stealth001 Posted April 20 Share Posted April 20 Hi. My mate bought one of these laptops GOCHI 14.1'' Laptop PC 2 in 1 Touchscreen Laptop N100 Processor(Up to 3.4GHz) 16GB RAM 512GB SSD 360° Foldable Notebook with 2.4/5G Dual Band WiFi Bluetooth 5.0 Type-C 46WH Battery Fingerprint Unlock Manufacturer GOCHI Series ANL5 YOGA We wiped the windows 11 and put a fresh install on it. But there are a load of drivers missing and can we hell find a website with the drivers that are needed. If any one could help that would be brilliant. Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/ Share on other sites More sharing options...
goretsky Supervisor Posted April 21 Supervisor Share Posted April 21 Hello, I am unfamiliar with this brand, but saw a model being sold on Amazon at <https://www.amazon.co.uk/dp/B0CTSYRL3J>. Perhaps you could try leaving a comment asking about drivers and seeing if the seller replies? Regards, Aryeh Goretsky Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/#findComment-598896765 Share on other sites More sharing options...
hellowalkman Reporter Posted April 21 Reporter Share Posted April 21 Sometimes Microsoft's Device Manager can automatically detect and download the necessary drivers. Why not give that a shot if you haven't? Right-click on the Start button Go to Device Manager, you will find all your devices listed here Go to each of them one by one and right-click> Update driver > Search automatically for drivers Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/#findComment-598896779 Share on other sites More sharing options...
stealth001 Posted April 21 Author Share Posted April 21 Yes i think ill contact amazon regarding the issue or i may try the snappy driver software and down load the 30 odd gig worth of drivers and see if picks any of them up. Thanks for the help. Regarding the 2nd comment. Yep tried that. Its deffently intel related even tried the intel driver updater. hellowalkman and goretsky 2 Share Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/#findComment-598896804 Share on other sites More sharing options...
+Warwagon MVC Posted April 22 MVC Share Posted April 22 On 20/04/2024 at 22:47, hellowalkman said: Sometimes Microsoft's Device Manager can automatically detect and download the necessary drivers. Why not give that a shot if you haven't? Right-click on the Start button Go to Device Manager, you will find all your devices listed here Go to each of them one by one and right-click> Update driver > Search automatically for drivers So that hasn't worked for years I think they killed it in the Windows 10 2004 update. They still let you do it, but it doesn't do anything. The new way to do it in Windows 11 is to click on Start / Settings / Windows update / Check for updates, then click on "Advanced options" / Optional updates / Driver Updates. Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/#findComment-598896992 Share on other sites More sharing options...
adrynalyne Posted April 22 Share Posted April 22 (edited) On 22/04/2024 at 07:52, Warwagon said: So that hasn't worked for years I think they killed it in the Windows 10 2004 update. They still let you do it, but it doesn't do anything. The new way to do it in Windows 11 is to click on Start / Settings / Windows update / Check for updates, then click on "Advanced options" / Optional updates / Driver Updates. It still works, it just doesn’t work often because by default WU is checked upon device detection. If something interrupted that or the device was offline at the time, then it will work if a driver is available. Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/#findComment-598896993 Share on other sites More sharing options...
+Warwagon MVC Posted April 22 MVC Share Posted April 22 On 22/04/2024 at 09:57, adrynalyne said: It still works, it just doesn’t work often because by default WU is checked upon device detection. If something interrupted that or the device was offline at the time, then it will work if a driver is available. Ever since then, I've had 0% luck. I just wrote it off, having been broken since I think it's Windows 10, 2004. Because before then it worked great, and I had great luck with it. Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/#findComment-598896996 Share on other sites More sharing options...
adrynalyne Posted April 22 Share Posted April 22 On 22/04/2024 at 08:10, Warwagon said: Ever since then, I've had 0% luck. I just wrote it off, having been broken since I think it's Windows 10, 2004. Because before then it worked great, and I had great luck with it. Just a guess, but before then it probably wasn’t checking WU upon device initialization. Link to comment https://www.neowin.net/forum/topic/1440597-driver-help/#findComment-598897003 Share on other sites More sharing options...
Register a new accountSign in
