Surface Pro OLED Copilot+PC Snapdragon X Elite USB Boot
Having Trouble Boot From Any USB tried windows media maker for Windows 11 try the recover maker With no Luck This is not my first Surface Pro i have a surface pro 4,6,7,9 and a Go 3 so do no how to boot from usb and never had this Problem (And The USBs i have tried all work on the other surface)
any help would be good
Thanks
Hello,
Have you tried downloading the Surface Recovery Image for your model of Microsoft Surface from https://support.microsoft.com/en-us/surface-recovery-image and using that?  If your Surface has a Qualcomm Snapdragon CPU it is not going to boot from any media for Intel/AMD CPUs.
Regards,
Aryeh Goretsky
On 27/06/2024 at 05:46, goretsky said:
Hello,
Regards,
Aryeh Goretsky
yes have tried the surface recovery Image but again this will not boot
what i what to use is Macrium Reflect to make a backup of the hard drive
@Bat21UK This might be caused by the Secure Boot and I believe the locking down of hash/keys being accepted by Microsoft/Intel/Someone now.
Have a look at https://www.ventoy.net/en/index.html when you boot from the resulting USB you will get an error and then be able to enroll the key. Ventoy is using the UEFI hash from an existing Linux Distro to the best of my memory.
Here is the part of the doco explaining what you need to do to enrol the key. https://www.ventoy.net/en/doc_secure.html
 Big Thanks for the help
Hello,
Regards,
Aryeh Goretsky
so are you telling me the the recovery image that windows 11 can build will not work
and again big thanks for the help Aryeh Goretsky
Register a new account
Sign in
