Ryzen 7 7700X / Radeon RX 6600 Build - Comments
Howdy, I'm looking at putting this together for a 1080p gaming build.  My last (RMA'd because it died) NUC-style mini PC had a Ryzen 9 6900HX & Radeon 6600M, so I see this as a comparable machine - but easier to look after.  I don't need storage as I am transitioning that over.  So would appreciate any feedback please:
PCPartPicker Part List
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  (£305.99 @ Amazon UK)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (£64.00 @ Computer Orbit)
Motherboard: ASRock B650M PG RIPTIDE Micro ATX AM5 Motherboard  (£169.98 @ Scan.co.uk)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£113.70 @ Amazon UK)
Video Card: Sapphire PULSE Radeon RX 6600 8 GB Video Card  (£207.98 @ Overclockers.co.uk)
Case: BitFenix Prodigy M 2022 MicroATX Mini Tower Case  (£94.90 @ Amazon UK)
Power Supply: Corsair RM750 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£119.99 @ Amazon UK)
Total: £1076.54
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2023-05-30 22:10 BST+0100
On 30/05/2023 at 22:16, hagjohn said:
If you are gaming you will want more than 8GB
1080p gaming - as I say, my last PC had a 6600M in it, and I was more than happy with the output :)  But if you can recommend a graphics card that doesn't kick my wallet's butt, then please - yeah, happy to listen :)
What about NvME?
I would go 6700 or 6800. Whichever is good for you but try to get something with a at least 12 MB for longevity.
  • Like 1
I got a 6600 myself just the other day upgrading from a vega 56, actually kind of feels like a downgrade but the price was right.  the 6600 can't really do ray tracing so don't expect it.  that being said, would actually look at going to a 6800 if you can afford it, or even a 7000 series card.
Hi, bill gates is calling lol
Think you meant 12GB 😛
Oh I also would personally go with at least 32GB of RAM instead of 16, even if you don't use it you can enable Resizable BAR and get a memory boost for the gfx card.
  • Haha 1
I have!?
ray tracing
I really don’t care about ray tracing but yeah ur right, it absolutely can not
6800
I’ll take a look :)
On 30/05/2023 at 22:59, Mindovermaster said:
Fractal Design
Which would you suggest?
Well, rn I have a Fractal Design Define S2. I think it's out of production, but, ANY Fractal Design case is good. I had 3 or 4 from them, and have been happy with all.
  • Like 1
Cool, am looking for something pretty small as this is a lounge build
This might interest you. In the US, I know, just an idea.
https://www.newegg.com/white-fractal-design-pop-mini-air-rgb-micro-atx-tower/p/N82E16811352163?quicklink=true
Has white and black editions.
  • Like 1
That actually made it onto my list - I like it! :)
  • Like 1
On 30/05/2023 at 18:23, Dick Montage said:
I have!?
😅 I misread it lol
On 30/05/2023 at 18:27, Dick Montage said:
I can stretch to this but please bear in mind that I’m looking at 1080 gaming…
https://uk.pcpartpicker.com/product/c3RYcf/powercolor-fighter-radeon-rx-6700-xt-12-gb-video-card-axrx-6700xt-12gbd6-3dh
Definitely better, actually wish I went with an XT, also regardless of what resolution you're gaming at, the 6700xt is better bang for your buck.
  • Like 1
Total: £1076.54
Have you considered the RX 6700 10GB from XFX? It is around 30-35% faster than the 6600 and comes with 10GB VRAM. https://uk.pcpartpicker.com/product/Rs92FT/xfx-speedster-swft-309-radeon-rx-6700-10-gb-video-card-rx-67xlkwfdv Should be a snug fit.
  • Like 1
OK, so I have now refined it to the following:
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£112.96 @ Amazon UK)
Video Card: PowerColor Fighter Radeon RX 6700 XT 12 GB Video Card  (£338.99 @ AWD-IT)
Case: Fractal Design Pop Mini Air MicroATX Mid Tower Case  (£84.95 @ AWD-IT)
Power Supply: Gigabyte P850GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£84.18 @ CCL Computers)
Total: £1161.05
Any feelings either way on cooling - I tend to err toward air cooling as I have had two AIOs fail on me - and fans can be run so quietly now.  That cooler rates almost as well as the Noctua NH-D15 and is half the price - and white.
Is the Ryzen 7 7700X maybe a bit much?
Is G.Skill Ripjaw memory OK?
Thanks
  • Like 2
Have you checked ASrock's MOBO QVL for compatibility with the G.Skill kit you've selected?
https://pg.asrock.com/mb/AMD/B650M PG Riptide/index.us.asp#Memory - I see the shortened SKU# F5-6000J3040F16GX2 but not the specific F5-6000J3040F16GX2-RS5W, so that might be something to follow-up on as RAM with 7000x seems really finicky from what I've seen and heard.
  • Like 2
I NEVER had a problem with G.Skill.. I've been using the Ripjaws line for 10+ years.
  • Like 1
And I'm sure many others haven't had a single issue either - I'm not trying to single-out G.Skill at all. I'm simply relaying info about RAM frequencies that many have experienced with the AM5 platform since launch in general. Making sure the kit you've selected is on a QVL can go a long way in determining stability and being able to run at advertised MT's.
  • Like 1
I just noticed that the memory isn't AMD EXPO certified and also not on the motherboard QVL list. I personally wouldn't choose this memory since Ryzen 7000 is quite finicky with RAM.
I found these that are similarly priced and are EXPO:
you can also go for some other manufacturer other than GSKILL
  • Like 2
OK, not gonna be a pest much longer, but having ditched the non-compliant RAM, I ditched the white theme and now am settled on:
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (£59.00 @ Computer Orbit)
Memory: G.Skill Trident Z5 Neo 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£154.44 @ Newegg UK)
Case: Fractal Design Pop Mini Air MicroATX Mid Tower Case  (£79.97 @ Box Limited)
Power Supply: Gigabyte P850GM 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£92.99 @ AWD-IT)
Total: £1201.36
  • Love 1
I recently bought an atx case and was able to compare various case sizes in 3d 👉https://comparesizes.com/comparison/h5-vs-cm-n400-vs-mesh2-c-vs-Cooler-Master-MasterBox-Q500L-vs-g3-vs-Wine/16835783329861696. Handy, no?
  • Like 1
  • Thanks 1
Size isn't likely to be an issue, but thanks
Register a new account
Sign in
