bikeman25 Posted June 17 Share Posted June 17 (edited) Hello All Townhome inspection scheduled for tomorrow the 18th, should i leave my Flat Ethernet cable sorta ran under door, then along the edge of the steps, down to Comcast gateway Modem? or should i unplug the Gateway from power, disconnect the ethernet wire (then bring that part of the wire up here, and hide it behind Laptop Desk) Then configure Desktop to use The backup Wifi 6E Connection, and use that til after the inspection is over with. They do check if Doors will close and open properly along with checking Windows, Closets, Hvac, Appliances, Under sinks, and such for leaks Picture included for reference Link to comment https://www.neowin.net/forum/topic/1442753-townhome-inspection-tomorrow-flat-ethernet-cable-ran-sorta-under-door/ Share on other sites More sharing options...
satukoro Posted June 17 Share Posted June 17 While I'm not sure if this is technically an issue, it wouldn't hurt to pull the ethernet cable out of there until after the inspection just to be on the safe side. goretsky 1 Share Link to comment https://www.neowin.net/forum/topic/1442753-townhome-inspection-tomorrow-flat-ethernet-cable-ran-sorta-under-door/#findComment-598910696 Share on other sites More sharing options...
bikeman25 Posted June 17 Author Share Posted June 17 Oh ok then will work on that asap here, and get that part sorted satukoro 1 Share Link to comment https://www.neowin.net/forum/topic/1442753-townhome-inspection-tomorrow-flat-ethernet-cable-ran-sorta-under-door/#findComment-598910697 Share on other sites More sharing options...
LittleNeutrino Veteran Posted June 17 Veteran Share Posted June 17 i've never had a landlord complain about anything like that then again I also to get a cable downstairs once drilled a hole in the floor in a corner and had it come down into the room below it through the ceiling and nobody batted an eye at that either. Gerowen 1 Share Link to comment https://www.neowin.net/forum/topic/1442753-townhome-inspection-tomorrow-flat-ethernet-cable-ran-sorta-under-door/#findComment-598910704 Share on other sites More sharing options...
Register a new accountSign in
