f-405sb Posted July 10 Share Posted July 10 (edited) I have an old led tv that the computer recognises as 1360x768 resolution, i just use Custom Resolution Utility (CRU) to add 1920x1080 resolution I also enabled Internal Graphics card Intel HD 630 and it works just like a vga converter to my graphics card, no need extra adapters, converter or cable to use led tv PS: bought this cheap hdmi to vga and dvi to vga converter, it just burns out in a couple of weeks, even days. Edited July 10 by f-405sb Link to comment Share on other sites More sharing options...
Ixion Posted July 11 Share Posted July 11 Is it displaying 1920x1080 or is the TV downscaling it? Lots of the Older "HD Ready" TVs only did 720p or 1360x768 which they claimed was full HD by using interlacing (1080i). Link to comment Share on other sites More sharing options...
f-405sb Posted July 11 Author Share Posted July 11 it's says 1920x1080 in tv osd, also images on screen becomes smaller hellowalkman 1 Share Link to comment Share on other sites More sharing options...
Ixion Posted July 11 Share Posted July 11 Nice, I've used a TV as a monitor for years, currently on a 48" LG 120Hz 4k OLED TV, makes for a lovely monitor f-405sb 1 Share Link to comment Share on other sites More sharing options...
hellowalkman Reporter Posted July 11 Reporter Share Posted July 11 On 11/07/2024 at 20:24, f-405sb said: it's says 1920x1080 in tv osd, also images on screen becomes smaller you can confirm it's indeed 1920x1080 by taking a screenshot and checking the image details. Link to comment Share on other sites More sharing options...
goretsky Supervisor Posted July 11 Supervisor Share Posted July 11 Hello, Just to confirm, have you looked up the brand and model of the TV to confirm that it has 1920×1080 resolution? Also, have you checked to see if the manufacturer provides a monitor profile information file (aka device driver) for the device to use it as monitor with Windows? Regards, Aryeh Goretsky Link to comment Share on other sites More sharing options...
f-405sb Posted July 11 Author Share Posted July 11 (edited) to clear things up, the igpu detects the tv as a 1360, but using CRU I can use 1920 same as an adapter converter would do. And using motherboard vga port the dgpu is using its computing power and fps to output it to the tv Edited July 11 by f-405sb Link to comment Share on other sites More sharing options...
Register a new accountSign in
