jnelsoninjax Posted July 6, 2023 Share Posted July 6, 2023 So I have two USB A to C cables and, despite them being plugged into a power brick, the device(s) (phone and tablet) that I attempt to charge never get past 52%, yet when I used another cable, the exact same as one of the other mentioned ones, it would charge to 100%, however, the cats knocked over a box that landed on the cable and bent the adapter 180 degrees. What could be causing this issue, is it the cable(s) themselves, or is it something else? Link to comment https://www.neowin.net/forum/topic/1431032-usb-a-to-c-cables-odd-charging-issues/ Share on other sites More sharing options...
Mindovermaster Global Moderator Posted July 6, 2023 Global Moderator Share Posted July 6, 2023 (edited) I think your wires are cut. They don't have to be fully cut to not work. Well.. Might want to keep it away from things that can fall on it. (isn't that everything? ) Link to comment https://www.neowin.net/forum/topic/1431032-usb-a-to-c-cables-odd-charging-issues/#findComment-598833842 Share on other sites More sharing options...
jnelsoninjax Posted July 6, 2023 Author Share Posted July 6, 2023 On 05/07/2023 at 23:26, Mindovermaster said: I think your wires are cut. They don't have to be fully cut to not work. Well.. Might want to keep it away from things that can fall on it. (isn't that everything? ) Yeah, good point, I would not have expected the 4 demons that run this household to knock over the box because it was against the wall! I guess they proved me wrong! Link to comment https://www.neowin.net/forum/topic/1431032-usb-a-to-c-cables-odd-charging-issues/#findComment-598833843 Share on other sites More sharing options...
Register a new accountSign in
