Looking for some help with converting an STL to model
Hey Guys and Gals,
Looking for a bit of help since my 3d skills are lacking.  Would someone be able to help me convert the following from Thingiverse to either a blender or fusion model.  I'm looking to use this for an Arduino/Pico project, will need to hollow it out and add mounting posts.
https://www.thingiverse.com/thing:5337939
  • 1 month later...
I'm not sure you'd have any luck with that task. I've tried to import an stl file into solidworks before on a couple occasions and it basically has to reverse engineer the part. One of the problems with this is that you end up with a very messy, very bloated project file and the conversion for even simple parts takes a long time and significant resources.
You would be better off remodeling the part from scratch or reaching out to the author and asking for the project file.
If i have time later I'll take a look and see if it wouldnt be too hard to recreate in OnShape (free web based cad).
Register a new account
Sign in
