tarifa Posted January 19, 2022 Share Posted January 19, 2022 good day dear friends on Neonwin, I want to make a simple ph meter and display the ph value on an OLED/LCD display. I think I can learn a lot from this project; Something about the construction and functioning of the pH sensor. Last but not least - if the system has to be calibrated (which I don't necessarily "have to" have - then I would just "take it with me". Then I learn the calibration method that determines the accuracy and accuracy of the sensor. But - as I said: actually I would like to get around the calibration. If that's possible. the options: a. DFRobot Gravity Analog pH Sensorb. EZO TM class embedded pH circuit: This is an ... - TI E2 by : The Atlas Scientific EZO™ btw: I note that the Atlas Scientific EZO has a pH resolution of +/-0.002 - well i do not really need that high resolution!!! So i guess that i have to choose the DFRoboat Gravity but here the comparison: which one is the best one!? to test water, Coffee, Tea, and so on (beverages) see the both examples:https://eckstein-shop.de/DFRobotGravityAnalogpHSensor2FMeterKitForArduino DFRobot Gravity Analog pH Sensor / Meter Kit For Arduino 30,26 € Hersteller: DFRobot overview: Aquakultur: ANALOG PH-SENSOR / METERSPEZIFIKATION Modulpower : 5.00V Modulsize : 43 x 32mm(1.69x1.26") range :0 - 14PH temperature: 0 - 60 °C accurate ph-readings : ± 0.1pH Reaction : < 1min pH-Sensor with BNC-connector EZO TM class embedded pH circuit This is an ... - TI E2E The Atlas Scientific EZO™ class pH circuit, has a flexible calibration protocol, allowing for single point, two point, or three point calibration. The other two ...https://www.amazon.com/Atlas-Scientific-Embedded-Circuit-001-14/dp/B00641R1PQFeatures • Full range pH reading from .001 to 14.000 • Accurate pH readings down to the thousandths place (+/- 0.02) • Temperature dependent or temperature independent readings • Flexible calibration protocol supports single point, 2 point, or 3 point calibration DescriptionThe Atlas Scientific™ EZO™ class embedded pH circuit, is our 6th generation embedded pH circuit. This EZO class pH circuit, offers the highest level of stability and accuracy. With proper configuration the EZO class pH circuit, can meet, or exceed the accuracy and precision found in most bench top laboratory grade pH meters. The pH-EZO™ pH circuit, can work with any off-the-shelf pH probe/ sensor/electrode. This device reads pH from a pH probe/sensor/electrode. This device does not include a pH probe/sensor/electrode.btw: i think i will stick to the b.- the Atlas Scientific™ EZO™ class embedded pH circuit i look forward to hear from you So here's a schematic drawing in advance - how I imagine it Glass-Electrode RG +-----------------+ +--------------------+ -------------------------| | | | +------------------------+ | mv-Amplifier | | | | | | | | a/d-converter | | microprocessor | |---- | |-----------------------| ---------------------------| | | | | | | | | | | | | | | | | | | +-----------------+ | +--------------------+ | | | | +------------------------+ | | | | | | - | +--+ | | | | | | |r1| r1 | | - | | | | +--+ | --------------------------------- | +---------------------+ | | | +--+ | | | | r2 | Display | | | | | Referenc-electrode | | | | --------------- +--+ +---------------------+ | | | | -------- ------ Further steps: i think about the interface: a. Arduino b. raspberryPi c. ESP 32 /8266 ....!? i will create a Frizzing plan : where i take care for the periphery . power supply . Display . resistors, capacities etc. etx . OP-AMP etc. etx. BTW; see more infos : https://eckstein-shop.de/DFRobotGravityAnalogpHSensor2FMeterKitForArduino Kalibrierung: vgl. https://community.dfrobot.com/makelog-308048.html cite: in this video is an overview and tutorial for an analog pH sensor that's >compatible with both Arduino and Raspberry Pi but I'll also give a general >overview of linear functions and interpolation. Plus I'll show you how to >write a custom code to use this sensor on an unsupported platform >(Espruino). Measuring pH is pHun! (...I'm here all night folks.) /* DF Robot Analog pH Sensor */ https://www.dfrobot.com/product-1782.html Arduino Library: https://github.com/DFRobot/DFRobot_PH Python Library: https://github.com/DFRobot/DFRobot_PH/tree/master/RaspberryPi/Python /* DF Robot ADC Converter */ https://www.dfrobot.com/product-1730.html I look forward to hear from you Link to comment https://www.neowin.net/forum/topic/1414737-ph-sensors-dfrobot-vs-atlas-ezo-class-embedded-ph-circuit-for-some-demo-settings-demonstration-of-ph/ Share on other sites More sharing options...
FrankenSter Posted January 23, 2022 Share Posted January 23, 2022 Good to know what you want to do. Since you found the parts and got alot of links to read what do you want here? Should we read everything for you and tell you how to build it? What're you asking? Want to know which is better? Read the specs and find out. Link to comment https://www.neowin.net/forum/topic/1414737-ph-sensors-dfrobot-vs-atlas-ezo-class-embedded-ph-circuit-for-some-demo-settings-demonstration-of-ph/#findComment-598706320 Share on other sites More sharing options...
Register a new accountSign in
