Pedro3 Posted July 23, 2022 Share Posted July 23, 2022 Hello... Finally I left Windows and enter the world of Linux, installed Linux Mint and I'm loving it One of the problems of the migration is that I've thousands of pictures in an external drive that was being used in Windows, in Windows I would put comments in each picture, in Mint, those comments show up in EXIF - Windows Comment. I wanted that Windows Comment to show up in the Comments of the picture, since if its only in EXIF Windows Comment, the search can't find it Is there a terminal command to copy the Windows Comment to the "normal" comment ? Thanks ! Link to comment https://www.neowin.net/forum/topic/1419981-copy-exif-comment-into-comment/ Share on other sites More sharing options...
Mindovermaster Global Moderator Posted July 23, 2022 Global Moderator Share Posted July 23, 2022 Try using this: https://www.geeksforgeeks.org/installing-and-using-exiftool-on-linux/ Not sure what exactly you mean, though.. Link to comment https://www.neowin.net/forum/topic/1419981-copy-exif-comment-into-comment/#findComment-598749244 Share on other sites More sharing options...
Pedro3 Posted July 23, 2022 Author Share Posted July 23, 2022 On 23/07/2022 at 14:38, Mindovermaster said: Try using this: https://www.geeksforgeeks.org/installing-and-using-exiftool-on-linux/ Not sure what exactly you mean, though.. Thanks, going to see it. Open Pix App, click on any .jpg with the Right Mouse Button, the last option will be "Comment", in there you can put a Description, I wanted to copy that EXIF windows comment to that Description. Pix can see the EXIF Windows comment, but can't search it. I tried to find another app to search that EXIF Windows Comment, but no luck Link to comment https://www.neowin.net/forum/topic/1419981-copy-exif-comment-into-comment/#findComment-598749324 Share on other sites More sharing options...
Pedro3 Posted July 26, 2022 Author Share Posted July 26, 2022 YES, finally, a solution ! Thanks to Phil Harvey, the creator of ExifToolhttps://exiftool.org/forum/index.php?topic=13773.0 Mindovermaster 1 Share Link to comment https://www.neowin.net/forum/topic/1419981-copy-exif-comment-into-comment/#findComment-598749643 Share on other sites More sharing options...
Register a new accountSign in
