kiddingguy Posted September 18, 2023 Share Posted September 18, 2023 I have a Satechi TYPE-C Multi-Port Adapter 4K Ethernet Space Grey v2 connected to my computer. I tried to connect a belkin MagSafe charger to it, but my iPhone won't charge [when I put it directly in teh USB-C port of my notebook it works]. I guess the power isn't sufficient. Is there a USB-C splitter available to which I can connect this MagSafe charging cable, AND make use of the Satechi adapter [not for only charging mouse and mousepad (RGB) & maybe in the future also an external HDD/SSD). Or is the layout/working of USB-C not compatible with this setup? Which splitter to use in this case? Link to comment https://www.neowin.net/forum/topic/1433588-usb-c-splitter-for-magsafe-charging-regular-usage-is-it-available/ Share on other sites More sharing options...
goretsky Supervisor Posted September 18, 2023 Supervisor Share Posted September 18, 2023 Hello, USB-C splitters and extension cables are specifically disallowed by the USB spec. Magnetic "breakaway" adapters are not mentioned, from what I recollect, but they are not recommended due to issues with ESD, signalling, and possible electrocution hazard (latest USB Power Delivery specification supports 240W). That said, I would suggest reaching out directly to Satechi explaining what you would like to do, and see if they can recommend a solution that meets your needs. Regards, Aryeh Goretsky Jose_49 1 Share Link to comment https://www.neowin.net/forum/topic/1433588-usb-c-splitter-for-magsafe-charging-regular-usage-is-it-available/#findComment-598851009 Share on other sites More sharing options...
Arceles Posted September 19, 2023 Share Posted September 19, 2023 https://es.aliexpress.com/item/32856424185.html?spm=a2g0o.order_list.order_list_main.53.3fa8194dLLfKUv&gatewayAdapt=glo2esp Maybe one of these will work? Link to comment https://www.neowin.net/forum/topic/1433588-usb-c-splitter-for-magsafe-charging-regular-usage-is-it-available/#findComment-598851160 Share on other sites More sharing options...
Register a new accountSign in
