Joni_78 Posted May 8, 2023 Share Posted May 8, 2023 (edited) Is it possible to disable blinking power button light when computer is in the sleep mode? Also is it possible to completely disable leds from the motherboard? My motherboard is ASRock x570 Taichi. At night these are really bright so I would like to disable those completely. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/ Share on other sites More sharing options...
trek Posted May 8, 2023 Share Posted May 8, 2023 unplug the leds from to mobo headers Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818835 Share on other sites More sharing options...
Joni_78 Posted May 8, 2023 Author Share Posted May 8, 2023 (edited) On 08/05/2023 at 06:43, trek said: unplug the leds from to mobo headers Expand I would like to keep the light when computer is on. Just disable it in sleep mode because it is so bright at nights. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818836 Share on other sites More sharing options...
Skyfrog Posted May 8, 2023 Share Posted May 8, 2023 I don't know of any way to selectively turn it off unless there's an option in the BIOS, and I've never seen one that has that. As far as I know the only way would be to completely shut it down instead of putting it to sleep. Of course the easiest option would probably be to simply cover it at night, maybe set a book on it or something. Personally I can't stand lights of any kind at night so I just unplug all of my case LEDs, and a small piece of black electric tape to cover the TV standby LED, router LEDs, etc. Thrackerzod 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818840 Share on other sites More sharing options...
Steven P. Administrators Posted May 8, 2023 Administrators Share Posted May 8, 2023 Disable the ERP option in the BIOS (Energy-related Products). Press [System Setting] on the [User Setting Menu] screen, and then press [Power Save Setting] and [ErP Setting] in sequence. Select the desired time button. Select [Do Not Switch] to deactivate this function. ERP allows certain components to still have power even when the computer is off. When ERP is disabled you will not be able to "Wake on LAN" or charge a phone in one of the USB ports (while the PC is off) I discovered this lovely function after seeing that my Razer keyboard's RGB would stay on even after I had shut down my PC. If that doesn't work, you might have to get used to switching the PC off at the back (which is the same thing as disabling ERP). Edit: after further searching, this should also work for you: In Windows under Settings -> System -> Power -> Additional Power Settings -> Choose what the power buttons do -> Turn on fast startup. Make sure that is UNTICKED. +Dick Montage, Joni_78, hellowalkman and 3 others 2 1 3 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818845 Share on other sites More sharing options...
Graham48 Posted May 8, 2023 Share Posted May 8, 2023 Yes, it is usually possible to disable the blinking power button light when a computer is in sleep mode. However, the specific method for doing so can vary depending on the manufacturer and model of your computer or motherboard. Regarding the LEDs on your ASRock x570 Taichi motherboard, it is also possible to disable them. The exact steps for doing so may vary depending on your specific motherboard and the version of the BIOS that you are running. One possible method for disabling the LEDs on your motherboard is to enter the BIOS settings and look for an option related to LED control. Some motherboards have a specific setting for disabling all LEDs, while others may allow you to control the brightness or color of individual LEDs. If you are not comfortable making changes to the BIOS settings on your own, it may be a good idea to consult the documentation for your motherboard or to seek assistance from a computer technician. Joni_78 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818847 Share on other sites More sharing options...
Joni_78 Posted May 8, 2023 Author Share Posted May 8, 2023 On 08/05/2023 at 07:56, Steven P. said: Disable the ERP option in the BIOS (Energy-related Products). Press [System Setting] on the [User Setting Menu] screen, and then press [Power Save Setting] and [ErP Setting] in sequence. Select the desired time button. Select [Do Not Switch] to deactivate this function. ERP allows certain components to still have power even when the computer is off. When ERP is disabled you will not be able to "Wake on LAN" or charge a phone in one of the USB ports (while the PC is off) I discovered this lovely function after seeing that my Razer keyboard's RGB would stay on even after I had shut down my PC. If that doesn't work, you might have to get used to switching the PC off at the back (which is the same thing as disabling ERP). Edit: after further searching, this should also work for you: In Windows under Settings -> System -> Power -> Additional Power Settings -> Choose what the power buttons do -> Turn on fast startup. Make sure that is UNTICKED. Expand Thank you, I'll try this when I get home. Steven P. 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818853 Share on other sites More sharing options...
Jim K Global Moderator Posted May 8, 2023 Global Moderator Share Posted May 8, 2023 The only way (afaik) to stop it blinking is to either: 1) power off 2) S4 sleep state (hibernate) When you are in a low power state it will blink...nothing you can do about it. Joni_78 and hellowalkman 1 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818874 Share on other sites More sharing options...
WiltshireHam Posted May 8, 2023 Share Posted May 8, 2023 Um, am I being thick? why not just turn it off at the socket? does it really take that long to power up? Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818890 Share on other sites More sharing options...
Joni_78 Posted May 8, 2023 Author Share Posted May 8, 2023 On 08/05/2023 at 11:38, WiltshireHam said: Um, am I being thick? why not just turn it off at the socket? does it really take that long to power up? Expand Socket is hard to reach. PSU switch is behind the aluminium enclosure. This is a Media Center PC so it needs to wake up for scheduled recordings. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818899 Share on other sites More sharing options...
+Warwagon MVC Posted May 8, 2023 MVC Share Posted May 8, 2023 On 08/05/2023 at 12:12, Joni_78 said: Socket is hard to reach. PSU switch is behind the aluminium enclosure. This is a Media Center PC so it needs to wake up for scheduled recordings. Expand When you put the computer to sleep at night, just take a bottle lid, and put it over the power button ... Fixed! No more blinky Binky! Xenon, Mindovermaster, spikey_richie and 2 others 4 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818915 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted May 8, 2023 Global Moderator Share Posted May 8, 2023 (edited) On 08/05/2023 at 13:22, Warwagon said: When you put the computer to sleep at night, just take a bottle lid, and put it over the power button ... Fixed! No more blinky Binky! Expand Cute.. I always put a peice of tape over it.. Or use a Sharpie lightly over it. Won't maker it black, but it will dim the light. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818935 Share on other sites More sharing options...
+Warwagon MVC Posted May 8, 2023 MVC Share Posted May 8, 2023 On 08/05/2023 at 14:10, Mindovermaster said: Cute.. I always put a peice of tape over it.. Or use a Sharpie lightly over it. Won't maker it black, but it will dim the light. Expand I think he still wants to see the light when it's on, just not while it's sleeping. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818958 Share on other sites More sharing options...
Asharae Posted May 8, 2023 Share Posted May 8, 2023 On 08/05/2023 at 13:22, Warwagon said: When you put the computer to sleep at night, just take a bottle lid, and put it over the power button ... Fixed! No more blinky Binky! Expand Just make sure its not thin enough to let light through, or you'll have a nice big bottle cap shaped light 😛 Mindovermaster 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818975 Share on other sites More sharing options...
WiltshireHam Posted May 8, 2023 Share Posted May 8, 2023 You can buy opaque stickers to block the light. goretsky 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818979 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted May 8, 2023 Global Moderator Share Posted May 8, 2023 On 08/05/2023 at 15:02, Warwagon said: I think he still wants to see the light when it's on, just not while it's sleeping. Expand On 08/05/2023 at 16:00, WiltshireHam said: You can buy opaque stickers to block the light. Expand That. They make opaque tape where you can still see it, but dimmed. As for the sharpie, it doesnt fully put the light out. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598818982 Share on other sites More sharing options...
Mindovermaster Global Moderator Posted May 8, 2023 Global Moderator Share Posted May 8, 2023 BTW, this is what I mean by the sharpie. I did this on my old DELL.. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598819012 Share on other sites More sharing options...
Joni_78 Posted May 8, 2023 Author Share Posted May 8, 2023 (edited) Thank you all. I was able to switch off those annoying RGB leds on the motherboard so that those are always off. No luck with the power button blinking on sleep. There just doesn’t seem to be options to adjust it the way I would like to. I would like the led to be on when the PC in on, only disable it when in sleep mode. Also I would still like to be able to charge my keyboard/mouse when it is sleeping. Oh well I just put mouse over it at night. hellowalkman 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598819014 Share on other sites More sharing options...
Steven P. Administrators Posted May 8, 2023 Administrators Share Posted May 8, 2023 On 08/05/2023 at 18:17, Joni_78 said: Thank you all. I was able to switch off those annoying RGB leds on the motherboard so that those are always off. No luck with the power button blinking on sleep. There just doesn’t seem to be options to adjust it the way I would like to. I would like the led to be on when the PC in on, only disable it when in sleep mode. Also I would still like to be able to charge my keyboard/mouse when it is sleeping. Oh well I just put mouse over it at night. Expand I think what you're asking for is impossible. You suggested that the PC needs to be "woken" for scheduled recordings, so that means you can't disable Fast Boot. The whole premise of Fast Boot is that the system is merely sleeping and the internal LEDs reflect this (it is a board status) and you want the LED to work when it is not sleeping so you can't even disable or cover the LED like some have suggested. I am the same, I can't sleep with any white/blue/green/yellow LEDs or even the dimmed state of the LCD screen of my Echo Show 8, the only color that doesn't bother me is red (standby light of my TV) which doesn't even face me so it isn't even bright. My suggestion is to get some red or orange tape and cover the LED with it. I think you'll find it is less distracting. Or you can manually cover it with the mouse like you said. Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598819079 Share on other sites More sharing options...
goretsky Supervisor Posted May 9, 2023 Supervisor Share Posted May 9, 2023 Hello, In the past I have used LIGHT DIMS sticker sheets to greatly reduce the amount of light from LEDs. Very nice when you are sitting at a desk and have a router, NAS, KVM switch or other gear with bright LEDs facing you all day. Regards, Aryeh Goretsky On 08/05/2023 at 16:00, WiltshireHam said: You can buy opaque stickers to block the light. Expand xrobwx71, Mindovermaster and +Warwagon 2 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598819101 Share on other sites More sharing options...
Thrackerzod Posted May 9, 2023 Share Posted May 9, 2023 hellowalkman, Steven P., Astral and 1 other 4 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598819138 Share on other sites More sharing options...
vf- Posted May 9, 2023 Share Posted May 9, 2023 (edited) On 09/05/2023 at 01:42, goretsky said: Hello, In the past I have used LIGHT DIMS sticker sheets to greatly reduce the amount of light from LEDs. Very nice when you are sitting at a desk and have a router, NAS, KVM switch or other gear with bright LEDs facing you all day. Regards, Aryeh Goretsky Expand Those blackout stickers are great. They even have them in grey/silver. https://www.amazon.co.uk/LightDims-Original-Strength-Electronics-Appliances/dp/B009WSJNCW/ goretsky 1 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598819143 Share on other sites More sharing options...
Xenon Posted May 9, 2023 Share Posted May 9, 2023 (edited) On 08/05/2023 at 13:22, Warwagon said: When you put the computer to sleep at night, just take a bottle lid, and put it over the power button ... Fixed! No more blinky Binky! Expand Thats a good idea. I use these: (you can find them on amazon for $2.99 +Warwagon, goretsky and Steven P. 3 Share Link to comment https://www.neowin.net/forum/topic/1428856-disable-power-button-and-motherboard-leds/#findComment-598819255 Share on other sites More sharing options...
Register a new accountSign in
