices connected to, determine the actual speed/throughput. But USB-C has a higher bandwidth, so technically my connected HDD and running device (when connected) can operate on full speed....
USB-C doesn’t have a higher bandwidth if it’s backed by the same tech as the USB-A ports. It’s just a different connector at that point.
I see that "A USB-C port equipped with Thunderbolt 3 can push data speeds to a theoretical limit of 40Gbps. To show how far we've come, that's four times faster than USB 3.1"
So, maybe even when connecting USB3.1 (10Gbps) the 'internals' of the USB-hub are I guess "more equipped" to handle these speeds.
("simplified": 4 USB 3.1 devices of 10Gbps = 40 Gbps; instead of a USB3.1 USB-hub which gives more or less 2.5 Gbps (maybe maxed out to 5Gbps) if not all are on full load per port (10Gbps/4 ports is this 2.5Gbps)
Or does this kinda tech in usb-hubs work differently?
Nah.
The controller is what matters here. If all of your controllers are USB 3.1, you get the same bandwidth regardless of connector type. If your USB-C is Thunderbolt, then thats different.
On 30/07/2021 at 17:34, adrynalyne said:
Nah.
The specs on Satechi's site lists: "CONNECTOR TYPE Type-C, Thunderbolt 3 Compatible"
Than the question... is my notebook Thunderbolt 3 Compatible?! Have to look that one up ;)
Not from what I saw.
You're right on that one. The manual states: USB 3.1 Gen 2 Type-C, transfer rate up to 10 Gbps.
So... I can just use this adapter than?! And safe myself almost a 100 bucks.
So... I can just use this adapter than?! And safe me almost a 100 bucks.
You can; but if you run out of power for the devices or see malfunctions due to lower power, you will know why.
Yeah I know (mouse issues). But this one is not on the same USB-ports input on my mobo.
So, (hopefully) the internal power relay to these USB ports (type A & type C) are different... and therefore causing -probably- less issues.
Regarding your mouse interference ... nothing to do with the power on the A or C ports. 5 and 10 Gbps USB speeds  generate a lot of RF energy in the 2.4GHz spectrum. Poor shielding on devices or having these 5/10Gbps devices operating very close to a 2.4GHz receiver will cause issues. Physically separate them.
https://www.intel.com/content/dam/www/public/us/en/documents/white-papers/usb3-frequency-interference-papers.pdf
On 30/07/2021 at 18:01, jasondefaoite said:
Thx.
So, my assumption could be correct as the 2.4Ghz dongle is place next to the USB-port of the USB-hub, and hence the interference.
And... using a completely different (USB-C) port on another side of the notebook making the distance larger and, therefore, causing less interference due to the distance between the plugged in 2.4Ghz receiver and the via USB-connected usb-hub.
Image taken from page 9 of this white paper.
  • Like 1
When I had my Logitech unifier wireless dongle, it never worked correctly in the back port, so what I did is I got a 6ft USB extension cable, plugged it in the same port and then ran the wire and taped it to the back of my screen, mouse and keyboard worked great after that.
  • Like 1
  • Haha 1
I looked up an overview of this Asus GL731V notebook, and came across this video.
The image a still from it.
Looks like the connectors are wired to a different part of/on the motherboard, so with the usb-hub plugged into the USB-C port (above in picture), and the mouse-dongle in the 'regular' USB (part of the port-of-3) (right-side op picture)  I think I'm better off...
Register a new account
Sign in
