Edge not taking "not now" as a answer.
Interesting just started edge (no surprise got the set default nag) big surprise, the "not now" is grayed out.
*thought weird it had the (manged by your organization briefcase) not a org computer just a personal one, no MS account even on it with a standard Windows 10 Pro install.
I just closed Edge and when it came back up it was gone just though it was really weird.
https://www.neowin.net/forum/topic/1429360-edge-not-taking-not-now-as-a-answer/
Edge never takes no for an answer. It's the Pepe Le Pew of web browsers
  • Like 2
  • Haha 1
Just delete Edge and all this goes away. Just flush the nagware.
You should run an article on how to uninstall Edge completely as to avoid it returning. The fact is that MS have turned both Edge and Bing into malware.
Given MS's shameful behavior it is imo a valid topic and it would be a huge article in terms of interaction.
I second this! Maybe with a section at the beginning about the pros and cons (if any) of uninstalling it would be a good addition to the article?
Register a new account
Sign in
